V-LED New DRL Harness
Old 05-10-2011, 07:54 AM
  #201
Fastest_Type_S_5at's Avatar
Looks nice. I cant wait till i get mine going. btw, it seems as if everyone except me got their harness replaced by vleds but me. i called them and they said ok yes we will replace the harness and when i check the mail, all i got was a new relay. Original relay was always working, thats not the issue. Could it be that the wires connecting to relay itself were not placed in correct order?? Not sure. Any suggestions?
Old 05-11-2011, 03:58 AM
  #202
SDSilverM3's Avatar
You could ask James to send you a harness that he has already tested out and is known to be working. There appeared to be no differences between my original harness and the replacement though it is hard to tell unless I strip the jacket off. Have you tried flipping the polarity of the wires?
Old 05-22-2011, 03:50 PM
  #203
Cheval's Avatar
I've sat on this and now that the reliability issues have been cleared up I'm wanting to buy. The original link doesn't work anymore but most (?) of the individual parts seem to be available on the vleds site, except for the module with the resistor. Anyone have a list of exactly what is needed or is the all-parts-that-are-needed kit still available?
I really think that LED look is sweet and I'm trying to resist my car with the audi/bmw look of LEDs. I think put the LEDs in the stock location might be the ticket.
TIA
Old 05-22-2011, 04:31 PM
  #204
vp55's Avatar
TIA
+1
EDIT: Guys, is this the link that includes the new harness?
http://www.v-leds.com/Vehicle-Specif...orLanding/true
Old 05-22-2011, 05:19 PM
  #205
Suprstar's Avatar
Originally Posted by vp55
+1
Yes. I got the 6K bulbs though. I recommend getting the 5K bulbs. When mine eventually die that's the temperature I'm gonna get.
Originally Posted by SDSilverM3
Thanks for the help everyone.
Full power on both sides now. Mounting the relay and resistor on the driver's side was fun. ]
I just used double-sided tape to mount the resistors.
Old 05-22-2011, 10:16 PM
  #206
Cheval's Avatar
thanks for the link. I tried searching their site but must have missed it.
Old 05-23-2011, 06:15 AM
  #207
mboob's Avatar
When I was looking, you couldn't get there by searching so maybe you didn't miss it. I also went with 6K and I wish that I would have gone with 5K. Not that it looks any bit bad, just a little blue. I did the double sided tape on the driver's side, there's a good place on the passenger's side to mount the plate, I think the instructions even tell you where for that one.
Old 05-23-2011, 10:26 AM
  #208
CHEWKNOW's Avatar
I bought and installed the new V-LED's DRL kit with harness/resistors this weekend and it worked perfectly. SO NICE! I will post pics of where I mounted the drivers side resistor plate. I already had the bumper off so I mounted it right under where withe drivers side headlight housing is on a piece of metal with 3M VHB tape and 2 tie wraps. Its not goin anywhere!
Old 05-23-2011, 05:34 PM
  #209
HiHenry.com's Avatar
Hi,
I have a Canadian 2006 Acura TL. Will this work for my car? Has anyone tried it?
I watched the video and the car setup seems to match.
Henry
Old 05-23-2011, 06:12 PM
  #210
vp55's Avatar
Did you get the 5k or 6k bulbs? Pics would be awesome as I think this would be a great mod for the ugly OEM DRLs.
Please post pics if you get a chance.
Old 05-23-2011, 08:35 PM
  #211
murph145's Avatar
finally got mine all dialed in....
i bought a set of the lights like 2 years ago at that time they said to use two of the plug and play modules which did not work only one light came on and my DRL warning light was on.... then they had me buy some otehr harness they said would work.... half the time barely any light was on and the other half no light go figure... finally i have been seing this thread and irritated at the fact i spent so much $ and my DRL's were not even on... so contacted vleds told them i am not buying a entire setup for $99 just want the harness because all of this back and forth and $ i had spent previously on other setup of harnesses... so they broke out a harness sent it and took me like 20 mins to hook up .... luckily this one works perfectly or id be an angry mo fo
Old 05-23-2011, 08:52 PM
  #212
CyDogg's Avatar
make more. This is a sweet mod
Old 06-12-2011, 10:53 AM
  #213
DooooT's Avatar
link to this product? Tried searching on their site - but didn't find anything that that was TL specific.
Thanks ahead of time.
Old 06-12-2011, 07:15 PM
  #214
vp55's Avatar
^They took it off there site, and when I emailed them they said to check back this week, however I still do not see them available.
I bought my set from ijdmtoy instead.
DooooT (06-13-2011)
Old 06-15-2011, 02:01 PM
  #215
Suprstar's Avatar
Damn it...I think my DRL's are starting to flicker. I hope it was just a freak thing. I've only had them (V-LED DRL) for two months
It would really suck if these thing have to be replaced every few months. They're damn expensive.
Old 06-15-2011, 02:05 PM
  #216
WhteTLS's Avatar
^ where did u place the resistors? they start to flicker when it heats up.. u need to place it where if can stay cool.. I have it screwed to the frame (metal) so it stays cool or atleast transport the heat to the metal.
Old 06-15-2011, 06:52 PM
  #217
Suprstar's Avatar
Okay, that makes sense.
I used 3M double-sided tape and stuck it pretty exactly where V-LEDS recommended it should go. The flickering occurred on my way to work. I noticed it when I parked in a garage in the Manhattan.
UPDATE: I checked the lights when I got home and they looked fine. So I guess it just flickers when it gets hot (like WhteTLS said). Whew...what a relief.
Old 06-15-2011, 09:51 PM
  #218
mboob's Avatar
I haven't noticed any flickering with my V-LED's harness. Both of my resistors are touching as much metal as possible, so maybe they're just transferring most of the heat away.
Old 06-16-2011, 01:35 PM
  #219
Suprstar's Avatar
Damn, I sound retarded in my post above.
It was a long day.
Old 06-16-2011, 11:00 PM
  #220
vt4lifecuf's Avatar
vleds is too expensive i found another alternative
http://store.ijdmtoy.com/9005-LED-Da...d_sku45_r3.htm
Old 06-17-2011, 07:54 PM
  #221
Suprstar's Avatar
I bought the kit through V-LEDS. I think the bulbs without the harness is around $50. I could be wrong.
Old 06-17-2011, 09:14 PM
  #222
vt4lifecuf's Avatar
The harness is very easy to make, you can get resistor on superbrightleds for 3 bucks. imo... i think vleds is a bit overprice.
Old 06-18-2011, 04:31 PM
  #223
Brokendubs's Avatar
Do you have these installed? Pics?
Old 06-30-2011, 08:10 PM
  #224
John08TL-S's Avatar
Old 06-30-2011, 10:55 PM
  #225
BSpecialist's Avatar
Just bought 68smd LEDs on eBay for $1 + $5 for shipping form HongKong. I just ordered this DRL harness and will post how well the harness works and pictures as soon as i get them.
Old 07-02-2011, 12:28 PM
  #226
Ok, call me stupid now. Do I need one of these modules for each LED DRL bulb? I ordered it figuring they'd send me enough to take care of my whole LED DRL issue (considering most people put 2 LED DRLs in at a time) but was surprised to just see 1 module. Thanks for the help.
Old 07-21-2011, 10:11 AM
  #227
CHEWKNOW's Avatar
I'm having the same flickering issue with the DRL's flickering after about 10 minutes of them being on. It seems as though this happens when they "heat" up? I have both the resistors mounted exactly as they say in the instructions. Has anyone found a solution to this? Is the problem that the RESISTOR itself is heating up causing the bulbs to flicker? This is kind of annoying. I hope I don't need to wait until winter for this to stop.
Old 08-26-2011, 12:19 AM
  #228
SDSilverM3's Avatar
I would think, yes, you would need one module (resistor) for each LED (one for each socket) since the VLED harness comes with two.
I haven't experienced the flickering issue yet or maybe I haven't noticed but I will keep my eye out for flickering since we're entering a stretch of warmer weather here in San Diego.
Old 08-26-2011, 01:36 AM
  #229
Update: Their new "Plug 'N Play" module is anything but. I tried with 1 module, nothing. I tried with another module, still nothing. Their tech support is pretty piss poor if you ask me but they agreed to refund me everything so it was only a slight pain in the ass. I reckon I'll be going with the DRL module setup from iJDMtoy.
Old 08-26-2011, 02:20 AM
  #230
Mons shaver
magnod's Avatar
That's too bad.
I just returned my iJDMToy version. It was easy to install, DRL warning light was on, but that was no big thing. The main gripe I had was that the lights were so dim looking during the day. Most times, you couldn't even see them unless you were really close. I could barely see them reflected on the cars in front of me a stops.
I've been looking for something brighter, so if anyone finds it please let me know.
Old 08-26-2011, 02:28 AM
  #231
GeaugaDog's Avatar
Has anyone here just pulled out the fuse for the DRLs? Is that an ok thing to do to disable them? I'd rather not have them on even the LED version (but especially not the ugly stock lights)
Old 08-26-2011, 10:02 AM
  #232
JTS97Z28's Avatar
I am curious about this as well. I actually think the stock DRL's look ok however today my pair of 92 LED 5000K switchbacks will be arriving from vled's. During the day I can use the white 5000K parking lights only if I would like. The colors would kind of clash if the DRL's were on so if I can disable them then that would be good.
Old 08-26-2011, 11:45 AM
  #233
KB1Spec's Avatar
I got these for my cousin's TL and works great without any problem. I installed the CREE LED and it is full 12V power instead of the conventional 6V while in DRL mode. Here is the link. They also sent me an email for a discount code too. Let me look for the code.
http://www.jlclightings.com/9005_CRE..._p/sku_067.htm
Old 08-26-2011, 12:25 PM
  #234
Engineer
lights's Avatar
do you think i can just get the DRL decoder kit by itself??
Old 08-26-2011, 01:46 PM
  #235
KB1Spec's Avatar
Module without the LED bulb you mean? I assume you can.
Old 08-26-2011, 05:25 PM
  #236
Mons shaver
magnod's Avatar
Is it bright? The last IJDMToy one I tried looked nice, but could barely be seen from a few cars away...
Old 08-26-2011, 05:50 PM
  #237
KB1Spec's Avatar
CREE is VERY bright and tends to get hot but they have a resistor and a heat sink on the bulb to prevent being burnt and reduce the heat.
We tested on my 12 TL but there is a shied that in front of the headbeam so we put in a SMD 360 Bulb and its bright but not as bright as the CREE. I'll see if I can post some pic of my cousin TL for the comparison.
Old 08-26-2011, 07:19 PM
  #238
IDSTL's Avatar
That's too bad.
i bought one set DRL kit and angel eye kit from JLClighting .com , the installation is very simple , took me about 10 mins for the DRL . took me 3 hr on the angel eye kit .i run a switch on both 9005 bulb (Cree led chip )and the angel eye , so i can switch when ever i like while i am driving . all i can say is i really love them , they are very bright .
here is the link :
youtube :
http://www.youtube.com/watch?v=MNjYBYlt5aw
here are my pics
Old 08-26-2011, 10:48 PM
  #239
Mons shaver
magnod's Avatar
here is the link :
youtube :
here are my pics
Looks awesome
Do you have any daytime pics of the DRL?
Old 08-28-2011, 03:54 PM
  #240
sockr1's Avatar
Received 1,158 Likes on 909 Posts
so i def want to change out my DRLs and just spent all of today reading this entire thread...but here are what i believe my options were/are:
v-leds took the kit off their website (at least none of the links work and i can't successfully search for it) so i emailed them but wont' get a response til business hours...unless i am not searching for the right thing
iJDMToy version seems like it doesn't give you the brightness that it is meant for in terms of DRL/safety
any other options or thoughts on where to go from here? i really want this mod! it looks great on your car pics
Quick Reply: V-LED New DRL Harness
