TSB covered under Warranty
Hey guys quick question for you.
Are service bulletins covered under Acura CPO 12,000 mile warranty?
Also are they covered by the extended Acura Care Premium?
The reason I ask is because I'm getting a check gas cap message pop up every so often after double checking the gas cap, also some rear deck rattle in an 08 TL.
AZ Community Team
Received 7,770 Likes
Although I'm not positive, I would say, "Yes." Even then you need to exhibit the symptoms of the TSB AND be within the VIN range.
If not, then you are relying only on the provisions of the extended warranty and/or dealer goodwill.
I would say yes. Opinion not fact.
I disagree. Acura Care itself does not cover rattles ( that's why i never got it lol ) . If your car is under 50k it will be covered by the factory warranty. And I'm guessing your over 50k because you bought the extended coverage.
Not sure who your dealership is but mine convered it! I actually have a little over 41,000 on my car but opted for the extended warranty till 100,000, which is full powertrain and bumper to bumper.
^ you have an 08 with a little over 41k of course your covered for the rattle by the factory warranty and I'm pretty sure after 50k you won't be covered for rattles. Acura care does not cover any rattles.
WHAT IS NOT COVERED BY ACURA CARE
Parts other than genuine Acura or AMERICAN HONDA authorized parts; wiper blades; battery (except for the nickelmetal hydride battery in hybrid VEHICLES); cables; steering wheel; belts; radiator hoses; heater hoses and vacuum hoses; spark plugs; plug wires; distributor cap and rotor; timing belt replacement when performed as routine maintenance: exhaust system, head pipes, tailpipes, catalytic converter; mufflers; hangars; heat shields; gaskets (except for the manifold block gaskand related fastening hardware); fuel system; fuel tank straps; fuel hoses; brake system wear items such as drums/rotors, shoes/pads; clutch disc, clutch pressure plate; throw out bearing, external shift linkages; pilot bearing/bushing; glass, mirror glass, body structure (except for hood hinges, trunk hinges, door hinges and sliding door rollers), hood fenders, doors, rear hatch, trunk lid, grille, panels; bright metal; sheet metal; paint (except for covered hinges painted to match the original VEHICLE color only); bumpers; moldings; lenses; bezels; bulbs (except for instrument panel illumination bulbs); HiIntensity Discharge (HID.) headlamps; sealed beams; fuses; body seals; weather-strips (except for window sash and windowrun channels); outside ornamentation; emblems; tires; valve stems; wheels; wheel covers/ornaments; rims; trim rings; caps; wheel studs; lug nuts; wheel locks; fastening/securing hardware for non-covered components; stripped or cross threaded fasteners (e.g., nuts, bolts, studs, screws, etc.); body seals; squeaks, rattles; buttons; carpet; dash pad; console; window handles; knobs; boots; pedals; pads; rearview mirror (except for electronic failure of the auto-dimming mirror); interior trim; upholstey; floor mats; electronic/audio accessories and cellular telephones other than AMERICAN HONDA AUTHORIZED ELECTRONIC/AUDIO ACCESSORIES/NAVIGATIONAL, DVD ENTERTAINMENT AND SECURITY SYSTEMS; Safety Restraint System fastening hardware; seat belts and airbag(s) deployed due to collision. If YOU believe there is a defect in these parts, please contact YOUR DEALER immediately.
Sorry to bring a thread back from the dead but, given that the TSB states that there is a defect in material and workmanship and gives advice on how to fix said defect, would that make it covered under an Acura Extended warranty? Anyone know for sure? If it's hit or miss I'll take my chances, but better to be armed with actual information when you talk to the genius service writers.
mlody
12-04-2019 02:11 PM
