Transmission fluid quick question!
Hows it going everyone ! Ive just recently purchase a 2005 Acura TL 6MT and i was wondering if anyone knows if amsoil manual synchromesh transmission fluid is good for the TL. I've seen good results of it being used on rsx type s but I'm not sure if there is a better preference for the TL. Also would there be a problem if i do a transmission flush and replace it with a new type of tranny fluid ? Thanks for your time !
Latent car nut
Received 2,005 Likes
Go with what works, ACDelco Synchromesh Friction Modified. Accept no substitutes.
LoveMyTL-S (05-01-2019)
I have a mix between OEM and redline d4. about 50/50.. and holding there for now
Latent car nut
To the OP, there are literally hundreds of posts here which supports the notion the best gear lube for cars with the 6-Speed manual is ACDelco Synchromesh Friction Modified. There is no need to look any further for the best MTF for your transmission.
o
Yes, but this conversation is about manual transmissions and, unless I am mistaken, you have an automatic.
horseshoez (05-05-2019)
thefork
08-21-2011 02:15 PM
thelastaspec
06-13-2011 12:59 AM
Putthead
01-13-2011 09:30 AM
silver01cltypes
08-12-2010 03:47 PM
idkjai
08-12-2009 11:16 PM
