Transmission fluid quick question!
Hows it going everyone ! Ive just recently purchase a 2005 Acura TL 6MT and i was wondering if anyone knows if amsoil manual synchromesh transmission fluid is good for the TL. I've seen good results of it being used on rsx type s but I'm not sure if there is a better preference for the TL. Also would there be a problem if i do a transmission flush and replace it with a new type of tranny fluid ? Thanks for your time !
Go with what works, ACDelco Synchromesh Friction Modified. Accept no substitutes.
I have a mix between OEM and redline d4. about 50/50.. and holding there for now
Originally Posted by Chad05TL
(Post 16421745)
To the OP, there are literally hundreds of posts here which supports the notion the best gear lube for cars with the 6-Speed manual is ACDelco Synchromesh Friction Modified. There is no need to look any further for the best MTF for your transmission. |
o
(Post 16421759)
Yes, but this conversation is about manual transmissions and, unless I am mistaken, you have an automatic.
