TL Type S reliability after 100k miles
Old 07-10-2014, 10:17 AM
5th Gear
smek007's Avatar
My 07 TL Type S AT has just reached 95k miles and my extended warranty is just about over so I'm wondering if its worth spending more maintenance money (timing belt, water pump, etc and keep the car.
I have had alot of problems with it in the past. Everything from fried computer from some A/C hose, bad control arm, bad mirror actuators (replaced 3 times), and now it keeps telling me to tighten the gas cap all the time...
I was wondering if ppl on here have alot more than 100k miles and how their car has been. Please share your experience...more miles the better.
Old 07-10-2014, 10:33 AM
stm25rs's Avatar
https://acurazine.com/forums/3g-tl-2004-2008-93/whats-mileage-your-3g-still-going-strong-826769/
smek007 (07-10-2014)
Old 07-10-2014, 10:42 AM
Received 16,260 Likes on 11,971 Posts
first and foremost, a car is a machine that wears out over time.
any moving part will wear.
in order to maintain the vehicle, you have to replace parts when they go bad.
this applies to all vehicles.
so, if you spend X amount of dollars on maintaining the vehicle a year, it will still be a whole let less than buying a brand new car.
at 100k miles, the engine is just getting broken in. there is a lot more life left from the engine, however, it'll be the small moving parts that go out sooner than the engine will.
it will then be your decision on whether to keep maintaining it, or buy a brand new $35-40k vehicle.
The following 6 users liked this post by justnspace:
Acura_Dude (07-11-2014), DMZ (08-11-2017), kev08wdp (07-10-2014), MRG061 (11-21-2018), smek007 (07-10-2014), YeuEmMaiMai (07-11-2014) and 1 others liked this post. (Show less...)
Old 07-10-2014, 10:49 AM
06 Anthracite TL
erdoc48's Avatar
My 06 runs so well that I'm actually concerned about replacing it when the time comes- some of the newer cars are more technically superior and therefore, more complicated, and subsequently, less reliable. I'm at 100K miles now (actually, 99,500) and I hope to keep mine running for as long as possible. The 105K service can be done for less than $1000 depending on who does it, and then you're good for quite a while more. As justnspace said, to replace what you have will cost at least $35-40K so typically, you're better off paying a little now to keep driving, otherwise you're making payments of at least $500 per month for several years. A payment free car is worth it.
The following 2 users liked this post by erdoc48:
Acura_Dude (07-11-2014), smek007 (07-10-2014)
Old 07-10-2014, 10:54 AM
bla8291's Avatar
I'm at 182K and I have had so little trouble with it, it kind of scares me. I guess I've become accustomed to being around people who don't take care of their cars.
Old 07-10-2014, 10:59 AM
5th Gear
smek007's Avatar
Thanks for the quick responses!
I want to keep the car i just hope nothing major craps out on me. If i didnt have the extended warranty i would've shelled out over 5k already
Slot Machine Lubricator
1black_seven's Avatar
127k and counting.
My only problem so far is my starter wore out. Everything else is pretty solid.
Old 07-10-2014, 11:03 AM
stm25rs's Avatar
Not the Type-S, but a friend of mine has ~240k on his, it's either an 04 or 05. He didn't even do the timing belt service at 105k, finally did it at ~200k. It was his dad's old car. His dad drives an '08 TL now. They both love them.
One of my work contacts (sales) drives 40-50k miles per year. He put about 250k on his 3rd gen before trading it in for a 4th gen.
Old 07-11-2014, 03:52 AM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
147k currently, and running strong. just take care of it and it will take care of you
Old 07-11-2014, 10:09 AM
Rev_2_8k's Avatar
Approaching 200k on my 07TL-S.
No problems other than a power steering pump recall, regular oil changes, brakes, rotations, + major service at 120K (timing belt, etc).
The only little issue I've had was the 'tighten gas cap' which is probably a sensor. My mirror actuators are slowly going and the blue tint on my side mirrors are fading.
Small things aside the car has been bullet proof!
Steve
Timstandupguy (07-13-2014)
Old 07-11-2014, 02:48 PM
FamilyGuy's Avatar
Originally Posted by smek007
...and now it keeps telling me to tighten the gas cap all the time...
Check the gasket on your gas cap and if it's not cracked, replace your purge control solenoid valve (P/N 36162-RDV-J01), located next to your throttle body. It's not too expensive and easy to DIY.
You can order parts from acuraoemparts.com, the purge valve is ~$90 plus shipping.
This car is very reliable. ~85k miles on mine now, 2nd owner. Only issues I've had were the purge control solenoid valve and the starter. My last car, a Volvo S60R, had already racked up over $2k in replacement parts and labor by this time. And I always take care of my cars maintenance wise, but I don't baby them when it comes to driving.
Old 07-11-2014, 03:32 PM
Codename Duchess
DiamondJoeQuimby's Avatar
144k on mine and it doesn't feel the least bit tired. About 85k I've put on. Nothing but regular maintenance stuff. Brakes, oil changes, 105K service, tires, just put on shocks, car has been super easy to own. Only non maintenance thing is I've put an alternator on at ~140k, but I also have a pretty healthy audio system that taxes the stock charging system pretty well.
Old 07-13-2014, 08:02 AM
nokkieny's Avatar
My main concern would be transmission. There isn't much else that is likely to break and is expensive.
Old 07-13-2014, 10:16 AM
KJ TL-S's Avatar
The auto transmission in the Type S models has generally been solid too, without the problems of the earlier base models.
I've only just surpassed 50K last week on mine, but its reliability seems to be keeping me from pulling the trigger on something more entertaining but less bulletproof, the BMW E39 540i/6.
Old 07-14-2014, 11:07 AM
iTzVlad's Avatar
I just hit 90k on mine. Aside from a minor electrical problem (battery gets drained if I don't drive it at least once every 3 days), it's purring like a kitten. Make sure you really take care of your car as soon as a problem surfaces. I've been getting synthetic oil every 6 months, 91/93 octane, changing all the liquids, adjusting anything that needs adjusting, getting full service when needed, etc. It's japanese bro, it'll outlive you and me if treated properly.
Plus the new TL is garbage so I'd keep this one around a bit longer. Hell I use to drive a 1990 ZX in 2011. I'd keep going if it didn't die
Old 07-14-2014, 01:08 PM
kocyk123's Avatar
For the has cap just get the new one. Had the same issue with my Audi. It was barely cracked inside that you couldn't even notice unless to took a really close look. Bought the new one for $6 and my CEL was gone I would also keep the car. You already have a good history of the services and stuff. As somebody mentioned earlier: The car is a machine that wears out over time.
Old 07-14-2014, 01:33 PM
Brock79's Avatar
The new TL is garbage? Please explain this one.
Old 07-14-2014, 02:12 PM
^brock, it was a tongue in cheek moment.
please dont reach for things that arent there.
if you want to be confrontational, please visit the thread you started in Ramblings, we miss you over there. (yes, that was a call out...Since you abandoned the thread, when it was just getting started)
nttstt444 (07-14-2014)
Old 07-14-2014, 02:40 PM
Regional Coordinator
(Mid-Atlantic)
97BlackAckCL's Avatar
Received 4,413 Likes on 3,023 Posts
Get a vette, brah
Old 07-14-2014, 02:51 PM
flyromeo3's Avatar
im at 158k miles and have replaced the following;
Front lower control arms. due to compliance bushings...its a wear and tear item so it eventually will need to be replaced. it was cheaper for me to just buy new control arms vs replacing the bushings.
power steering pump overhaul. ( the 13 dollar fix with all gaskets)
had an issue with water leaking onto my MICU but that was due to a bad windshield installation
other than that, this car has been rock solid.
Old 07-14-2014, 06:22 PM
Brock79's Avatar
I didn't abandon the thread and no one is being confrontational but you. I already said I will return to that thread once the person it was made for shows up. Other than that keep this thread on topic.
Old 07-14-2014, 06:41 PM
so, how about them J-series engines?
not blowing up since 1996
Old 07-14-2014, 08:49 PM
Fearless DIY Guy
DeathMetal's Avatar
Given the low frequency of failures amongst the general TL population for the items you have detailed, it does not appear to be the more intelligible choice in keeping your TL. I would normally jump at the opportunity to recommend holding on to our cars, but something seems generally amiss in the overall construction quality of your specific build, and I would not be surprised if more issues have yet to present itself.
I could be wrong, and I hate to have to resort to such hackneyed expressions as considering your car to be "built on a Friday"...but that's a considerable list in comparison to the general population.
Old 07-15-2014, 02:58 PM
Accord325's Avatar
As everyone says, maintenance. 140k+ only got one CEL for VSA and that was due to not filling the Brake Fluid reservoir up all the way after a flush.
Old 07-16-2014, 08:54 AM
mcmanut's Avatar
I'm at 261,000 on my 2008 Type S and it has been a great car. Outside of the regular services these are the only items that were replaced due to failure.
* Two Purge Control Valves to take care of the Tighen Gas Cap Message( One at 88k and one at 250k
* App Sensor was replaced around 230K when I received a message that it was not working correctly
* The XM Radio Unit needed to be replaced around 225K( Put one a used one on Ebay for $25.00
Everything else has been working great. Engine and Trans are solid with no leaks etc.
Good Luck!
AyyoSeabass (05-03-2019)
Old 03-07-2017, 08:49 PM
8th Gear
rharal's Avatar
2007 Acura TL Type S
Hey guys looking to buy a 2007 tl type s with 152k. Was wondering if the transmissions in these are solid? They have any major problems that i should look out for when i go to look at the car?
Old 03-07-2017, 11:06 PM
OsK
OsK's Avatar
Yeah bro the trannies in deez are bulletproof. I redline in 1st and love hearing my RV6 True Duals bounce off the rev limiter. u shud be gud bro *ok hand emoji* *fire* *fire* *100 emoji*.
Nah forreal though they're bulletproof. Long as you drain and fill every other oil change after you pass 100k (which the car you're buying is).
Make sure the timing belt & water pump were replaced. Make sure the transmission fluid looks good, and you're golden.
MrZuno (08-04-2017)
Old 03-08-2017, 08:43 AM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
the AT is solid but not 100% fail safe UNLESS all the maint been keep up to date.
Old 08-04-2017, 01:23 PM
7th Gear
MrZuno's Avatar
Just bought a 07 Type S with 140k on it. Is there anything that I could do to make sure it has been taken care of. CARFAX shows last scheduled maintenance at 105k, but I'm going to call and verify that the Timing belt was replaced. Besides that should I do a trans flush or sea foam treatment? Don't know too much about sea foam but a lot of people on here swear by it.
Old 08-04-2017, 01:43 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
Three comments:
  1. Seafoam is roughly akin to l'huile de serpent; don't waste your time or money.
  2. Don't "flush" your transmission, that is a really nice way to damage it.
  3. However, do perform what is known as a 3x3x3 ATF service (i.e. drain, fill with three new quarts of DW-1, drive for say a week, and then repeat twice more).
MrZuno (08-06-2017)
Old 08-04-2017, 04:28 PM
truonghthe's Avatar
3x3 on on TL-S and RL I did 3 X 7.
Old 08-04-2017, 09:25 PM
Latent car nut
horseshoez's Avatar
Yikes, what was the "3" and what was the "7"?
Old 08-05-2017, 06:48 PM
truonghthe's Avatar
drain and refill 7 times with 3 quarts (more like 2.5 quarts) each time. I still have 3 cases (12 bottle each case) Honda DW1 left lol.
Old 08-05-2017, 10:51 PM
Latent car nut
horseshoez's Avatar
Sounds like a lot of work and bother; glad I have a 6MT, drain and refill every 30,000 miles with 2.3 quarts of ACDelco Synchromesh Friction Modified.
Old 08-06-2017, 12:26 AM
truonghthe's Avatar
I also glad that I do not have to spend $1300-$2000 to replace the clutch I already had my fair share with MT in the Legend (clutch was good but throw out bearing was shit). Honestly it took 15 mins for each drain and fill.
Old 08-06-2017, 08:15 AM
Latent car nut
horseshoez's Avatar
Old 08-06-2017, 01:13 PM
7th Gear
MrZuno's Avatar
The TL-S has the same engine as the RL, correct? Does it also have the transmission or is the transmission the same as the regular TL?
Old 08-06-2017, 02:56 PM
7th Gear
MrZuno's Avatar
Three comments:
I plan on doing the 3x3x3, but I also reset the ECU and found that it is pretty beneficial for someone who buys a used Acura. I can already tell a major difference in the way my TL-S is shifting and the amount of pickup it has when I lay on it.
Old 08-07-2017, 08:46 AM
truonghthe's Avatar
07-08 TL-S and base TL have the same transmission as the RL with minor details being different other than that its identical. The engine on the TL-S and RL is the same but some minor difference in cam and sensor location.
Old 08-07-2017, 09:04 AM
7th Gear
MrZuno's Avatar
If the TL-S has very similar transmission to the RL why do a 3x3 on the TL-S and a 3x7 on the RL? Sorry that could be an ignorant question, I'm pretty new to all this.
Quick Reply: TL Type S reliability after 100k miles
