thinking of painting my grill
Old Apr 24, 2009 | 03:26 AM
bdown62007's Avatar
so like the title says im thinking about painting my grill. i was just wondering if this if more of a DIY type thing or a get it done professionally. i've never really done anything to myself to any of my cars before. but if its not crazy complicated i figure, i not start here?
Old Apr 24, 2009 | 07:41 AM
bzyrice's Avatar
Originally Posted by bzyrice
I purchased Trim paint by duplicolor.. it is in a green spray can at any autoparts store..
Here is what I did:
I removed the front bumper.. once you get the front bumper off you will see how to remove the grill.. there are a few screws and clips to get the grill off.. then I removed the "A" emblem on the grill. 2 Screws hold that on.. then I sanded the grill with I think 600 grit sand paper.. wiped it down.. then cleaned it with alcohol and let it air dry.. this is to help clean the surface of any oils that could mess with the paint sticking... I then sprayed it with Duplicolor adhesion promotor. I followed the directions on the spray can. Do light coats!! I think I did 2 coats.. this is to help prevent paint chips and help the paint stick. Then I sprayed it with the Duplicolor trim paint. Again with light even coats. I did about 3-4 coats.. This paint dries very evenly and doesn't need clear coat. I have used it to paint side skirts and other parts of my other cars and it looks like paint they use from the factory. Never had a problem with this paint chipping or falling off. Make sure you prep it so the paint will last longer!
Good Luck and pm me if you have any questions!
BTW, Here is a pic of the trim paint:
Here is a pic of the adhesion promoter:
I posted this in this thread: https://acurazine.com/forums/3g-tl-photograph-gallery-96/grilles-grilles-more-grilles-show-give-ideas-here-618755/
And here are pics of my grill:
[/QUOTE]
Old Apr 24, 2009 | 08:34 AM
LoveMyTL-S's Avatar
Some people of painted their grills. Probably some pics in the pics section. Try a search for ideas.
Old Apr 24, 2009 | 08:45 AM
Majofo's Avatar
(in a creepy french voice) Do it! Do it.. Yourself!
The more important question, where you'll get the most response, is what color is your TL and what color are you painting the grill? I'm going to be doing this soon as well.
Old Apr 24, 2009 | 09:17 AM
dlphnsjk's Avatar
IMO go to a specialist and get it painted matched to your car, they color code it so its perfect, ithink that would look tight on a nbp or kbp
Old Apr 24, 2009 | 10:15 AM
maharajamd's Avatar
Here is a copy of a thread I made on preludeonline.com about my TL and grille options... These cars are from members on here.
Ok, so it's time to officially start modding the TL. Its a 2004 in NBP. Well, my ASPEC body kit will be installed tomorrow or Wednesday. Once I get that done, I am scheduled to have some paint work done. I am having a professional fix all of my rock chips, and then do a 4 stage cut/buff.
So while it was there at the shop I figured I would go ahead and do the grille modding...
Here is my stock front/grille (no apsec)
Also notice the different pieces. 1 silver piece on the hood, 1 silver "V" on the bumper, 1 silver horizontal bar that holds the badge, and then the darker gray inside piece.
Here are the choices...
1. "Floating 'A'" - All pieces body matched NBP, center bar removed, mesh added. He also has the aspec front lips which is usually two toned. He had the gray area body matched as well. This is my favorite but this would require cutting/bondo which I don't really want to do.
2. All Black. My second favorite, this would be the easiest to do. Notice the aspec front lip, but he left it two-toned.
3. All Black + Chromed lower grille line. Similar to the Type-S lower grille.
4. Chromed Stock... This is pretty much stock but instead of silver, it's all chromed out. I generally don't like chrome, but this doesn't look too bad...
Discuss...
Old Apr 24, 2009 | 11:42 AM
georgegiorgio's Avatar
G Force
I like the #3....
But seriously, wouldn't be nice to be all black and matte black Emblem would sick....
I really would like to see someone with that configuration...
Also the back, Back Emblem, Acura and TL in matte black with Type-S untouched
Old Apr 24, 2009 | 08:54 PM
bdown62007's Avatar
i have an AM. im thinking aout painting it black or maybe color matching it if i can find the same color
Old Apr 24, 2009 | 09:35 PM
Steven Bell's Avatar
Originally Posted by Maharajamd
Floating "A"....well done !!!!
2009 Kansas City All Acura Meet-May 17th
https://acurazine.com/forums/midwest-312/kansas-city-2009-spring-all-acura-meet-may-17th-12pm-%40-jay-wolfe-acura-714994/
Old Apr 24, 2009 | 09:39 PM
AnthraciteAspec's Avatar
RPF1+RS3 FTW
^^^ that floating A is darksom1's car
AM
heres my AM with painted grill and other stuffs.
Old Apr 24, 2009 | 09:51 PM
1fsthatch's Avatar
WOW colormatched FTW
Old Apr 24, 2009 | 10:06 PM
PROPOSED2aTL's Avatar
lovin the floating ''a''..might have to copy
Old Apr 24, 2009 | 11:42 PM
trancemission's Avatar
Regions Leader
Please do a search on the grill. There is an entire thread devoted to this.
rockyboy
Aug 4, 2024 10:35 AM
TLDude876
Dec 28, 2016 03:18 PM
drone619
Jan 26, 2016 07:09 PM
DwDrummer
5G TLX Problems & Fixes
Sep 14, 2015 08:20 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
