Is there a DIY for adjusting Emergency Break?
should be in the garage section as part of the rear brake diy
If its a floor mounted pedal- you adjust the park brake till it stops the wheel - then back the `STAR wheel` adjuster off 6 clicks
Dont know for center console ones -anyone help there?
the park brake is really a small set of drum brakes located inside the rear rotor- thats why the center hub section is so wide- contains the brake shoes and the hub is the drum for them!- pretty trick actually
The `star wheel adjuster` is at the bottem of the hub rotation- access thru rubber boot on hub
same as doing any old american car drum brake adjust
a special tool is available at parts stores or a flat screwdriver and flashlight work well
i dont recall which way is tighten, i think its down with the wheel, but its obvious in a few clicks if things are getting tighter or looser- there will be a very slight dragging feel and noise when properly adjusted
Always a good idea when doing rear brake job to remove rotor and clean-inspect and lube all the park brake parts, then do the adjustment
Especially look behind the backing plate at rubber boot into plate- if it tears open water gets in- can rust, or freeze the assembly and cause major headaches
check owner book for how many clicks of lever it should require to hold the car stopped when some throttle is applied
If you ever do need them as an emergency brake in a hydraulic fluid loss situation/event, apply partially them more and more--thinking they are small drum brakes and you dont slam on the brakes with something like that- it just locks the rear wheels--you dont slow with sliding wheels
does that get you started?
To adjust the parking brake, you need to gain access to the handbrake lever at the back of the center console (no idea how to do that). Once you've done that, here's what you do...
- Place the rear of the vehicle on jack stands
- Spin both rear tires to make sure they spin freely (if not, loosen the #5 adjuster nut till they do)
- Pull the parking brake lever up one click and leave it there
- Spin either rear wheel and check to see if the wheel still spin freely (if there is slight drag on one or both, your done)
- If no drag is felt, turn the #5 adjusting nut one notch tighter (it has a ratchet type action) & recheck
- Continue adjusting until slight drag is felt
- Put parking brake handle down and check that there is no longer any drag on either wheel
No drag w/ the handle down & slight drag with handle on 1st notch is what your looking for. It is pretty normal for one side to experience drag before the other, so don't be worried if that's the case. If your car still has trouble holding on an incline, it may be necessary to adjust the individual drum mechanism behind the brake disk on the loose wheel.
I just figured out how to access the adjuster nut.
- Open up the center console storage bin (armrest)
- Remove the #19 rubber mat from the bottom
- Remove the #20 maintenance hatch
- The adjuster nut is between the two brake cables just forward of the maintenance hatch
- Use a small ratchet and socket to make adjustments through the hatch
DIY's are in the 3G garage. this is the best place to look before searching or posting a thread.
https://acurazine.com/forums/3g-tl-2004-2008-93/brakes-caliper-o-h-pad-repl-hoses-bleed-disc-specs-park-brake-adj-3g-garage-d-041-a-578017/
Scroll a bit more than half way down.
I just followed my own step-by-step and it was very easy. Parking brake works much better now.
On the plus side I just found the spare 12v socket inside the lower armrest bin. I also found the small access hole into the upper portion of the bin to run the plug wire. Guess it's been a long time since I looked at my owners manual... lol
Here's the tools required:
- 3/8" ratchet
- 12mm deep socket
- Two hands
As you turn the adjuster nut, it will get tight just before it gets loose again. During the tight part it is necessary to hold the socket with your fingers as you turn the ratchet cause the nut wants to spring back. It's kinda hard to get your fingers in, but it works
- 3/8" ratchet
- 12mm deep socket
- Two hands
- 3/8" ratchet
- 12mm deep socket
- Two hands
- 3/8" ratchet
- 12mm deep socket
- Two hands
lanechanger
Oct 13, 2015 10:56 AM
kixo
Sep 25, 2015 03:07 PM
