Strut Brace flange nut part number
Old 09-27-2016, 09:18 AM
uneedkhoality's Avatar
Does anyone know what the part number is for the flange nut for the strut brace? I stripped one of the 6 when removing the brace to change my spark plugs. I honestly did try to search here, but to no avail. Thanks!
Attached Thumbnails Strut Brace flange nut part number-d5233d9121e099ff4190a1f9dd323a47.gif
uneedkhoality is offline
Old 09-27-2016, 09:19 AM
Received 16,260 Likes on 11,971 Posts
go to the hardware store and pick some up.
and on 12 point socket. always use 6 point sockets!
justnspace is offline
Old 09-27-2016, 09:26 AM
Received 8,582 Likes on 6,629 Posts
OEM Acura TL SEDAN 2006 FRONT LOWER ARM parts
2790361-SEP-000
NUT, FLANGE (8MM)
$0.50$0.35
thoiboi is offline
Old 09-27-2016, 09:28 AM
I thought about going to the hardware store, but thought it was some kind of special flange nut. Thanks for the advice, I did use a 12 point socket which is why it stripped the nut.
Old 09-27-2016, 09:29 AM
he knew
thoiboi is offline
justnspace (09-27-2016)
Ohh I know!!! happens to the best of us....but now that you know!!! dont make the same mistake again!
the parts that thoiboi linked say they are 8mm....umm mine are def. 12mm nuts
Old 09-27-2016, 09:30 AM
awesome, thanks thoiboi!!!
Old 09-27-2016, 09:31 AM
he knew
rounding off nuts suck
Old 09-27-2016, 09:34 AM
thoiboi is offline
Old 09-27-2016, 10:41 AM
BreezyTL's Avatar
8mm thick. Definitely a 12mm socket removes those. Pick some up at the hardware store, a nut is a nut! Mine were rusted to bad, I snapped a few studs. One way to remove it!
BreezyTL is offline
Old 09-27-2016, 10:44 AM
thanks. after I wrote it, i was like maybe i'm misinterpreting it
Old 09-27-2016, 10:46 AM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
I don't understand why they ever used 12 points...
I like OEM hardware but in a pinch, 10.9 at home depot will do.
rockstar143 is offline
Old 09-27-2016, 10:51 AM
BreezyTL's Avatar
^ you also cut your springs.... must have been in a pinch!
12-point allows you more angles to get at the nut...
BreezyTL is offline
Old 09-27-2016, 12:19 PM
you would be the guy after the most angles to get at a nut
I was left with a droopy ass and no coilovers to rectify, I did what haddabedone!
Old 09-28-2016, 02:34 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
If you buy hardware for a car at local stores, it needs to be GRADE 8 minimum! Most bolts/nuts on the car are made past GRADE 8 standards, perfect example are the bolts for the lower shocks!
Personally, I use 6 point sockets for almost everything now, 12 point can go and strip itself!
csmeance is online now
BreezyTL (09-28-2016)
Old 09-28-2016, 07:08 PM
10.9 was what I saw stamped on most suspension related bolts so I stuck with at least that!
Old 10-02-2016, 12:08 AM
eastcoastguy's Avatar
I remember seeing this thread before I tried to remove my strut bar and I still stripped 2 nuts. I did use a 12 point socket, my 6 point I needed a 3/8 to 1/4 adapter and broke that.
OP how did you get the nuts off you stripped, I wound up doing the spark plugs without removing the strut brace, wasnt too bad. Oreilys automotive didnt have the right size tool for me to get the stripped nut off, they had an 10mm and a 13mm.
eastcoastguy is offline
Old 10-02-2016, 06:29 PM
BreezyTL's Avatar
could soak them in PB blaster, pound a smaller socket on them and break them loose that way? When I was taking mine off, I stripped 2 as well. I was able to take a dremel and cut a slit in the stripped nut and was able to get a flat head in there and tap it with a hammer to spin it off.
BreezyTL is offline
Old 10-02-2016, 06:30 PM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
Originally Posted by csmeance
... Most bolts/nuts on the car are made past GRADE 8 standards, perfect example are the bolts for the lower shocks!...
I'm not sure that's necessarily the case unless there are 12.9 suspension bolts. Metric class 10.9 is essentially equivalent to Grade 8 in tensile strength (within 0.5% IRRC).
But yeah, I'd assume Grade 8 would work fine as a replacement in this case...
Large vice grips? Pound an 11mm socket onto the stripped nut??
These nuts are only supposed to be torqued to 16 ft-lbs? How the hell are people managing to strip these nuts?
nfnsquared is offline
Old 10-03-2016, 08:30 AM
BreezyTL's Avatar
i'm not sure that's necessarily the case unless there are 12.9 suspension bolts. Metric class 10.9 is essentially equivalent to grade 8 in tensile strength (within 0.5% irrc).
But yeah, i'd assume grade 8 would work fine as a replacement in this case...
rust!
BreezyTL is offline
Steven Maslauskas Jr. (12-01-2022)
Old 10-03-2016, 09:22 AM
I used a 6 point deep socket, lightly hammered it on the stripped nut and luckily was able to loosen it. My next problem was removing the nut from the socket after I got it off which required me to clamp it down and hammer it out. Messed up the socket but it can be replaced.
Old 10-03-2016, 09:25 AM
mine weren't rusted but because I used a 12 point socket and the nut was "soft"
Old 10-03-2016, 03:25 PM
Thats exactly what I said to myself, they are not that tight why the hell cant I loosen them? Mine werent rusted either but with some hammering on them the others came loose. I also had a 12 point socket, last time I use that!
Old 10-22-2018, 06:45 PM
SouthStar019's Avatar
these bolts are weak. happened to me today also. ended up getting a bolt extractor to get it off. im about to order 6 of these and replace all 6. why they used the softest metal out there on these?
SouthStar019 is offline
Old 10-22-2018, 06:47 PM
Did you use a 12 point socket?
thoiboi is offline
Old 10-22-2018, 08:56 PM
nope. don't even have them. 6 Point only here.
Old 12-01-2022, 07:33 AM
Steven Maslauskas Jr.'s Avatar
I'm trying to buy dress up bolts titanium = does anyone no the correct thread
hi I'm trying to buy dress up titanium bolts for my strut Tower bar that are titanium does anybody know the thread pitch size for a 2012 Acura TL??
Steven Maslauskas Jr. is offline
Old 12-01-2022, 07:38 AM
Strut tower bolt correct thread size for a 12 Acura TL
Looking for the correct bolt size or thread size I should say for 6 titanium bolts that hold our strut Tower bar on if anyone knows the correct thread pitch size could you please let me know it would be greatly appreciated I'm trying to buy a set right now. Thanks 😊
Old 12-01-2022, 09:08 AM
TheSauceBoss's Avatar
You're in the wrong forum, you ought to ask this in the 4g TL forum here https://acurazine.com/forums/4g-tl-2009-2014-123/
TheSauceBoss is offline
Old 12-01-2022, 09:25 AM
🤦🏻‍♂️🤦🏻‍♂️🤦🏻‍♂️🤦🏻‍♂️thanks man, EXSTREAMLY new to this site =haha if you couldn't tell LMAOOO.... thanks man appreciate the help.
Old 12-01-2022, 10:25 AM
BROlando's Avatar
Received 1,163 Likes on 874 Posts
They should be 14mm wrench size...
so M8 thread size since its JIS
Thread spacing is 1.25
So...
Its a M8x1.25mm, JIS small wrench, smooth flange nut
try bellmetric.com for zinc plated steel nuts that are made to the same as factory (OEM) standards.
They don't have Ti fasteners. For that, you'll want dressupbolts.com
Don't use stainless
and don't use fasteners with knurled/saw tooth flanges
BROlando is offline
BreezyTL (12-01-2022)
Old 12-01-2022, 11:34 AM
AZ Community Team
Legend2TL's Avatar
Received 4,023 Likes on 2,501 Posts
My oh my, 8 year old thread reboot
Legend2TL is offline
Old 12-02-2022, 10:02 AM
@BROlando is so full of it.
"it" being very accurate mechanical knowledge of things
csmeance (12-05-2022)
Jon M
11-21-2022 08:56 PM
2gTltypeS
10-09-2011 07:07 PM
DimwitRj
11-30-2009 02:08 PM
AMGala
03-03-2007 11:47 AM
dfv3.2CL-S
05-07-2002 02:26 PM
Quick Reply: Strut Brace flange nut part number
