Side Mirror Reverse Tiltdown Programmable?
Old 01-21-2012, 10:29 PM
djDANNY's Avatar
Does anyone know if the amount that the side mirrors tilt down when the car is put in reverse is programmable to a memory function? Currently, my mirrors don't tilt down far enough when I'm in reverse to see the curb in relation to my wheel. I always have to manually point it down more after it does it's automatic tilting thing. Is there a way that I can set it to go down to the level that I want every time automatically?
Old 01-21-2012, 10:38 PM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
I don't think so.
Old 01-21-2012, 10:39 PM
AZ Community Team
Bearcat94's Avatar
Received 7,770 Likes on 4,341 Posts
No.
Put it should go down all the way, I think. I don't think you should be able to use the switch thing to lower it more.
If that is correct you may have an "indexing" issue; that is the gear center is not the mirror center.
Old 01-21-2012, 11:11 PM
djDANNY's Avatar
Originally Posted by Bearcat94
No.
It seems to go only half way down (compared to how far down it could possibly go). After it stops going down on its own, if I hold the down button on the mirror adjustment switch, it'll still go down a lot more. I always feel bad holding up traffic when I'm trying to parallel park because I have to find the switch (bulbs burned out) and then manually move it down.
I know you don't really need this feature to park, but I figure I might as well be safe and not curb my rims if the car has this ability built in.
Old 01-21-2012, 11:43 PM
AZ Community Team
Bearcat94's Avatar
Are both sides the same? That is, do both sides only tip about half way down?
If the driver side is different (i.e. tips further down) then you've got some kind of problem with the right side mirror.
I'm not sure how far they go. Mine tips enough that I can see the curb/parking space lines.
Old 01-21-2012, 11:59 PM
rhafikjaan's Avatar
Dude i know exactly what you mean.. i guess its mostly depends on the driver..how he sets up the side mirrors and i do the same thing.. sometime i manually tilt it down.. but i think the best option for me and you at this point it to attach one of those tiny blind spot mirrors and have it aligned so that when it tilts you can see more of the curb from that tiny mirror.. i use to do that in my other car lol and it works fine.. and I also heard this is something the dealer can reprogram .. not sure if its true tho
Old 01-23-2012, 06:59 PM
kels_TL's Avatar
i just got my tl a month ago, and first few days I noticed mirror on passenger side go down now recently backing out of driveway it no longer moves. did I move it out to far to drop ?
Old 01-23-2012, 07:31 PM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
Set your seat lower so your mirror starting point will be lower, or raise your seat up so you can see when you're backing up...
Old 01-27-2012, 01:45 PM
08WDPTL's Avatar
That's probably because you moved the L R switch for the mirror adjustments.
I found out that if the switch is in the middle, neither of the mirrors will move down.
Set the switch to the side you want to move down and it should work.
Old 01-27-2012, 05:55 PM
GKinColo08TL's Avatar
I was wondering why sometimes my mirrors move nd sometimes they don't...but once both moved, at least I think they did. Anyone know why this might have happened?
Old 03-02-2016, 01:33 AM
4th Gear
3gTLlover's Avatar
I was wondering if you can have both mirrors tilt down when you reverse. Do you think that is possible or to have it reprogrammed?
Old 03-02-2016, 06:06 AM
-------Tim-------
Slpr04UA6's Avatar
^KPTechnologies makes a module that you can purchase to make that possible, from the factory that is not an option.
They also make a module for being able to roll all your windows/moonroof up from your keyfob. This module is around $50.
Old 03-02-2016, 06:12 AM
window roll-up is my favorite mod of all time.
The following 2 users liked this post by rockstar143:
Slpr04UA6 (03-02-2016), TL-Syndicate23 (03-04-2016)
Old 03-02-2016, 01:47 PM
4th Gear
3gTLlover's Avatar
About rolling down your windows, you can do that anyway by press and holding the unlock button on your key fob. I always had this option since I have bought the car from my parents without any modifications. Any Acura TL owners from 2004-2008 should have that option.
in regards of the Mirrors, I will take a look at KPTechnologies as you indicated to see how much will it cost.
Old 03-03-2016, 12:52 PM
He's referring to rolling the windows UP, you can't do that with your fob without the module.
Slpr04UA6 (03-04-2016)
Old 03-04-2016, 07:42 AM
TL-Syndicate23's Avatar
I just bought a Mirror Tilt module from KP Tech myself. Since we already have the option to control one mirror I was told that we can wire up the other to do the same with one module as I see they sell a deluxe kit that comes with 2 modules per say. I think it would involve tapping into the mirror itself and running the wires to both the stock module under the dash along with the KP module. Thinking of just leaving the factory switch selected on the passenger mirror and wiring the drivers side to the module. Plan on doing it this weekend so I'll let you know how it goes.
Old 03-04-2016, 07:28 PM
sockr1's Avatar
Received 1,158 Likes on 909 Posts
Following to see the dual mirror thing installed. Please take pics during the install!!
Old 03-08-2016, 07:41 AM
Didn't get a chance to do so last weekend but I will include photos of the install once I get to it. Hopefully this weekend! Keep you all posted!
Old 09-21-2020, 09:54 PM
GUN-M-TL's Avatar
Mirror Tilt in reverse
  • The amount of tilt is not programmable that I know of. One solution is to add a small fish eye blind spot mirror to the outside edge of your passenger mirror. The combination of the partial tilt your getting and the use of this mirror will allow you to see the curb by your rear wheel when parking.
rockyboy
12-06-2022 02:29 PM
Type S Zero
02-17-2016 02:37 PM
sockr1
10-01-2015 01:31 AM
hand123
09-10-2015 09:27 AM
Quick Reply: Side Mirror Reverse Tiltdown Programmable?
