Notices
Third Generation TL (2004-2008)
Side Markers for 2007 Type S
Old 04-09-2019, 07:14 PM
Registered Member
Liked 0 Times in 0 Posts
I've looked all over for the last 3 days. Needing a drivers side REAR side marker. Found plenty on ebay and amazon, but for base TL's. And yes (as it appears) the Type S connector will NOT fit a base TL side marker. The Type S has a wider connector. Dealer wants $105 for the OEM part, it's looking like my only option unless someone can help. I went to a pick and pull here in my hometown that had a 2007 base TL, and grabbed both rear side markers (red vs smoke) and they will not match up, not that I would of used the red ones anyway but I was curious if Acura really made the Type S side markers a different "size" connection wise....which they did. Anyone have an idea/info?
jeffstlnote is offline
Old 04-09-2019, 07:38 PM
-------Tim-------
Slpr04UA6's Avatar
Liked 485 Times in 418 Posts
It’s been a long time since installation. But I installed the type-s side markers on my base. I don’t recall it being to hard. And I didn’t have to change anything (clip or wiring wise).
Slpr04UA6 is offline
Old 04-09-2019, 07:40 PM
Liked 5,791 Times in 4,643 Posts
https://www.oemacuraparts.com/v-2007...-license-light
a little cheaper here at 73
and with the proper part code above, i was able to find some on ebay for 45: https://www.ebay.com/itm/Acura-TL-Ty...-/332842875135
thoiboi is offline
The following users liked this post: thoiboi
justnspace (04-09-2019)
Old 04-10-2019, 05:38 PM
Registered Member
Thank you so much! The one on Ebay would be perfect if only it was for the drivers side rear versus the passenger rear. Looks like my best option may be the other link you posted., Thanks again, if anyone has any other suggestions holler at me!
Old 04-10-2019, 07:22 PM
https://acurazine.com/forums/market/
put a Want to Buy (WTB) ad up here and hope someone is selling theirs!
or alternatively, buy the base ones and mod the connector.
Or check a local junkyard
or even Search Results
I just typed in 2007-2008 TL and chose the Rear sidemarker
It doesn't let me post the exact link so you'll have to re-do the search yourself. Hope that helps!
thoiboi is offline
stp2585
09-11-2011 09:01 PM
meowevil
05-15-2011 10:13 PM
Butler230
11-17-2010 11:37 PM
monkeyquach
10-13-2009 06:02 PM
jptl04
3G TL Photograph Gallery
46
11-10-2006 10:53 PM
Quick Reply: Side Markers for 2007 Type S
