Shut Off the Auto-Mirror Adjust Feature in Reverse
Miss my 89 Legend
Does anybody know how to shut off the automatic feature that adjusts the driver side mirror down when you put the car in reverse? I have a 6MT so is this just a feature for 6MT..
When I first got my car like 2 weeks ago now, I noticed this feature, and I am really worried about this freezing in the winter and I would like to be able to shut it off.
Originally Posted by vclune
There is a switch on the left side of the dash that says mirrors L or R. Just move the switch to the middle. Didn't yours come with a manual?
Miss my 89 Legend
Well for you smart allecks.. Last time I checked I was still on the navigation book.. http://www.acura-tl.com/forums/newre...te=1&p=937813#
Hi
I would also like to completely turn off the automatic feature that adjusts L&R mirrors.
When I move the L/R mirror adjustment switch in the center, mirrors will stop moving, but every once in a while the left mirror will start making noises and move down on its own. I am guessing the motor inside is going bad?
Is there a way to turn this automatic feature off with an OBD2 scanner or by unplugging the correct fuse?
Or should I just replace the motor inside the left mirror?
Check to see if the mirror is centered up & down . If its been knocked off of center it can be at the end of its travel and trying to return to the driver preset position.
navtool.com
31
11-16-2015 08:30 PM
