"Service due soon A"
What does it mean?
What does the service entail?
How much will it run $$$ (car is under warranty if it matters)?
TIA.
TIA.
![Cheers](https://acurazine.com/forums/images/smilies/cheers.gif)
https://techinfo.honda.com/rjanisis/...404O00194B.pdf
"A"= oil change. If you don't like changing your own, shouldn't be more than $40- tops.
Also is there a list here somewhere w/ all the service codes?
07 tl-s in
Originally Posted by ..Mark..
Thanks. Once i change it how do i reset the light?
AZ Community Team
Received 7,770 Likes
..Mark.. , Here's a link to Owners Manuals in case you don't have one.
https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
Services for each code are listed in the Maint section.
You can also set up an Acura Owner Link account and Maint Services are listed there as well.
https://www.ahm-ownerlink.com/login.asp?brand=acura
Mark,
Note that the service item (A) will also be accompanied by a number, which is another maintenance item. So 'A1' will be oil change + tire rotation. See manual posted by ggesq.
Keep Right Except to Pass
Originally Posted by pokin
Mark,
Yes, I know this thread is ancient, but I didn't feel the need to start another. My display is saying "Service Due Soon A" and holding reset for 10 seconds does not get rid of the notice. After holding the reset button for 5 seconds or so, it progresses to the next screen and the "i" indicator is still lit. How does one reset the reminder on a 2008 MDX?
