replacing motor mounts on 2007 TL
My 2007 Base TL needs motor/trans mounts replaced. 139K and looking to keep car another 3 yrs, 25k. Looking to use after market, like this site https://www.am-autoparts.com/product...335580227.html. Site says they are a fit, Part #s similar, but look to be Honda #s instead of Acura #s. Any advice?
Do not get them. They will fail again very soon and you will need to replace them. You have to go OEM or get Innovative Mounts (They are solid mounts and car will vibrate a lot more than stock).
truonghthe (01-20-2019)
Latent car nut
Received 2,005 Likes
get a rebuilt kit and DIY, its very simple and Rockstar has DIY thread on it. The final bill wooping $36 and 90 mins of your time (1st time).
Mr. Detail
I would go OEM on the mounts except the passenger side mount, go with the urethane Innovative mount. If there was in increase in vibration, I can't tell and it should help the front mount last longer.
Coming to a city near you
Just had my lower control arms changed and they found out my passenger side mount failed again (240k miles ) But the bolt hole is stripped will need to be helicoiled. The shop will do it for $600 with a new mount. I don't want to try doing the helicoil myself, worried I will mess it up and then really be screwed.
$600 for a mount and helicoil seems steep. You could buy a new engine mount bracket, mount and bolt(s) for way under 6 hundo.
https://www.acuraoemparts.com/auto-p...nts-at-06-scat
08smr6mt (06-16-2019)
I just swapped ours to the innovative mounts. They pretty much replaced all the stock mounting points. If you need one you can have it. It came off a 09 V6 Accord 6 speed. I believe they are the same for the pass side.
Algavin (06-18-2019)
boxmanryan
01-12-2015 09:15 AM
NighthawkBlue
10-24-2012 02:39 AM
luxerymobile
03-29-2011 12:48 PM
