Replacing button lamps/bulbs
I've got a number of buttons that no longer illuminate and am ready to replace them. I decided against going with LEDs because that would mean replacing everything for a consistent appearance. I need to replace the bulbs for the following and already have them on-hand:
The process that I'm worried about the most, which is also the most important, is the nav unit. I also can't figure out how to remove the little HFL steering wheel "pod". I hope I don't have to pull apart the entire steering wheel.
- Trunk release button
- VSA switch
- HFL end call/command (both bottom buttons)
- Hazard switch
- Almost every button surround the nav display (these went out when I replaced the cup holder)
Have you looking the Garage? Tons of great info there.
https://acurazine.com/forums/third-g...-first-553557/
jaysizzlecity
2G CL Problems & Fixes
06-23-2008 10:55 AM
2CLean
08-20-2007 04:17 PM
UglyPsycho
11-20-2006 07:11 PM
