Rear view mirror on a 2004 TL
Old 11-01-2017, 08:47 PM
Joecop67's Avatar
Forgive me if this is posted in the wrong place. My rear view mirror seems to have a darker tint to it than other rear view mirror I'm used to. Mainly my 2013 Camry and my 2008 civic.
Is this normal? It seems slightly grey or greenish.
Old 11-02-2017, 12:40 AM
Superunknown's Avatar
Make sure the auto dimmer is off. There's a button on the bottom of the mirror.
Old 11-02-2017, 04:22 AM
Joecop67's Avatar
I tried that. Makes no difference if it's on or off. The best way to describe it, it looks tinted. I may try to take a picture of it.
Old 11-02-2017, 08:57 AM
Jackass's Avatar
It is not as "clear" as a manual mirror. It will have a slight tint to it. The real question is if the auto-dim is still working or not...
Old 11-02-2017, 09:27 AM
Joecop67's Avatar
I don’t know if the dimming works or not.
So auto-dimming mirrors are not as “clear” as regular ones? I’ve never had an auto-dimming mirror.
Mia there a part number for a regular one? Lol
Old 11-02-2017, 09:30 AM
Received 16,260 Likes on 11,971 Posts
take a flash light to the front of the sensor. the mirror will automatically darken.
I love mine, since trucks like to be lifted and have all kinds of front lights, all I have to do is hit the switch and the mirror will darken
Old 11-02-2017, 09:55 AM
Received 8,568 Likes on 6,621 Posts
Sounds normal
Old 11-02-2017, 10:32 AM
Joecop67's Avatar
I had tried with an led flashlight. I saw no change.
Old 11-02-2017, 10:33 AM
Is the green light on?
Old 11-02-2017, 10:44 AM
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
I wouldn't say it's a common problem but these auto dimming mirrors do get stuck regardless if the button is pushed.
My rear view mirror is stuck with a bluish tint when it used to be clear as a mirror without auto dimming.
Joecop67's Avatar
Yes.
Old 11-02-2017, 10:46 AM
Joecop67's Avatar
So, you are saying it could be stuck on dimming?
Anyway to get it unstuck?
Old 11-02-2017, 10:49 AM
Joecop67's Avatar
I’m meeting someone near me on Saturday with a 2008 tl they are parting out.
Would the mirror from the 08 work on my 04?
Also would the fog lights in the number of the 08 work on mine? Should I start a different thread for that?
Old 11-02-2017, 10:51 AM
Joecop67's Avatar
According to an online site, the mirror from an 08 should work.
justnspace (11-02-2017)
Old 11-02-2017, 10:59 AM
yes, just pop off mirrors along with electrical connection; then re-install the same way
Old 11-02-2017, 12:51 PM
There's no way I know of to get it unstuck.
Many Acuras share the same rear view mirror - they should all work as long as it looks the same.
I too am experiencing the same problem - back in 2010 and 2011 it's VERY noticeable when you hit the button on and off. You'd be blind to miss it working.
it hasn't bothered me that much, but I'm mainly a chicken to change out the mirror and not crack the windshield.
You could just browse eBay for Acura TL rear view mirrors and notice that a few of the listings have the stuck blue tint.
It should look like this though:
Old 11-02-2017, 01:14 PM
I just reread your original post, if your rear view mirror is a slightly darker grey/green that sounds normal.
Old 11-02-2017, 02:32 PM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
What is dimming mirror? I can't recall using it at all since my back window is 5%....
Old 11-02-2017, 02:35 PM
I'm not cool enough to go 5%...
Old 11-02-2017, 03:02 PM
Joecop67's Avatar
Old 11-05-2017, 01:24 PM
Joecop67's Avatar
I replaced the mirror. The one on the right is my defective one.
Old 11-05-2017, 01:56 PM
Wow, that's a huge difference!
Was it easy to replace?
Old 11-05-2017, 03:03 PM
Joecop67's Avatar
Yes, it was. I followed the directions posted for removing the hfl, unplugged it. Then I took off the bottom cap.
I used a flat screwdriver on the top edge of the mirror and a rubber mallet to gently tap down parallel with the windshield. Carefull because the mirror will suddenly fall off.
To install it, use the screwdriver and hammer from the bottom to get it all the way on.
guitarplayer16 (11-05-2017)
MomsMdX
1/2G MDX (2001-2013)
11-01-2017 02:41 PM
jameswesss
10-30-2017 08:17 AM
evgu-tl
10-26-2017 02:11 PM
mana1015
09-25-2017 04:32 PM
Jacques226
08-15-2017 06:15 AM
Quick Reply: Rear view mirror on a 2004 TL
