rear tunk lid spoiler removal?
so i took my spoiler to Wilburn to have it painted....looks good, i had them put it on but im not 100% satisfied with it....whats the best way to remove the spoiler so i can put it on?
is it screwed on or taped on? if screwed on, remove bolts then use dental floss to remove the double sided taped. if only taped on, use only dental floss to remove double sided tape.
yes, its taped on only...the hard part is going to be removing the tape from both the trunk and spoiler....it was installed yesterday so it may not be 'set' yet....i hope. whats the best method to removing the residue (Goo Gone isnt THAT great)
Read this thread. Should be able to help you. Good Luck.
https://acurazine.com/forums/showthr...moving+spoiler
I got the Shifts
well goo gone isnt that great, but i did use it to get the large peices of residue off and then i used rubbing compound by turtle wax to remove the finer outline when i debadged, gave it a wax afterwards and its like the glue was never even there.
(floss helps ALOT!)
(floss helps ALOT!)
i was able to pull it off with a little force (i think they used poster strength tape). now, i need a template and some kick ass two sided tape and MAYBE a sealant, what do you guys thing/suggest?
ahh thanks for the response!
Originally Posted by mark602
I would offer you the template, but it wouldn't help. It is for a OEM 07-08 spoiler. The OEM had 2 bolts.
oyayjoe
09-12-2015 04:40 PM
09-04-2015 08:03 AM
