Ran straight over deer carcass at 65 mph
So I was traveling home last night and the car immediately in front of me swerves away, and right in front of me with no time to react is a deer carcass. My only instinct is to straddle it between the tires. BOOM. I didn't feel anything but it was definitely a fairly loud impact. I was able to drive home (another 20 minutes) no issues whatsoever, but this morning I see giant clumps of hair in two locations under the car, one on a pipe near the front two wheels, another giant clump toward the rear of the vehicle. I took it to local car cash and it isn't coming out.
What possible damage could have been done? I've got a firestone appointment today at 5pm for a 'vehicle inspection', but so far everything seems...ok?... Thanks for any advice. |
poor dear :sad:
*deer
It's unlikely that any damage occurred, other than to your bumper or plastic coverings underneath the car. Running over medians or curbs can definitely jack up undercarriage components but something "soft" like a deer isn't likely to cause damage to metal parts under the car. Let Firestone know what happened and they can take a look. Otherwise, just keep an eye out for leaking fluids. If anything, it could have damaged the radiator but I think even that's unlikely since the radiator is protected by a chassis beam. It could have also caused damage to the brake lines but you'd know pretty quick if that were the case. |
hurry and wash it off! it's already like 100 degrees here in texas, wouldnt want that stuff to stink!!!!!!!
Originally Posted by losiglow
(Post 16434942)
*deer
It's unlikely that any damage occurred, other than to your bumper or plastic coverings underneath the car. Running over medians or curbs can definitely jack up undercarriage components but something "soft" like a deer isn't likely to cause damage to metal parts under the car. Let Firestone know what happened and they can take a look. Otherwise, just keep an eye out for leaking fluids. If anything, it could have damaged the radiator but I think even that's unlikely since the radiator is protected by a chassis beam. It could have also caused damage to the brake lines but you'd know pretty quick if that were the case. Anyway, thansk for your insight. I thought I was seriously screwed when I first hit it, so glad to know there's a chance of no real damage. |
Following too closely. Lesson learned, hopefully.
(Post 16434978)
Inspection appointment at Firestone :spit:
And I was feeling sorry for the deer. |
Originally Posted by Majofo
(Post 16435036)
If it would put your mind at ease then go for it. It's certainly possible that a chunk of flesh (gross, I know) could have gotten wedged somewhere or that something like an exhaust heat shield got bent which might result in some rattling later on. But it's pretty unlikely that anything critical was damaged.
(Post 16435036)
Originally Posted by RedsTL
(Post 16435054)
I dunno I just want someone to be able to see under the car. Maybe not necessary....
Firestone report: Cracked subframe Bent wheels (x4) Clogged catalytic converter Bent exhaust pipe Tire tread 1/8 Brake pads FxR 0.5mm Bottom end clean Top end clean Cracked Radiator Cracked Oil Pan Damaged splashguards Damaged intake Torn compliance bushings Leaky struts x2 Torn Accessory Belt Spark Plugs (mando carb compliance) Poor alternator efficiency Poor starter crank Etc. Total Est: $7020.30 |
:rofl:
(Post 16435054)
your eyes stopped working? Just jack it up and take a look see.. hell even take a pic and post it here |
(Post 16435120)
:squint:
your eyes stopped working? Just jack it up and take a look see.. hell even take a pic and post it here OP, not saying some peace of mind isn't warranted. I personally think you're fine. But a well reviewed honest indy shop would be a safe bet. |
I'd cancel the appt with Firestone and let Road Kill
Cafe know you got the goods. |
Shoulda driven about 5 miles and then stopped, reached under the car, and grabbed ya a hunk o' cooked venison. Yummmm!!!!
Slam your car, that way it'll just push it over instead of driving over the deer....
Yup NEVER follow too closely. A few years ago a woman was riding my ass, I mean I couldn't even see her front plate. This continued for miles & miles. Up ahead in my lane there were 2 garbage cans that had blown into the roadway. So I decided to let her know the consequences of tailgating, but I first made sure there were no vehicles coming the opposite way, we were on a quiet road and non residential. As I approached I then suddenly swerved to avoid hitting them, but she couldn't because she was riding my ass, KABOOMM!!! and as I glanced in my rear view I laughed and laughed and continued onward. I actually saw her front spoiler break off into chunks.
^it's worse on the freeway...someone will be huggin me, and because I leave space, I can change lanes at will. right around slowing traffic, I see them in the rear view mirror having to slam on their brakes to avoid pile up
Assholes.
(Post 16435481)
Assholes.
It's better to drive like a boss... Be smart, not granny...
Watch for any brakelights in front of you... So on... Change lanes and overtake when possible (safe)... :D |
Also, if an animal like a deer, rabbit or raccoon runs out in front of you, brake gently and gently aim the vehicle toward where the animal came out from...
AKA "point for the tail"... Living in rural Mississippi for two years, this saved me atleast a dozen accidents.... Just don't jerk the wheel like you're on a slalom, do it gently, like changing lanes or something, it's all you'll need... Also, train your eyes for seeing eyes off to the sides of the road, it gives you more time to anticipate what may happen... |
(Post 16435618)
That's if one runs out next time...
(Post 16435618)
AKA "point for the tail"... |
Wow. That car took that tree out like a boss.
(Post 16435621)
So what happens when it's a carcass aka ALREADY DEAD :doh: :poke:
Simple logic.. jeez |
(Post 16435618)
…AKA "point for the tail"
WAIT - Who told you about my failed "first date" strategy and why are you bringing it up here…!? |
A few years ago I nailed a road gator and took on nearly a grand in paint damage to the bumper and door sill... But the person tailgating me got it laid across their hood after my tires ejected it into the air.
That tree didn't stand a chance.
Originally Posted by ProfessorFunk
(Post 16436393)
Works for me |
Originally Posted by Superunknown
(Post 16436453)
I'm from NOLA, and this would happen regularly in the outter areas, beyond city limits... It's rough too... Like hitting a log... Someone died on I-10 in the East a few years ago after their cargo van hit a large alligator and turned over, then was rear ended by a following car... I also know someone who hit one on highway 61, too... Superunkown? Hell yes! :rockon: |
