Rack and Pinion Overhaul
Old 01-27-2019, 04:14 PM
ifeliciano's Avatar
I order the seal kit (06531-SDA-A02) to replace the main cylinder seals as I has a leak on the drivers side of the R&P.
The kit had 10 parts. L/R seals, some lock washers for the tie-rod ends, etc... Two of the parts were o-rings. One o-ring, the larger is for the base of the valve housing,
but for the life of me, I can't figure out where the other o-ring goes. Im thinking somewhere withing the valve body, but I didn't take the valve apart as it looks good,
and would need special tools to put back together. Anyhow, back to the o-rings.
Any of you who have overhauled your R&P know where the smaller 35.5mmx2 o-ring goes? I'm thinking its possible the smaller o-ring is for a different Acura/Honda model R&P.
Thoughts?
briancl
08-08-2008 07:57 PM
BigHoop65
1G TL (1996-1998)
04-09-2006 07:32 PM
$peed])emon
10-24-2005 06:14 PM
jstenuf
10-04-2001 09:44 PM
Quick Reply: Rack and Pinion Overhaul
