Question on taking off timing belt
#41
You're all over the place.. again.
Simple stuff like removing side engine mount.
Why in the world would anyone do a timing belt job
then plan to remove it again to replace the camshaft.
Are you basing lobe damage by ticking noise?
If you actually have damaged lobes, that could be much more important to address.
#42
The overall J series engine design hasn't changed in 20 years. All the mounting locations are the same for each Honda/Acura V6 since 98'.
So yea, it's pretty damn easy to say the least. I know your inexperienced but like I said earlier, take your time & do yourself a favour, pick up a service manual or at least sign up on Alldatadiy.com. Best 20 bucks you'll spend.
#44
Yup that is front camshaft. I have been driving like that for more than 2.5 years and I don’t have misfired or performance issues other than ticking engine noise. I will have to replace it at some point.
#45
That's bad pitting, but how are you getting this picture without removing the cam? That's not typical wear at all. My guess would be defect during process or install. You either replace with timing belt job or not at all. Might as well replace and do valve job while you're in there.
#47
#48
#49
Removing the valve covers is really easy
#50
I still don't understand how you got that pic
the rockers sit right over the cam
#51
Well, we may now have a clue as to the cause of the camshaft wear.....
#52
#53
Other than the pitting, the head looks good. That's a serious defect.
Even if the flake caused negligible damage, I'd report to Acura.
That should be covered IMO considering the age, miles?
If not the fight worth fighting over..
I'd pull the head off, do a full valve and cylinder inspection.
Replace cam and whatever looks worse for wear. Definitely new head gasket.
#54
You'll have to forgive Majofo. He's still coming down off the bath salts following his naked ATV ride. Majofo, wtf were you doing in Missouri anyhow?
Naked man on ATV leads Missouri police on wild, hour-long chase | Fox News
#55
Emphasis on long
Standard Tuesday night here
Justn was taking video
#56
^^^^ I knew Crabman was implicated in this event somehow
#59
I don't think the head will mate.
The header of an 07 is different from an 04 TL.
Code stamp on a head is the last two digits on the engine code.
If it don't match, it's not worth the trouble of finding out.
#60
Not only that, but we're talking a J32 vs J35
#61
#63
Well what the hell do I know, nothing
#65
Back to my popcorn
#66
It is a j37 series. I just bought the camshaft and I read the FSM on how to remove and install it. It is pretty straight forward. There is no need to remove the block. Just remove intake, the cylinder cover, rocker arm assembly, timing belt, camshaft pulley, batter, EGR....and slide out the camshaft. But it lots of removing parts.
#68
MDX you say... Should move it to that subforum me thinks?
#71
#72
Parts are here and PARTY TIME!!
Time to tear down and let’s PARTY!!
replacing front camshaft, timing belt, water pump, remove oil pump!!
Parts
New camshaft. What is the slot with the green arrow for?
Parts
#75
Latent car nut
Received 2,005 Likes
Wow, I've seen cam spalling on some Honda 4-Cylinder engines; I've never seen it on one of the J-Series motors, that looks really bad. Hopefully you bought new cam followers as well.
#80
what is a cam followers? You mean the rocker arm riding on that lobe? I just bought a a front camshaft only.
