Power steering fluids?
I searched but didn't find solid answers.
can someone tell me if I should use honda only fluid?
Is there a quality fluid on the shelf at a parts store anyone might recommend?
tia
tia
BANNED
i like the amsoil PSF.
Use either Honda or Amsoil. Honda is thicker than most others and uses more zinc. Amsoil is a much better fluid, will hold up better and steering will be lighter when it's cold.
I haven't found an off the shelf fluid I would use other than OEM.
Majofo (02-29-2012)
takin care of Business in
Received 4,732 Likes
^^^ I concur....thow i have experience with only Honda PSF, I will be trying the Amsoil this go around...
^^^ you just need 2 bottles TOPSSS
AZ Community Team
Received 7,770 Likes
I bought a new reservoir and want to try to get out as much as possible. there has been bubbles in there for a while- I was told and it was explained to me as an oxidation issue with current oil?
Prestone has honda fluid at wally world, I wonder if its decent, at least for just a flush..
My other half swears by his amsoil transmission fluid in his GTO and Camaro, I don't want to risk it.
Maybe the time has come for a new car.
Use OEM, I had a bad experience using an after market fluid (had to replace rack & pinion assy).
Rather than flush just do a change fluid, 2 bottles,
then do another change 2 weeks or so later using 2
more bottles.
more bottles.
I would listen to your other half, sounds like good advice on the Amsoil. I've run it in the trans or power steering for nearly 100,000 miles.
my work here is done
Amsoil.
Tia, How you doin?
Tia, How you doin?
Learned the lesson the hard way, only OEM Honda PS fluid in my Acuras & Hondas.
BANNED
^unless it's safe for hondas/acuras...like amsoil is.
sounds like somebody didn't do their homework.
BANNED
^yeah I've never heard of asmoil either.
Majofo (03-01-2012)
for some reason i like kingkong_dav....he can get under people's skin without saying much LOL....
as mentioned above....i would ONLY go with recommended fluids:
Honda/Acura stuff: Recommended by Honda/Acura
Amsoil: Recommended by many members on the forum
BANNED
^you take it back swoosh!
swoosh (02-29-2012)
we are still friends right Aaron ???
BANNED
^yeah if you get my ECU shipped tomorrow
lemme see what i can do
SharksBreath (02-29-2012)
Well, guess I'll pick it up from the dealer. Thanks guys.
The car went to the dealer a while back for a power steering recall, I dont know if the seal was replaced? It was ordered and will be put in when he does it. I dread going to the dealer, cerritos acura sucks in many ways.
mike from annapolis
05-07-2017 08:21 PM
