Powdercoat or paint brembos?
Old 05-27-2014, 12:19 PM
skd2k1's Avatar
I've heard mixed opinions on this, what do folks around here think? what are the pros/cons of each? which is more durable? etc.
thanks for the input!
Old 05-27-2014, 12:34 PM
bouncer07's Avatar
Think that answers it.
Old 05-27-2014, 12:52 PM
skd2k1's Avatar
no, it doesn't. thanks.
Old 05-27-2014, 01:33 PM
KJ TL-S's Avatar
Almost everyone seems to paint em, and I never really hear about any issues from those who have.
skd2k1 (05-27-2014)
Old 05-27-2014, 01:40 PM
Received 16,260 Likes on 11,971 Posts
powder coating involves heat.
this means; you'll have to disassemble the brembo brakes to take off all the things that cant stand up to 400 degrees.
I believe that's how hot the powder coating process gets.
then you have to re-assemble the caliper.
so, lots of time, effort and money goes into powder coating.
and if you dont do it right, ie: if the seals get busted from the heat....you'll just have a cool Brembo branded paper weight
painting the calipers with a kit or a spray can is less expensive and way less time involved.
skd2k1 (05-27-2014)
Old 05-27-2014, 01:44 PM
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
There's nothing wrong with painting, no good reason to powdercoat. Yes powdercoat is stronger but for brakes it's not needed, since nothing ever touches your calipers. Just get a good paint job done on it and it'll be fine. Factory big brake kits are always painted, not just for the TL brembos but also other car manufacturers too
skd2k1 (05-27-2014)
Old 05-27-2014, 01:48 PM
skd2k1's Avatar
don't brakes normally get hotter than 400 degrees?
Old 05-27-2014, 01:51 PM
^no, they get hot but not where it destroys the seals.
powder coating will destroy the seals if not taken apart properly.
you can find brembo rebuild kits on the internet. comes with new seals and stuffs
Old 05-27-2014, 02:03 PM
skd2k1's Avatar
gotcha, not sure if you'll know, but is a brembo rebuild something that ought to be done as maintenance at some point?
fyi, the factory paint on both of my brembos is starting to chip, so I'm wanting to avoid that in future if I repaint which is why I thought about powdercoating.
Old 05-27-2014, 02:12 PM
not under general circumstances and will last the lifetime of the car.
but under certain circumstances, there might, key word Might be a need to rebuild.
like for example, the powder coating will need a rebuild.
I also remember a thread where a member accidentally took apart the seals thinking he was going to clean them.
skd2k1 (05-27-2014)
Old 05-27-2014, 02:13 PM
maharajamd's Avatar
Received 1,544 Likes on 1,197 Posts
- Sand, clean, prime, sand, base, clear, clear, clear.
- At the very least use high temp primer and clear.
- Unless you have issues with your brembos they don't need rebuilt.
- To avoid this in the future don't let brake fluid touch them.
skd2k1 (05-27-2014)
Old 05-27-2014, 04:00 PM
Security Dude
Sbarbee54's Avatar
My buddy and I made a powder coating oven in his garage to do quad, dirt bike frames, and the occasional axle or 50 on 4X4. I can tell you first hand it will cook the heck out of the seals in that caliper. Paint it, yes powder coating is allot more durable, but unless you are sloppy at bleeding breaks or spraying harsh chemicals on your tires, a good paint job will be fine.
skd2k1 (05-27-2014)
Old 05-27-2014, 04:19 PM
☆New England Patriots☆
tl-frank's Avatar
Ive painted calipers on my civic before just use a good base paint clear and make sure you do all the prep so it can come out clean. ..besides that ive had no issues on painting my calipers. ..think about iy its really cheap and easy to do if you dont like it you can go the powder coat way
skd2k1 (05-27-2014)
Old 05-27-2014, 04:25 PM
tl-frank's Avatar
Double post
Old 05-27-2014, 04:45 PM
tl-frank's Avatar
Check this site out
http://www.andysautosport.com/calipe.../acura_tl.html
Old 05-27-2014, 08:50 PM
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
If you can paint them, do that.
Old 05-27-2014, 09:11 PM
skd2k1's Avatar
Originally Posted by tl-frank
thanks dude!
yeah, I'm thinking I'll just 'em. good advice pal.
Old 05-30-2014, 07:19 PM
Turbocoop's Avatar
I painted mine last November and they still look exactly the same as the day I painted em (except one tiny chip from the wheel hitting one). If you do it right it will last. Sand, prime, paint, clear, clear, clear, clear.
The following 2 users liked this post by Turbocoop:
justnspace (05-30-2014), skd2k1 (05-30-2014)
Old 05-30-2014, 07:54 PM
skd2k1's Avatar
^that looks awesome! great job and color choice.
any special technique to painting with clear? did you use high temp brembo stickers or the brembo logo painted?
Old 05-30-2014, 08:46 PM
lowrd on tein CS biatch
CL-S progression 01's Avatar
I would just buy g2 two part epoxy paint off ebay and your done with it for like 50 and no headaches... It's lasted 3 brutal winters so far for me.
That VHF spray paint crap just cracks off over time... Now I did not do clear over it like u did above but it should tell u to do so in the instructions then. After two applications a year apart the calipers both had flaking.. The clear is what is bonding the paint together and making it hard enough not to fall off.
That's when I researched and found g2 is the only two part epoxy caliper paint I could get my hands on.... Why is it amazing? It's two part.. It comes with a catalyst that hardens the paint after u have applied it... So you have an hour to apply it or so... So. You may wanna mix half. The mix the other half to buy yourself some time. U can get the whole car done in a day and be driving the next... That's fast for painting calipers.
But that VHT stuff I was super disappointed in... Looked amazing for a few months but that's it. And the drying time was brutal. Sorry
skd2k1 (05-31-2014)
Old 05-31-2014, 08:33 AM
Turbocoop's Avatar
It was actually a 2 step paint- the only high temp blue color I could find was the stupid light blue "ford" color, and I wanted it darker- what I did was sand and prime it with high temp engine enamel primer, then put a couple coats of the "ford" blue on, after it dried I painted em with some semi-transparent VHT "anodized look" blue paint. Its supposed to be used on polished metal or chrome, but it came out good on the blue, made it dark enough for my liking...
after that dried I put on the brembo stickers (regular ebay stickers), then about 4-5 coats of clear high temp engine enamel paint.
skd2k1 (05-31-2014)
Old 05-31-2014, 11:48 AM
skd2k1's Avatar
^great info, thanks guys!
Old 05-31-2014, 05:15 PM
G2 has the dark blue and the baby blue ford color.. They have your basics bright colors and then 6 or so custom ones.
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
polish_pat
09-30-2015 12:22 PM
2ManyHobbies
09-24-2015 09:23 PM
Quick Reply: Powdercoat or paint brembos?
