Playing around with Plastidip Colors
Old 10-25-2012, 08:56 AM
  #121
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
Old 10-25-2012, 12:18 PM
  #122
Starcraft II addict
Buda's Avatar
Originally Posted by swoosh
looks fucking great Sean....cant wait to see your car in person....
Wow, awesome video, Sean!
Thanks guys!
Originally Posted by McCollins23
Sean are you this much closer to doing the big mod now? I have a beater car you can practice on
Unfortunately the big mod is not happening this year. I have a friend with stage 4 cancer that needed help with paying some bills so my money went there instead of towards the mod.
Old 10-25-2012, 12:24 PM
  #123
swoosh's Avatar
Good luck to your friend bro....Hope he fights the cancer off !!!
Old 10-25-2012, 02:21 PM
  #124
Chapter Leader (Midwest Region)
McCollins23's Avatar
Sean, you are a Class Act!
Hope everything is good in the long run!
Old 10-25-2012, 09:24 PM
  #125
Everyday I'm rofling
opboarding's Avatar
Received 1,788 Likes on 1,103 Posts
Great videos man. I am seriously considering getting some clear enamel this weekend to make my wheels and grille glossy.
Old 11-11-2012, 08:43 PM
  #126
Starcraft II addict
Buda's Avatar
Hey all, I got my wheels done. There are more pics in my thread here: https://acurazine.com/forums/showthr...6#post14155596
Old 11-12-2012, 12:10 PM
  #127
swoosh's Avatar
Good great Sean....cant wait to see it in person....
how you feeling now?
Old 11-12-2012, 01:08 PM
  #128
Starcraft II addict
Buda's Avatar
Thanks Anil, I'm feeling better. The pneumonia really knocked me on my ass. I'm working one more day from home and then I'll be back in the office tomorrow.
Old 11-12-2012, 01:24 PM
  #129
swoosh's Avatar
Perfect....so will get to see your car tomorrow....
you need to add some blue in your headlights
Old 11-12-2012, 02:19 PM
  #130
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
Looks beautiful, Sean. I'm glad you're feeling better. I like Anil's idea about blue in the headlights-maybe the rings!
Let's open those babies up!!!!!
Old 11-12-2012, 03:18 PM
  #131
Starcraft II addict
Buda's Avatar
While blue would be cool to add in the headlights I'm not sure I want to open them up yet again. I'd rather find a different set to work with and start from scratch.
Old 11-13-2012, 10:05 AM
  #132
swoosh's Avatar
wanna switch
Old 11-27-2012, 09:12 PM
  #133
Starcraft II addict
Buda's Avatar
Ran into a slight problem on finishing up the wet sanding test on the Rust-Oleum. Let's just say it didn't like having painters tape on it.
I did go ahead and do the peel test on the aluminum piece I've been working with. The results are quite interesting.
http://youtu.be/UHOnmS98SOA
Old 11-28-2012, 12:47 AM
  #134
A SiQ TL's Avatar
The problem with peeling the top Rustoleum area might be due to the Goo Gone and Xylene that you used on it.
Old 11-28-2012, 10:18 AM
  #135
Engineer in Training
LockDots's Avatar
or if it wasn't fully cured. Rustoleum although it may feel dry to the touch takes a long time to cure.
OP, did you use a heatgun on the rustoleum painted portion? If not, how long did you wait after painting before you applied tape to it?
Old 11-28-2012, 02:05 PM
  #136
Starcraft II addict
Buda's Avatar
I only used the products on the center portion to test it and not the entire area of the enamel. They did not impact the peel test as I never even made it to the area I used the product on. Also I didn't let the product set on there as I was rubbing it in to get the adhesive off. When it wasn't working I rinsed off the product immediately.
No heat gun was used and the Rust-Oleum set between 1 and 2 weeks before the tape was applied. It's possible that the stronger adhesive on the green frog tape caused the problem as I didn't see the same problem with the blue painters tape. It is also possible that the 1+ weeks of cure time wasn't enough.
However when I did the video the Rust-Oleum had been on that area for over 1 month and I even had problems with the black only section that was 4 months old coming off.
The products I used to try to remove the adhesive didn't impact the peel test and the enamel had cured for over a month before doing this test (products were used right before the video was shot). It was fully cured by then and the peel results are consistent with every single other test I've done with the Rust-Oleum. I still recommendation using Krylon Fusion Clear for plastics due to ease of use/removal. However no matter which product is used, the video did show that heavier applications of PlastiDip (a lot more coats than 5) does greatly help the removal process.
I do appreciate the questions both of you had as they are very valid and it's good to ensure that I didn't make any mistakes.
Old 12-02-2012, 03:16 PM
  #137
Starcraft II addict
Buda's Avatar
Christmas "lights"
Not car related, but is plastidip related so though I'd share.
I have a green house so I though red lights would be great. Not just any lights though, they had to be plastidipped. I looked outside and the outdoor lights on either side of the garage looked in need of some dip. I'm thinking of pulling the dip off the smaller glass sections and spraying it blaze green. I don't have much left but may just have enough to do the small glass sections.
Ready to dip
First coat
Three coats - a little black still shows through and I really like it that way.
Night shot!
Old 12-02-2012, 06:27 PM
  #138
swoosh's Avatar
you have become a certified Plastic dip whore
btw saw your car at work and am loving the rims....any change we can do my rims before winter
Old 12-02-2012, 06:36 PM
  #139
Starcraft II addict
Buda's Avatar
I put the green on the smaller glass pieces. It looks really good! Also I dipped the porch light too.
Old 12-02-2012, 08:15 PM
  #140
Very creative Sean! Well, done, young squire.
Old 12-02-2012, 10:57 PM
  #141
Starcraft II addict
Buda's Avatar
If there are more warm days maybe and depends what you want done.
Old 12-03-2012, 11:30 AM
  #142
swoosh's Avatar
^^^ just dip em black...no blue pin stripe/etc....
Old 01-25-2016, 04:44 AM
  #143
G290's Avatar
Sweet!
Originally Posted by GeeteeDan
Looks stupid with the bar off
The red dots just show where the screws go
And buda
This is what the grille looks like in black plasti dip with the hood trim done and v trim on the bumper
I have a silver TLN as well and love the way yours says Acura on the bumper in black!
navtool.com
Sponsored Sales & Group Buys
87
01-23-2016 01:25 PM
ExcelerateRep
10-14-2015 08:20 AM
Ratheruneeq
09-28-2015 07:41 AM
blackwarrior
09-26-2015 09:09 AM
Quick Reply: Playing around with Plastidip Colors
