Playing around with Plastidip Colors
#42
Yeah call them or e-mail justn.
Fonzie@dipyourcar.com
I got you, I don't like that trim on 07-08 too.
But I think SMOKE plasti-dip would make it just like 04-06 ones.
Gunmetal might be darker. I will try it too. I took out my black blasti dip from the frame of the grill.
and listen this after 1:00
he has matte clear plasti-dip on his chrome emblem. Takes the shine out and makes it like our grill 04-06
Difference between Clear Plasti-Dip and Smoke? Not sure
justnspace (07-23-2012)
#43
i agree, fantastic thread. rockstar, you can actually make the plasti come out amazingly smooth if you have a good hand, you can ask a few of the guys who have met with me at menlo and felt the dip. in about 2 weeks, i'll hopefully be able to post up a full DIY with some of my tips/tricks for dipping, as of now i have had stock wheels, grill, rear emblems, and window trim done. i've also done several other cars, its all about practice, just like regular paint
From what I can tell from using the clear matte and the videos of the smoke, the smoke is basically the clear matte plastidip with a slight grey tint to it.
Btw, I'm going to try to do a small sample piece of black plastidip and then get enough layers of enamel on it to be able to wet sand at 600 grit to get a smooth surface. Will probably be later in the week when it is posted. I think the enamel says to wait 48 hours before sanding.
#47
Yeah, I especially like the description:
"Plasti Dip® BLAZE Orange is a very bright, beautiful orange that is perfect for orange accents, trim and wheels. Exactly what you need to set your car apart from the rest."
http://www.dipyourcar.com/product.ph...&cat=26&page=1
That would set you apart alright. Not sure it would be set apart in a good way.
#48
^-- actually over in the new dipyourcar.com forums (in the Grills and Trim dipping section) there is a thread over there titled "2012 gli orange dip." and what that person did with the Blaze orange doesn't look all that bad.
Here is one of the pics that was posted up over there.
#49
ROTAREDOM
Afterward I dipped my rims and caps all at once and just peeled the inside plastidip out of the centre apps to reveal the red.
#51
Chapter Leader (Midwest Region)
Sean, I've been wanting to try that smoke on my mirror turn signals. I've read that it's not dark enough tho. You got any clear plastic to spray it on so I can see. Also is this "experiment" what you and I talked about at FF?
#53
'07 TL Type-S
#57
I just played around with the blue. You'll want to read my posting when I get to that one in a bit. First it's smoke time!
#58
I Like turtles
No Problem! Just remember to protect me when my girlfriend decides to kill me for this. She groans every time she hears the word Plastidip or finds out that I'm playing with the stuff again.
GeeteeDan (07-24-2012)
#60
Hope this is what you were wanting to see!
Let's hear it for some Smoke Plastidip!
Coat 1
Coat 2
Coat 3
Coat 4 - Here I accidentally had a heavy spot go right through the middle.
Coat 5 - Since I messed up a little bit on coat 4 I decided to go heavy all over on coat 5. Made quite a difference in the look.
Coat 6 - A light coat to even out coat 5.
Coat 7 - Final light coat to even out coat completely.
View from back
Various Coat 7 Pics:
LED light behind lens. It's not that bright going through it but couldn't get my phone to take a better pic than this.
#67
I don't think it will be the look I was going for. On a side note do you know how to get those little pieces off the mirror? I've never read where someone actually took them off. I think I am going to Niteshade them.
#68
Now for the Blaze Blue! (I've been busy tonight)
I like the blaze blue at lot but it has one major caveat. It doesn't have as good coverage. In order to get what I felt was a solid color I needed 8 coats. I first plastidipped an aluminum surface with the black and then did 2 strips of blaze blue over it. After that I then used the sliver metalizer over one of the blue strips. Then over half of the area of the blue strips/metalizer I put on 3 coats of Gloss Enamel.
With the Metalizer it actually does a really nice job in just one coat. I went ahead and did a second coat but felt that was getting close to overkill. One drawback of the Metalizer is that is uses the Glossifier as the base so you get the Light diffusion again.
I'll let you judge the rest from the picks below. I'll post up some better daylight pics in the next day or two. Tomorrow is officially 2 years of dating my girlfriend. I may get castrated if I work on Plastidip stuff tomorrow.
Blaze Blue Strips: 4 Coats - Can still see black showing through.
Blaze Blue Strips: 6 Coats - Can still see black showing through in person.
Blaze Blue Strips: 8 Coats - Complete Coverage.
Silver Metalizer: 1 Coat - I'd probably have stopped with just 1 coat.
Silver Metalizer: 2 Coats
Silver Metalizer: 2 Coats - Light Diffusion
Enamel Pics: I like how it deepens the Blaze blue.
#71
TL-S BeASt
Quick question, does any one know if scratches or scraps on a rim would affect the outcome of plastidip? Also is it possible to plastidip an engine cover or is it too hot that it'll melt?
#72
About scratches, it would depend how deep they are. It should cover up any imperfections tho. I think I remember seeing someone do plasti-dip on engine covers underneath the hi-temp paint they were using.
#74
Do you guys know if these are exact same?
Wheel kit Gun Metal Matte
and
just one spray can of Gun Metal
and
#76
I like the way you got the flat black to gloss up. How did you do that, as I've tried it no matter how much gloss I spray it only get up to a satin look. I sprayed my lower lip on my 350Z. Thanks
#77
Not metal or gloss
And I think wheel kit's doens't come in spray can's.
Comes with a bottle spray and you fill it with plasti dip.
That's why I can't make sure how the Gunmetal color comes out with the Wheel kit.
In his videos he only tested the spray can Gunmetal
#78
but the can spray has matte color right?
Not metal or gloss
Not metal or gloss
LoveMyTL-S (07-26-2012)
#79
@plastibluetl
Undying Dreams (07-26-2012)
#80
Received 6,470 Likes
Damn, all that looks great buddy.
