Picking out my 1st TL
Hello guys and gals...
Looking to pick up my first TL. At first i was going to pick up an 05, then i quickly learned the 04-05 had possible transmission issues and that the 07-08 was a safer bet. Anything else to be considered? I plan on doing a 3x3 trans drain and fill w/ DW1 and the pressure switches as well right away.
Thanks for the guidance!
David Maine (05-12-2020)
Latent car nut
Received 2,005 Likes
Or you could skip the transmission issue entirely and buy a 6MT model and put ACDelco Synchromesh Friction Modified MTF in it and call it a day.
ive got the 620rw Z06 with a 6 speed... the TL will be the get in and go car. There is a spotless 08 type s local to me with a 6 speed... too bad or else i would be buying it if it was A5.
Yeah, if you're looking for an auto then I'd go with an '07 or '08. There aren't a lot of problems with the 3rd gen other than the automatic transmissions. I'd just check for the normal car maintenance and condition stuff that you'd check with any used car. You may want to pay special attention to the dashboard, as it's prone to cracking. And there's a fair chance the Bluetooth module won't be functional. They had a very high failure rate in the 3G.
The following 2 users liked this post by losiglow:
David Maine (05-12-2020),
FRiCK (08-06-2018)
baboya96
50
05-06-2005 09:04 AM
BEETROOT
03-22-2005 06:38 AM
