Painted emblems
I'm new to the forums and the first mod I want to do is paint my emblems black so I wanna see what some of yalls emblems. I personally don't like the plastidip look. Post pictures of ur emblems and how u did it. Thanks
Here:
https://acurazine.com/forums/attachm...0&d=1352083955 https://acurazine.com/forums/attachm...9&d=1352083955 https://acurazine.com/forums/attachm...0&d=1373873150 https://acurazine.com/forums/attachm...2&d=1373873192 Those are painted. Color is dupli-color's enamel gloss black, I painted them as follows: 1 - Remove emblems, use dental floss inbetween the painted surface and emblem to cut the double stick then goo-gone to remove the residual double stick. 2 - Scuff emblems - I used gray scotch brite pads to scuff them until water sheets on the emblems. You don't want it to bead up at all, if it does keep scuffing until water sheets. Let it dry completely before proceeding and clean with dish soap like dawn to de-grease. 3 - Hit the emblems with duplicolor prep spray & allow follow the directions to let it evaporate 4 - Spray the emblems with 2 light coats of bull-dog, following recoat windows, careful with the bulldog it'll run really easy if oversprayed 5 - Paint with dupli-color enamel gloss black - Coat 1 is light, dusting - Coat 2 is also light, full coverage - Coat 3 is medium - Coat 4 is medium/heavy Follow re-coat windows between each coat 6 - Paint with Spraymax 2k Glamour Clear coat --- Warning here .. the spraymax 2k contains isocyanates and is extremely hazardous to your heatlh. Standard OV filters on your respirator last less than 10 minutes around this chemical (check the sheets) and it's odorless. It can cause major respiratory problems and you can become 'sensitized' to it and have an asthmatic reactions anytime you're near it in the future, for the rest of your life. Check the hazards, its not pleasant stuff and take appropriate precautions. I used a paint booth and put new filters on my respirator before starting to spray. Also wore gloves, coveralls, non-vented goggles and sprayed the paint so it would flow away from me and toward the paint booth ventilation. And I exited the paint booth between coats while I waited about 15 minutes for my re-coat window each time. - Spray it on in same way as you did the enamel black, following re-coat windows on the clear coat. The spraymax is dangerous for CC due to the isocyanates, just google the chemical name and you can read about it. But you're not going to find another rattle can clear coat that has as good of a finish as you'll get from the 2k spraymax CC. My paint has been on the emblems for over a year now and no chipping or flaking at all. I used one-shot red pin-striping paint for the A-SPEC lettering after the clear coat cured. Also carefully used an exacto knife and 3M double-stick tape to re-affix the emblems. I put the double stick on the back of the emblems before putting them back onto the car. |
Yeah I just dipped mine then did a triple layer of clear coat gloss. It's easy, painless, and probably wont give you cancer.
Its funny guys OP said he doesnt like plasti dip at all. :snicker:
Good job mzilvar on the write up and pic :thumbsup: |
I used to have the A on the trunklid plastidiped with clear coat over it, it looked good(not as nice as mzilvar's) but good for the amount of work I did. And if you get tired of it and want to go back to stock plasti dip peals right off.
Yeah that is the beauty about it plus they come in colors now. Granted I would rather have something better (black chrome) but I have been lazy about finding it and doing the work.
Aside from the nasty chemicals that spraymax clear coat looks like good stuff. They don't give it away tho! $20+ a can.
^^ Yah thats true it is expensive.
I actually have another can sitting on my dresser right now. Not sure what I'm going to use it for, I was originally going to use it to re-paint my C-MOD grill but decided to have the body shop re-do it NBP with some other parts on the car when I have my RonJon bumper installed. |
3 Attachment(s)
This is plast-dip and clear coat gloss. Emblem and rims.
Attachment 106912 Attachment 108361 Attachment 106979 |
Originally Posted by mzilvar
(Post 14704279)
Originally Posted by cjTL
(Post 14706161)
You painted an A-Spec badge... :what::yuck:
The lettering is red now, I'll get a better picture of it later. |
(Post 14706161)
Here's the photo of it with red lettering:
https://lh5.googleusercontent.com/-Z...0/IMG_0068.JPG I need to wash my car. When I painted I did everything wet on wet, only took a little over an hour to have all of the paint on from start to finish. If you wait too long your paint won't cure or it'll peel. Once the paint has cured, you're supposed to wait 7 days and then scuff it prior to painting it again or you won't get any adhesion. Paint has two ways to hold on.. mechanical adhesion (from the scratch lines) and chemical adhesion to prior layers. Once everything was cured I did the lettering, had to scuff the inside of the emblem where the lettering was carefully, then painted by hand with a paint brush and wiped the excess off the surface while it was wet. I used pin-striping paint for the lettering (one-shot) which is designed to go on top of clear coat. |
8 Attachment(s)
A few pic's of my CBP TypeS. All done with Plasti'Dip. Will be doing the grill shortly! Hope you like... :wish::wish:
Remove the emblems. Base coat with plasti dip then dupli colour engine enamel gloss black on top. It'll come out perfect, and if you ever decide you want to go back to chrome, it'll peel off.
:zombie:
that Murdered TLS... is niiisshhhe!
How do you re-apply when emblems after you detach them using dental floss?
Originally Posted by Cryhawk
(Post 15872310)
All of your typical auto stores usually has it too |
Type S Badge
Originally Posted by yn1scott
(Post 14716062)
"all done with plastidip"
just tape it up. then spray paint it |
and :zombie:
