The Optimal Percentage of Racing ATF
#41
I used redline racing atf and did 3x3 all at the same day with a little driving in between to move the fluids around. Its flaring so hard that even my wife who doesnt know anything about cars complained about it and even told me to trade in the car for the mdx because of how rough it is.
How was your transmission before using the Racing ATF?
I hope that I don't sound confrontational. I just want to collect the facts as accurately as possible. The forensics of this topic is important to the whole forum.
#43
Just to make sure. When you say it flared, do you mean that the tachometer would suddenly jump upward by approximately 500 RPM immediately before shifting to the ne gear (as shown in the video above)?
I would say the transmission was ok before the atf change.
#44
To all readers,
With these facts presented by abracing, this is another confirmed case of too much Racing ATF in my opinion.
Thank you for your patience and cooperation abracing
#45
4G Acura TL SH-AWD/TECH
great post inaccurate
i am about to do the pressure switch change and from what i believe, the first ever transmission drain/refill (car is at 129,000)
So, assuming that there was never any tranny drain/refill, and wishing to go the optimal "type f" route, i do:
Refill #1 = 3 quarts Racing ATF
Refill #2 = 3 quarts Racing ATF
Refill #3 = 2 quarts Racing ATF + 1 quart D4
correct? i am trying to aim for the best combination for future reliability of the transmission, while also getting crisp shifts.
thanks
thanks
#46
also, how would a recommendation level be for 2 quarts of D4 and ONE quart of Type F racing?
i do not WOT it too much, maybe once every day or so...if i drive it "quick", i will take it sometimes up to 5k rpms
#48
I used redline racing type f atf and did 3x3 all at the same day with a little driving in between to move the fluids around. Its flaring so hard that even my wife who doesnt know anything about cars complained about it and even told me to trade in the car for the mdx because of how rough it is.
#49
Chapter Leader (San Antonio)
Great thread! This is what my friend told me about Racing ATF, but I didn't understand anything he said. :x
He advised me to put 2 QTS Redline Racing ATF and 1 QT of D4 to balance the amount of FM/amount of Racing ATF.
I did this and 20k miles later, it still runs like the day I changed it!
#50
The shifting from a performance aspect would be quicker than just the D4. But please realize that you would not be getting the super quick, double-clutch like shifting.
#51
Just to clarify. Did you do only a single refill with 2 Racing + 1 D4? Or, did you do a 3x3 with 6 Racing and 3 D4?
#52
Since I got my TL I've done 2 changes with Castrol Multi-vehicle ATF (meets Honda spec), and one with the Redline type F racing. ..... I liked the firmer feel after adding the Redline, but I already decided future changes would be 1 quart of Redline with 2 quarts of synthetic ATF with FM. Call me a geezer, but any firmer and I call the shifts harsh. So for me the ideal mix is 33% racing ATF.
According to your description, you have done the following?
Refill #1 = 3 quarts Castrol Multi-vehicle ATF
Refill #2 = 3 quarts Castrol Multi-vehicle ATF
Refill #3 = 3 quarts Redline Racing
If so, then you have a 40% Racing mixture.
For any subsequent refills (If you choose to do any additional refills in the future), if you use 2 quarts synthetic ATF and 1 quart Racing ATF, then your Racing percentage would be gradually approaching 33% with each subsequent refill.
Chisel (11-01-2014)
#53
Perhaps I should had titled this thread as "The Ultimate Racing ATF Percentage".
#54
Coolest A-zine Member
What To Do....
About 4 months ago I had transmission failure. It occurred around 108k miles and was a huge blow to a college guys wallet. My transmission went through a full rebuild (I have the list of parts rebuilt/new parts somewhere) at a tranny shop in Amarillo named FiveStarTransmissions. All was well the first few months but I've developed that 2-3 or 3-4 gear, hard shift again. I was getting that pretty frequently before my failure, on the order or every other time I made this shift basically (I have an auto). The transmission and their work carries a 1 year warranty and he said that if anything big or time consuming had to be fixed that it would have to be fixed at his shop....which sucks b/c I'm 3 1/2 hours away from there (loooong story). He stated that small things I could get fixed locally though and they'd pay.
Ok sorry for the rambling...but when I went to pick up the car I asked him what ATF they used and he said it was their rebuild type of ATF. Not really sure what that meant but I figured you might have to use a specific type of ATF on a fresh tranny. So my question is should I bring this issue up to the guy or is it just common with our transmissions? It's only 20-25% of the time now but I dont want to gradually get higher and higher when I'm out of the warranty. I figure changing the ATF might lose the warranty, but i'll call to check. Just figured I'd ask for advice here also
#55
The 2 quarts of D4 and 1 quart of Type F would produce a 33% Racing mixture.
A 33% Racing mixture would be an extremely conservative route that will give you some of the benefits. The shifting from a performance aspect would be slightly quicker than just the D4 and the clutch wear would be slightly less than running just the D4.
On the other hand, the shifting experience and clutch longevity would be vastly superior to running the Z1.
#56
takin care of Business in
Received 4,732 Likes
3.5 qts....is he filling the tranny more than the max capacity ?
#57
I too had the flaring problem, running an 85% percentage of Racing and 15% of Z1, after approx. 3K miles. I had flaring in both the 2-3 and 3-4 shifts, plus a very hard 1-2 shift. My vehicle is an RDX.
After enduring the flaring for about 50 miles, I went to a current mix of:
1 quart Racing (already in the trans)
1 quart DW-1 (result of first drain/ fill) - stopped the flaring
6 quarts D4 (result of the next two drain/ fills)
---eof
#58
My wifes 04 Pilot had a lot come out, and it took about 3.5qts to refill to the line on the dip after the 3rd drain & fill.
#59
I was planning on changing my tranny fluid within the next few weeks and already have racing and lightweight racing on hand. Should I use just the regular racing fluid and buy a qt of D4 for the 3rd change? Or can I still do a 2:1 regular racing to lightweight racing fluid ratio like I was planning to do? I have a 2nd gen btw.
TIA for any input and suggestions
#60
WOW....I have done a 4x3 with the type F and have seen any flaring....its been 5K miles since the 4x3 and 8K miles since the 1x3....
Actually only 2.7 qts should pop out...dont know how your cuz is extracting
#63
#64
18psi
Before my car was taken off the road for the motor swap I had done 6 or 7 drain and fills with amsoil type F. The last drain/fill was roughly 10,000 miles ago (same time as the turbo install). I noticed no flaring.
When the trans is pulled and bolted to the new motor I have 10 quarts amsoil type F waiting to go in (I need the extra 1.5 quarts for the trans cooler)
I cant say that I ever noticed a difference between the 2nd drain/fill vs the 6th. But maybe it was so long ago I cant remember
Ill continue to use type F only unless I notice flaring.
Good work Inaccurate
#65
NBP is a pain...
I already completed the 3x3 Racing ATF a little over a year ago. I do notice the car lunging and shifting kinda harshly during stop and go driving. I would like the shifts to be a bit more comfortable and am thinking of of doing a 1x3 w/ just Redline D4 ATF instead of 2 quarts of Racing and 1 quart of D4.
Also pondering of maybe using 1x3 w/ DW-1 but may just stick w/ the Redline products since the fluid is of better quality.
Advisable?
Advisable?
#66
^^^ I would just go with the D4....
I did a 4x3 with Redline Type F and I do feel my tranny shifting very well....I would not want to change a thing about it....next flush is 60K miles down or 55K since I have been driving around for 5K since the 4x3 and 8K since 1x3.
After 60K miles, I might do a 4x3 using 9qts of Type F and 3 qts of D4....
#68
^^^ if you dont notice flaring why are you doing another drain and refill ? I think you should be good for the 50-60K miles interval....
#70
^^^ try Type F itself....I have done a 4x3 with type F and am fine since 5K miles....
If you want to go very safe:
Refill #4 = 2 quarts D4 + 1 quart Racing
If you want to go a little aggressive:
Refill #4 = 1 quarts D4 + 2 quart Racing
#71
Hey guys, I'm unsure of which method to go with. I have already done 4x3 refills of pure redline racing type f. I've been driving with it for about 5k miles already. The only think I don't like is the 1-2 shift like majority of the people on here, it's harsh.
I've already replaced the switches thinking it could help but it did not. So I don't know what to do next for my 5th refill. Inaccurate's suggestion of 2 qts of d4 and 1 qt of racing sounds great and I don't mind trying it lol. I'm thinking to do that method or maybe 2 qts of d4 and 1 quart of lightweight figuring I'll be dropping from 87 to 65 percent anyway and make viscosity thinner? What do you guys think and suggest? That or just add 3 qts of d4 but Im not sure what my percentage would drop to by doing that.
Suggestions?
Suggestions?
#72
Suggestions?
Suggestions?
#73
Suggestions?
Suggestions?
do you notice and flaring ? if you dont then you should be good to go....if you do then I would suggest doing the drain and refill#5....
I have been running 4x3 type F since 5K miles without any problems and I love the shifts....they are snappy....yes the 1-2 shift is harsher than the rest, but its only when the tranny is cold....otherwise I think its fine....
#74
Swoosh and to all readers,
Swoosh, although you have a 87% Racing mixture and no shifting issues, I feel that it is irresponsible to suggest to others that they should run greater than a 65% Racing mixture.
Many Acurazine members have had their transmissions replaced due to the Racing ATF. However, it was not the Racing ATF itself that caused the transmissions to be replaced. It was because we (the forum as a whole) was unaware that too little FM would cause issues. Now that we know, I do not want to see the Racing ATF to get anymore of a "black eye" from people suggesting anything greater than a 65% Racing mixture.
As I stated in my opening post of this thread, going beyond a 65% Racing mixture offers *no advantages* (except for forced induction applications) and many disadvantages.
To all readers, I advice that you follow my recommendations in my opening post. If you have questions about how to obtain a 65% Racing mixture, please ask and I will help you.
#76
Refill #1 = 2 quarts Racing ATF + 1 quart Lightweight ATF
Refill #2 = 2 quarts Racing ATF + 1 quart Lightweight ATF
Refill #3 = 1 quart D4 + 1 qt Racing ATF + 1 qt Lightweight ATF
The above will produce a 65% Racing mixture with normal viscosity.
For any subsequent refills (If you choose to do any additional refills in the future), you should use
This will maintain a 65% Racing mixture with normal viscosity indefinitely.
The following 2 users liked this post by Inaccurate:
AMSMiTH (02-20-2012),
demon-cleaner (02-09-2017)
#77
You are currently at a 87% Racing mixture.
Please do a single refill (1x3) as shown below. This will also maintain the same overall viscosity that you were aiming for originally with the Lightweight.
Refill = 2 quarts D4 + 1 quart Racing
This will produce a 65% Racing mixture.
This will indefinitely maintain a 65% Racing mixture with normal viscosity.
wilztlxs (10-02-2011)
#78
Originally Posted by anonymous
Thank you for clearing up my issue that I was having a while back.
I did a 4x3 with Redline Type F. After about 6k miles, I noticed my 2nd to 3rd shifts slipping or what I thought at the time. Anyways, Acura good willed a replacement trans and got me on my way. I have been hesitant about going with Type F again but after reading this I will do a couple drain and fill with Type F.
Today, I received the message above (see quote above) via a PM. In my opinion, this is another confirmed case of someone that had their transmission replaced due to having too much Racing ATF.
And, kudos to this person for still having faith in the Racing ATF.
#79
For anyone that is beginning to use Racing ATF for the first time AND WANT A NORMAL VISCOSITY
Pretty much, what is the difference between this post vs the first post that stated that the first refill should be
All Redline Type F
All Redline Type F
2 Redline Type F, 1 D4.
Once again, all this is applying to first time use of Redline Type F (or, potentially first drain and refill at all)
#80
1> how did you get to the 65% figure ?
2> you already had some fluid in the tranny which had less FM's so when you switched from that fluid to Type-F you had really low amount of FM's....
Am not asking anyone to keep pouring Type F in there until their tranny takes a dump.....am just saying people who have done 4x3 and had Z1 or DW1 in their tranny's before they switched to Type F to just keep it in before they feel any flaring and if they do experience that, switch/drain and refill with D4 or some like that....
a lot of people do listen to you and they should....you do extensive research....and am not pointing a finger at you....but how did we get to the 65% golden number....why not 70% or 75% or 50%....thats my question....
