Oil filter tricks - Let me hear them
Old 01-15-2011, 02:43 PM
Sutitan's Avatar
Ive had my car now for 96k miles, and im about to change the oil soon. While draining the oil is no big deal, I dread removing the oil filter since it always gets everywhere. Ive usually jut put up with it, cleaned a little mess, and thats all.
So I was wondering what tricks you guys use. I cant be the only one that has these problems. Let me know.
Old 01-15-2011, 02:49 PM
Chapter Leader (Central New Jersey)
07tl-s6spd's Avatar
put a freezer bag around it while unscrewing...works for me
Old 01-15-2011, 02:52 PM
boomersooner02000's Avatar
I do the same thing. Works great!
Old 01-15-2011, 02:54 PM
Sutitan's Avatar
Do you guys usually remove the wheel?
Old 01-15-2011, 03:11 PM
Walk the walk
Shoot2Thrill's Avatar
Turn the wheel, use the bottom 3/4 of an empty 2 liter soda bottle around the filter as it is removed.
Old 01-15-2011, 04:42 PM
Registered Member
SouthernBoy's Avatar
I use a heavy duty ZipLock freezer bag. I loosen the filter using a wrench to the point where I can continue to remove it by hand. Then I work the ZipLock bag up over the filter and pickup arm and continue to remove the filter. The residual oil goes into the bag to be dumped in some creek in the woods along with the crankcase oil when I'm done. No muss, no fuss.
(I don't really dump any oil in a creek.)
Old 01-15-2011, 05:07 PM
piggydog's Avatar
TL easiest oil change ever. Turn the wheel, remove filter, no need to even jack the car up.
Old 01-15-2011, 05:12 PM
Chapter Leader (San Antonio)
TheChamp531's Avatar
Lay under the filter, and open your mouth.
Oh does it taste gooooood.
Old 01-15-2011, 05:25 PM
LaCostaRacer's Avatar
Drain the filter first by punching a hole in the bottom using a Screw driver- catch the drippings in your pan and you're good. I also saw a flexible plastic thing in the back of a car magazine that forms a flexible funnel too. I personally use the screw driver method.
Old 01-15-2011, 06:15 PM
piggydog's Avatar
I just wipe whatever fell on the pipe.
Old 01-15-2011, 08:12 PM
SpiderX1016's Avatar
I just use Blue Shop Towels. I put 1 or 2 around the parts it might drip on and when the new filter is installed, I use one of the towels to wipe everything down.
If I'm lazy I just wrap the filter with one of those towels and unscrew by hand. Works the same.
Old 01-16-2011, 04:17 PM
Flick's Avatar
I wrap a couple of pieces of aluminum foil around the pipe under the filter, take the filter offer and just pull the foil off when I'm done and no mess to clean up.
Old 01-16-2011, 10:18 PM
Sutitan's Avatar
Ziplock bag worked! It was just turning the filter once the inside of the bag was covered in oil. The whole job was about 95% clean
Old 01-17-2011, 12:40 PM
#1 Super Guy!
94eg!'s Avatar
This car is 1000x cleaner than doing anything with a K-series motor in it (RSX, Element, Civic, etc). The filter is on the back of the block right above the driveshaft boot and subframe. You can't even imagine the lengths you must go through to keep oil off of everything. Took me many years to perfect a technique.
Then we sold the Element...
Old 01-17-2011, 02:08 PM
One or Two?
chuanger's Avatar
I use a ziplock freezer bag as well. No mess at all.
Old 01-17-2011, 04:12 PM
Why me??
mikedog4's Avatar
I just use shop towels
bungln
02-20-2019 08:47 PM
atsx1313
09-22-2015 09:04 PM
VolkingTL
09-16-2015 09:10 PM
ghuns
09-16-2015 04:26 PM
datadr
09-12-2015 09:12 PM
Quick Reply: Oil filter tricks - Let me hear them
