The Official OEM Tail Light Difference Thread
3 Attachment(s)
:wave:
Seeing another thread asking about tail lights made me want to create another “difference” thread, similar to the one I did for the A-Spec lip kit which can be found here: https://acurazine.com/forums/3g-tl-2004-2008-93/unofficial-spec-difference-thread-853331/ ****Before we begin...ALL 3G TL tail lights are interchangeable. Listed below are the different types.**** 2004-2006 Tail Lights
Attachment 48292 http://2.bp.blogspot.com/-zaKlq63wal...Package_05.jpg http://i942.photobucket.com/albums/a...DSCF0499-1.jpg 2007-2008 Base Tail Lights
http://4.bp.blogspot.com/--vN9eZq6h6...llpapers_3.jpg http://farm8.staticflickr.com/7325/9...471ee097_b.jpg 2007-2008 Type-S Tail Lights
http://farm6.staticflickr.com/5500/9...16c67cc4_b.jpg http://www.linenoyz.net/files/images/DSC08244.jpg 2006-2008 CDM (Chinese Domestic Market) Tail Lights
http://i43.photobucket.com/albums/e3...c/IMGP3767.jpg Attachment 48293 Attachment 48294 *The picture above does not show actual CDM tails, rather ones that were modified to look similar. You can see that the vertical clear reflectors are missing. I had a hard time finding actual CDM tails installed :tomato:
Originally Posted by jnc2000
(Post 10680712)
NOTE: These pictures do show bumper removal with the A-spec kit installed. If you do not have the A-Spec kit you're proccess will be slightly different. The first step is to jack the vehicle up. Make sure to use jack stands. http://jczechphotography.com/photos/...06_9iwAH-M.jpg http://jczechphotography.com/photos/...49_Jdjbm-M.jpg After the vehicle is secure, you'll want to remove the screws securing the rear bumper to the vehicle behind the wheels. You may need to remove the rear wheels thus was my reasoning for jacking the car up in the first place. http://jczechphotography.com/photos/...66_dNeAD-M.jpg http://jczechphotography.com/photos/...11_voaZ8-M.jpg Next, pop open the trunk. Take note of the two smaller plastic covers in the bottom corner. You'll need to pop these off with a small flat head screwdriver take care not to scratch the paint. Behind the cover you'll see a 10mm bolt. Remove the bolt from both sides. http://jczechphotography.com/photos/...17_mHbqC-M.jpg http://jczechphotography.com/photos/...14_WMngi-M.jpg http://jczechphotography.com/photos/...90_oYgsu-M.jpg Next step is to remove the 10mm bolts from the bottom of the bumper. In these pictures, take note at the black bolts, not the silver screws. You'll want to remove all the bolts. --This is where the A-spec and base bumper will differ. The base bumper you'll also be removing some additional screws / plastic pieces. http://jczechphotography.com/photos/...47_Y648S-M.jpg http://jczechphotography.com/photos/...59_v39QF-M.jpg http://jczechphotography.com/photos/...31_RTYak-M.jpg http://jczechphotography.com/photos/...94_VWdqv-M.jpg This is the part where you'll need a helper. After taking all the screws off you'll want to start at each corner and gently pry the bumper cover off. You'll feel/hear it snap off - thats good you want that. It sits into plastic grooves and you'll need to work it out of those grooves. When its all loose you'll know.. take the bumper and set it aside. This next picture already shows the light removed... but I'll use it for illustrative purposes. I'll show the removal of the light below. http://jczechphotography.com/photos/...33_XEzGN-M.jpg Next, you'll want to remove the stock light. You'll repeat this process for both sides... so it doesn't matter which side you start on. There are two 10mm bolts and 1 Philips screw you need to remove. on the outside. the screw goes up into the light itself, and the bolts into the car body. Start by remove these three pieces of hardware. http://jczechphotography.com/photos/...65_63x37-M.jpg Next, on the inside you'll want to remove the 8mm bolts that are threaded onto securing the light to the interior sheet metal. There are a total of 4 per side. Once all these are removed, unplug the wiring harness and the light should just pop off. http://jczechphotography.com/photos/...20_4aL5E-M.jpg http://jczechphotography.com/photos/...39_Htzcc-M.jpg With the light off the next step is swapping the LED board. There are 4 small Phillips screws that you'll need to remove. When you are swapping the LED removing the LED board, make sure you remove the foam grommets too as you'll need to reuse them when you install the new light. http://jczechphotography.com/photos/...50_9vgz2-M.jpg http://jczechphotography.com/photos/...21_QvVqZ-M.jpg Next, you'll want to reinstall and route the small plug from the stock light into the Type-S tails. This can be tricky so take your time. http://jczechphotography.com/photos/...36_NhqLo-M.jpg http://jczechphotography.com/photos/...67_D3ZKd-M.jpg http://jczechphotography.com/photos/...67_XyzY6-M.jpg Reinstall the LED board - put the screws back in and make sure to reuse the foam gaskets. To install the light - go in the reverse order from the initial removal. Take care not to over tighten any bolts. Repeat these steps for both lights. Grab your friend and put the bumper back on. Loosely fit the bumper on the vehicle and check alignment. then press the bumper into the fittings. You'll hear it snap into place. Reinstall all the hardware and sit back and enjoy the fruits of your labor.
*If I used a picture owned by you and you would like it removed, please let me know and I’ll have a moderator edit my post. I used your picture strictly for educational purposes. *If you see that any of the above information is incorrect, please let me know so it can be corrected. **Big thanks to jnc2000 and KB1Spec for information found in their threads and their pictures :thumbsup: |
Very well put information
Good standard information here Tyler, well laid out.
And I like that first shot of the Type S tails, very nice :snicker: |
Great info. It is much appreciated. I didn't know about the CDM lights until now.
Sweet! This was definitely needed.
Great post. Lots of info.
Glad you posted this, it will help me out here soon
Nicely done, Tyler. :thumbsup:
Great DIY!! Thanks for taking your time with this.
Outstanding work Tyler. I'm changing you from Unofficial to Official-Congrats!
Awsome CLtothTL32, But still a PITA to do.. HAHA
Actually you don't need to take out the whole rear bumper. When I did my I just loosen some bolts on the bumper and barely enough space to use my socket wrench and nudge in to loosen the bolts of the bracket of the tail lamp.
5 Attachment(s)
FYI here is the CDM tail lamp with the vertical reflector and also the comparison of the USDM modded tail lamp
Attachment 48287 Attachment 48288 Attachment 48289 Attachment 48290 Attachment 48291 |
both your aspec and taillight differences thread get so many thanks, but my seat difference thread is like dead....should i make a headlight difference thread? LOL
Good info, but in the bumper removale DIY you do not need to completely remove the bumper as it states. Infact, all you have to do is pull out the upper portion of the bumper just enough to get to the two bolts under each tail light.
I didn't even know the CDM taillight existed. Kinda cool.
Such a great thread. I need this valuable information. Thanks:thumbsup:
1 Attachment(s)
the CDM's are not flat!
there's a little protrusion that sticks out, which I think is pretty neat! you can kinda see it in this photo Attachment 48247 |
CLtotheTL32, Thanks for the great write up!
Taillights
Is it possible to get the CDM tailights
if so how &where |
They cannot be bought new. Only chance you have is to purchase them second hand from someone selling theirs. Also expect to pay big $$$ as they're extremely rare now.
Depending on how you look at it. Its not worth getting it. I see some floating around on Ebay selling copies of the CDM style tail light. I used to do tail lamp conversion back in the days where I swap out the outer lens of the base TL tail lamp with the TL-S tail lamp
Where can I purchase the 2006-2008 CDM (Chinese Domestic Market) Tail Lights? All TL's should have had amber turn signals!
I see someone is selling only the driver's side on ebaY. Asking them where I can get the other side is like talking to a brick wall. . . |
I think everyone and their brother has tried asking that eBay seller for the passenger side. I can confirm that they responded to me a looong time ago saying that they do not have the passenger side available.
Good luck lol |
Where is that CDM 4th brake light at tho
https://c2.staticflickr.com/6/5692/2...2047cdf6_b.jpg
Poor man's version of CDM tail lights with amber LED turn signals :rofl: |
Originally Posted by Superunknown
(Post 16292403)
http://autonews.gasgoo.com/resource/...39e34b01e7.jpg |
I have an irrational need to find one of those.
Originally Posted by wusty23jd
(Post 16292389)
Ugh, that's frustrating. The demand for these is so high too. It's a shame that both sides aren't available right now.
I got a pair of these, cleared with carbon fiber inserts for $300 2nd hand. I sold them with my last TL, and seriously thought they were some cheap replica housings.
Originally Posted by 1black_seven
(Post 16392832)
https://cimg3.ibsrv.net/gimg/acurazi...9071346e89.png |
Originally Posted by mdnborg
(Post 16392833)
Does anyone here know how to clean the inside of a taillight? I cut mine open and some water got in (very little) after noticing I didn’t seal this small area. Also anyone selling CDM’s? |
Originally Posted by navicolb
(Post 16395498)
(Post 16395499)
Distilled water.
whats the drying process, sun bathe, blow drier? |
(Post 16395500)
so im guessing just swish it around inside right? whats the drying process, sun bathe, blow drier? |
(Post 16395501)
Don't use a hair dryer, you'll just blow more dust in. Sun dry or leave it in a dry area for a few days.
He is lol
(Post 16395533)
He is lol
