The Official "Does This Fit My Car?" Thread
Old 11-04-2008, 04:57 PM
  #321
94 DC4 RS LSV/Turbo
stillhere153's Avatar
it will be slightly off, but not enough to not match...
lets just put it this way, from teh factory the wdp bumper is wdp yet it doesn't match the car... the difference between ssm and asm is way less than that, so it is almost not visible
Old 11-06-2008, 01:32 PM
  #322
SSGTUSMC's Avatar
Good Thread (tires)
I have an 04 Tl, non-navi
came with 235/17/45
want to put on 245/17/45
10 mm wider......... like the thread says...
Old 11-06-2008, 10:30 PM
  #323
94 DC4 RS LSV/Turbo
Fits no problem
Pick from either 245/45-17 and 245/40-17
I am rolling on 255/40-17
Old 11-07-2008, 06:14 AM
  #324
SSGTUSMC's Avatar
no rubbing anywhere then with the 245's ?
btw everything is Still stock too.
Old 11-07-2008, 07:19 AM
  #325
94 DC4 RS LSV/Turbo
I have wider wheels, and no rubbing, but its near stock
You won't rub unless ur slammed (3" drop), at which point the tire will touch the fender
Old 11-07-2008, 09:13 AM
  #326
SSGTUSMC's Avatar
10-4 thanks a million man!
then 245/17/45!!!!!!!!!!!!!!!
btw did you know that you have 8,273 posts.....holy moly
Old 11-07-2008, 12:38 PM
  #327
94 DC4 RS LSV/Turbo
roger that
8,285 and counting, over
Old 11-13-2008, 01:15 PM
  #328
4th Gear
Blue_S2K's Avatar
would this fit. 19x8.5 +25 offset all around with 235 35 19 tires. Car is stock height but if i get some wheels i plan to lower it just a little .5-1 inch. Thanks
Old 11-13-2008, 06:47 PM
  #329
94 DC4 RS LSV/Turbo
It'll fit and be nicely aggressive
Tires: 225/40-19
Drop: see aspec suspension just under 1"
Old 11-13-2008, 06:53 PM
  #330
94 DC4 RS LSV/Turbo
Tires: 225/40-19
Old 11-13-2008, 11:40 PM
  #331
4th Gear
Blue_S2K's Avatar
you think it will fit with 235/35/19 cause the wheels i wanted comes with the tires already..
Old 11-13-2008, 11:41 PM
  #332
4th Gear
Blue_S2K's Avatar
do you think i'll have to roll the fenders or anything?
Old 11-14-2008, 01:49 AM
  #333
94 DC4 RS LSV/Turbo
if you'd like to run 235, your fronts will be ok, but the rear will require you to buy a rear camber kit, and run -2 degree and also have 0 degree toe and also roll the fenders in the rear
you cannot roll the fenders in the front (if you do you will have some visible damage to the front body line curve where the fender meets the bumper)
Old 11-14-2008, 02:08 AM
  #334
4th Gear
Blue_S2K's Avatar
ok thanks for the response i guess i'll pass and look for another set thanks again
Old 11-15-2008, 07:15 AM
  #335
B A N N E D
Riga89's Avatar
I'm thinking about buying these wheels for my car. Will they fit?
http://cgi.ebay.com/ebaymotors/09-Ac...oto#ht_930wt_0
Old 11-15-2008, 08:12 AM
  #336
94 DC4 RS LSV/Turbo
The bolt pattern is 5x120 and the offset if +55
You will have to get a wheel adapter in order to allow fitment
Pm me if you need a place to order the wheel adapters from
The wheel adapters you will require are as follows
5x114.3 to 5x120, with a thickness between 10mm to 20mm
Should you decide to pursue these wheels, you will surely be the one and only 3rd gen sporting them
Good luck
Old 11-15-2008, 05:41 PM
  #337
mikedejohn's Avatar
Year: 2008
Trim: BASE
Color: SILVER
Item you would like fitment verified:
I would like to know if progress sway bars for the 2007 Acura Tl will fit my 2008 Acura TL???
Old 11-16-2008, 04:43 PM
  #338
My Other Ride is a Huey
tragichero's Avatar
Year: 2007
Trim: Type S
Color: NBP
Item you would like fitment verified: This might be a dumb question but will a non-type s front bumper spoiler fit my car?
Old 11-16-2008, 06:20 PM
  #339
94 DC4 RS LSV/Turbo
Originally Posted by tragichero
Year: 2007
Trim: Type S
Color: NBP
it can be force fit, in fact it has been done before, you will have to get a body shop to do it tho
Old 11-16-2008, 06:21 PM
  #340
94 DC4 RS LSV/Turbo
Originally Posted by mikedejohn
Year: 2008
Trim: BASE
Color: SILVER
the sway bar for the 1st gen tsx, 7th gen accord, and all 3rd gen tl... IS THE SAME
progress has different part #'s but it is all the same
Old 11-18-2008, 03:23 PM
  #341
tragichero's Avatar
Looking again I noticed that the 04-06 front spoiler is different from the 07-08. Will it be a bigger hassle to put the 04-06 one on my 07 TL-S?
Thanks stillhere!
Old 11-20-2008, 05:19 PM
  #342
94 DC4 RS LSV/Turbo
As I stated get a body shop to do it because it will require modification to the lipwhere the foglights are located
Old 11-21-2008, 08:22 PM
  #343
Team Anthracite President
Vffr1's Avatar
Year: 2004 TL
Trim: Base
Item would like verified: 2008 Type S rear bumper and 4 pipe exhaust system.
My car was recently hit in the rear would like to replace with an 2009 Type S bumper and 4 way exhaust pipes, will it fit?
Michael
Old 11-21-2008, 11:35 PM
  #344
Vffr1's Avatar
Now that I have read 9 pages, let me ask in a different manor.
Seems 08+ Type S rear bumper covers will fit 2004-07TL's.
Can I use my stock exhaust or must I purchase the 4 pipe exhaust to make it all work (I'd like to put the bumper cover on then find a used 08+ exhaust).
Thought I somewhere bumper cover fits, but needs a little cutting? Can you explain what needs to be cut, and by how much.
Lastly, is the 4 pipe system a direct fit to 04 - 07 models or does that need to modified and is a bolt in or weld in?
Thank you,
Michael
Old 11-22-2008, 12:10 AM
  #345
94 DC4 RS LSV/Turbo
ok here is the lowdown
04-08 base is 1 tip on each side
07-08 type s is dual tip on each side
04-08 base bumper fits 07-08 type s (same applies to the 04-08 base skirt on an 07-08 type s)
07-08 type s bumper fits 04-08 base (same applies to the 07-08 type s skirt on an 04-08 base)
as for the exhaust, the 04-08 base exhaust fits the type s no problem
the 07-08 type s exhaust when installed on the 04-08 base will require either an 07-08 type s rear bumper, or an 07-08 type s rear skirt (which will require some cutting)
cutting: very minimal... pm me if you need pics of exactly what needs to be trimmed
Old 11-23-2008, 08:46 PM
  #346
cellph titled's Avatar
Year: 2004
Trim: Base
Color: NBP
Item would like to be verified: 2004 Type S Wheels on my base TL?
Old 11-26-2008, 11:42 AM
  #347
everto13's Avatar
Year: 2004
Trim: Base 6MT
Color: ABP
I need to replace the front bumper cover, which has some cosmetic damage. Will the '07-'08 base bumper fit? What about the '07-'08 type S. Any mods required, or will it snap in?
Old 11-26-2008, 10:34 PM
  #348
94 DC4 RS LSV/Turbo
Originally Posted by cellph titled
Year: 2004
Trim: Base
Color: NBP
you mean 07-08 type s wheels on a base... yes they fit no issue no problem no issue nothing
  #349
94 DC4 RS LSV/Turbo
Originally Posted by everto13
Year: 2004
Trim: Base 6MT
Color: ABP
it fits 100% but all of the grille pieces will need to be swapped out for either the flat grey from the 07-08 base or the black chrome from the 07-08 s
Old 12-18-2008, 01:47 AM
  #350
More Than Meets The Eye
phambam's Avatar
Currently Own:
07' Type-S, 5AT, Brembos
I want to purchase 04 A-Spec Gunmetal 18x8.5 +45 Offset
Will these fit without any problems and clear the brakes?
Old 12-18-2008, 03:30 PM
  #351
phambam's Avatar
I have another question (assuming they fit without any issues)...
Will I lose my TPMS? Is there anyway around this?
And lastly is there a way to shut off the light that will be a constanty eye sore?
Thanks!
Old 12-18-2008, 04:48 PM
  #352
04 tl stealth's Avatar
will the speedo and tach from a 08 type s fit my 04 5at? Would i need to make any changes?
also... Instead of doing a full bbk i was thinking just doing new brembo calipers for all 4, they do not make specific for tl what car should i get them for and what do i need to change? (6mt rotors are nice but i want the rears to look the same like porsche has same fron and rear)...thanks
Old 12-18-2008, 10:04 PM
  #353
muhshu417's Avatar
Year: 2008
Trim: BASE
Color: SILVER
Old 12-24-2008, 11:21 AM
  #354
Crazy Cuban's Avatar
Posting this here too .. sorry and thanks stillhere153
Wheel Make/Model: Platinum Gripp
Wheel Size (**X**):18x8
Wheel Offset (+**):+40
If lowered (amount): none
Transmission (Manual or Auto):MT
Year/Trim (04-07, Base or Type S):04 base
Width/Sidewall-Diameter (***/**-**):245/40-18
Edit: will they fit?
Old 12-24-2008, 12:27 PM
  #355
94 DC4 RS LSV/Turbo
for brakes pm excelerate
for gauge cluster... it should fit, but you will have to cut and splice for the mid screen
  #356
94 DC4 RS LSV/Turbo
it'll need a 5 or 6mm spacer
Old 12-24-2008, 12:28 PM
  #357
94 DC4 RS LSV/Turbo
Originally Posted by muhshu417
Year: 2008
Trim: BASE
Color: SILVER
yes it does
Old 12-24-2008, 03:11 PM
  #358
Former Whyner
RonJonTL757's Avatar
Year: 2005
Trim: Navi
Color: SILVER
Item you would like fitment verified: I got one for ya. The clock display on the 8th gen civic is blue (non-si) and red (si). Can that blue display be transplanted into our boring gray to match everything else blue? it looks the same.
http://us.autos1.yimg.com/img.autos....12_346x270.jpg
Old 12-25-2008, 05:00 PM
  #359
6th Gear
TLx2o8's Avatar
anyone have any pictures of
19x8 wheels +30 offset slammed?
any problems with rubbing?
pics?
Old 12-25-2008, 11:51 PM
  #360
94 DC4 RS LSV/Turbo
Originally Posted by RonJonTL757
Year: 2005
Trim: Navi
Color: SILVER
do you know how to solder... if so it'll fit straight custom retrofit
Quick Reply: The Official "Does This Fit My Car?" Thread
