New aftermarket headlights? [pics]
Old 12-24-2018, 04:46 PM
  #121
jdmvette's Avatar
Originally Posted by jdmvette
Use a Phillips in the slot and you will see the adjuster. I couldn't see it at first but used my phone's flashlight and you can see the "gears" you turn to raise/lower.
I just took some pics for the adjustment
Factory adjustment hole, passenger:
Getting closer:
There you are!
Old 12-24-2018, 10:21 PM
  #122
hamburglar490's Avatar
[list=1]
  • I just took some pics for the adjustments
    Getting closer:
    There you are!
Oh man, that would have saved me quite of bit of pain hahah. Ugh well now I know at least. Any luck looking up that harness for LEDs? Would love to give them a shot
Old 12-24-2018, 10:25 PM
  #123
jehuh's Avatar
Are you guys running LED rear turn signals in conjunction with these headlights? My worry is that these will cause hyper flash since my rear signals are LED (currently running incandescent fronts). I have the error free LED signals in the rear so I hope the upgraded front turn signals won't trick the car into thinking a bulb is out since in theory these will draw much less energy?
Old 12-24-2018, 10:35 PM
  #124
Null and proud of it
Midnight Mystery's Avatar
From what I understand, they are LED and have a resistor bult in to prevent hyper flashing. It looks like this kit is Plun N' Play!
Old 12-25-2018, 12:43 AM
  #125
jdmvette's Avatar
I'll get that looked up as soon as I can. Wrapping gifts for the kiddos now
Old 12-25-2018, 12:50 AM
  #126
jdmvette's Avatar
I currently run red vleds Triton v6 in the rears and formerly ran the same in amber in the front. The vleds v6 kits are awesome and incredibly bright. They come with resistor kits to prevent hyperflash so it was plug and play and worked perfectly.
Here's the amber kit that I pulled out of the front yesterday that I'll have for sale when I get around to posting them up
Old 12-25-2018, 12:59 AM
  #127
jdmvette's Avatar
If you want to use the LEDs as DRL, I suggest wiring it to the DRL ststem. Or you could get a DRL module (hooks to battery and ground/uses alternator voltage jump in battery to activate) and find the LED power wire on the pinout, I suppose.
IDK, I was hoping it could work this way... Only thing, the LEDs will not be bright enough to use as DRL, really.
Tried it before and the LEDs need to be extremely bright to be seen in direct sunlight like OEM DRL is.
Here's how they looked in the sun this morning.
Partial sun:
Full sun:
These LEDs are BRIGHT, I'd say at least as bright as any OEM in the full sun in my limited experience.
The following 2 users liked this post by jdmvette:
mazen222 (12-26-2018), silverTL6 (07-02-2020)
Old 12-25-2018, 01:43 AM
  #128
Wow, that looks good!
I like that they still look like the OEM lights, in a way!!!
Old 12-28-2018, 06:29 PM
  #129
jdmvette's Avatar
Try using these with the "R3" option
https://store.ijdmtoy.com/LED-Daytim...ecoder.htm#top
It looks like the one I have.
If all else fails, just wire the DRL bulbs to an ignition-switched 12v source. Your DRL bulbs will be on day or night (but they look real good alongside the new headlight accent LEDs).
You'd still have the DRL code in the cluster but you would have functioning DRLs again
Old 12-28-2018, 08:09 PM
  #130
Put a little toggle switch on it, did this on my old Camry!
Old 12-29-2018, 02:00 PM
  #131
MyGuti's Avatar
Hey I got my headlights and fogs installed yesterday and man what a difference! IMO they look much better in person and build quality is top notch.
I also have the same R3 harness and am wondering what temperature the DRL bulbs are that come with the new headlightz? You say they match the LED accents nicely, your talking about the bulbs that come installed in the headlights right?
I'll be uploading some pics soon
Old 12-29-2018, 06:02 PM
  #132
jdmvette's Avatar
Oh no, I meant that my LED bulbs "match" nicely in the sense that even though mine are amber but the whole "LED look" just is just so modern and fresh IMO.
The new headlights came with a regular halogen bulb so I wouldn't recommend using that since it looks old school.
Awesome you got yours! Looking forward to your pics man!
Old 12-30-2018, 12:04 AM
  #133
MyGuti's Avatar
Bear with me....im uploading from mobile....
So overall, the install was fairly straight forward. The company does a good job providing a sheet of instructions and they are simple and clear. This was the first time I've ever removed the front bumper on any vehicle, and this is my second TL. By far, removing the bumper and headlights is the most difficult part. However, now that I've done it once. I'm confident, I can get it off within 30 minutes. Was just alot of trial and error, putting it back on as well. The bloody headlights have about 7 bolts holding them in place, 2 of which are on a clamp which is an absolute PITA to get too.
Aiming the lights were a bit tricky as well, just tedious really. If anyone does take the plunge and orders these sets ...make sure you seat the HID bulb correctly. Be careful to pay attention to how your bulb is seated in your original headlights.
Enough rambling..onto some shitty install pics
Last time she will be stock
superb packaging by AKG, really well done.
Didn't get a shot with the lights and fogs together. Will try and get some tonight
Old 12-30-2018, 01:01 AM
  #134
OMG! Looking awesome! Makes the car look so much fresher!
Wrap your grille black! It would look nice!
Old 12-30-2018, 02:34 AM
  #135
jdmvette's Avatar
^^looks good my man!
also looks like you're in need of some new hood struts!
I got me a set from orielly's fairly recently, they're easy to pop on and off
Old 12-30-2018, 12:41 PM
  #136
MyGuti's Avatar
Thanks man, I agree it totally refreshes the car's front end, especially with the updated fogs to match. Shoutout for hamburgler for those!
I'll think on the wrap lol. Right now, I really enjoy the subtle bits of chrome on the car.....so if I get bored of that, I definitely change it up
Haha yea, I gotta get on those hood struts asap!
Thanks for being the one to post these man. I get compliments everywhere I go, and I was able to give the front end a more aggressive styling.
I may have to remove the front plate, but its a pricey ticket if I get pulled over
Old 12-30-2018, 02:51 PM
  #137
mhtut83's Avatar
Sweet! Just wondering how they'd look on a NBP. You got me sold on them! I'm going to pick up a set since the seals on mine are bad and have crazy condensation getting in. Plus, the lenses have micro cracks inside that I can't polish out.
Old 12-30-2018, 02:57 PM
  #138
mhtut83's Avatar
Did you all go with the original link posted by Hamburgler to guy them? The one without any pictures?
Amazon Amazon
Old 12-30-2018, 08:31 PM
  #139
jdmvette's Avatar
I bought mine on eBay but I wouldn't hesitate to buy them from Amazon. Pull the trigger!
Old 12-31-2018, 01:47 AM
  #140
MyGuti's Avatar
Got a few more pics of the headlights. This time with them actually on lol.
I'll be updating my thread with a few more...
Old 12-31-2018, 02:31 AM
  #141
jdmvette's Avatar
[left]
img]
Did you make a new thread?
Old 12-31-2018, 05:11 PM
  #142
jdmvette's Avatar
More dirty daytime pics
Old 12-31-2018, 05:45 PM
  #143
No, no, Way dirtier next time! :wink:
Old 12-31-2018, 09:01 PM
  #144
Ossman14's Avatar
These are growing on me. Oh the decisions
i mean I’m sure I could open up these and install my demon eye, but seems pointless to spend $300+ just to hack them up
Old 12-31-2018, 09:07 PM
  #145
MyGuti's Avatar
In my humble opinion, they look the best on a NBP
Old 12-31-2018, 11:05 PM
  #146
jdmvette's Avatar
I just did a bit of rewiring on the headlights in order to have the DRLs always on and an added bonus, I also got around the DRL warning light on the dash!
I used some spare short wiring harnesses I had to tie the LED bulbs together. I also tied them together using the existing long wire harness (posted above) to run from the passenger side to the driver side.
Once the were both wired together, I ran the ground wire to ground and ran power to an ignition-switched point on the fan relay in the fuse box pictured here:
I was able to get around the DRL warning light because I had a pair of resistors from VLEDs I had previously purchased (didn't work with the LEDs directly due to flicker)
In this case, I was able to plug the resistors into the stock blue connector it made the car happy.
These were the "R2" resistors I used:
Here's a quick 'n dirty pic of the car tonight with the low beams on with the DRLs:
Success! Hey Hamburglar give something like this a shot!
mhtut83 (01-01-2019)
Old 01-01-2019, 04:54 PM
  #147
MyGuti's Avatar
Nice job on wiring the DRLs to run by themselves. I'm hoping someone does a write up for independent fog lights for our 07-08s. If that happens, then I'll run DRLs to match the LEDs and fogs to complete the look
Old 01-01-2019, 07:41 PM
  #148
Ossman14's Avatar
lol they definitely do. I may have to pull the trigger at some point. Makes me sad since I did my lights by myself lol
Old 01-01-2019, 07:42 PM
  #149
jdmvette's Avatar
Are you looking to have the fogs on with the low beams off?
I would think that if you wanted to trigger the fogs to turn on with just the parking lights it would be easy to tie the fog power wire to any of the lights that turn on with the parking lights. Such as the fender side marker lights or the parking LEDs on your new headlights.
Old 01-01-2019, 08:56 PM
  #150
MyGuti's Avatar
Hmmm I'll ask a buddy who's good with electronics and see if this would be a smart route to take. Basically I want to run the fogs independent as it's been done for 04-06 models. But if it's not possible for 07-08 models, I'd be happy with being able to run the fogs with the parking lights
Old 01-03-2019, 11:14 AM
  #151
JD TL-S's Avatar
Thanks Bro Long time no see. That WDP Was sweet Car meets. LSD Peace J.D. Making my car More "Mint"
Old 01-03-2019, 03:52 PM
  #152
peter6's Avatar
It is possible, but it most likely would require outside relay and tapping into the harness at the steering wheel. I was thinking about doing that, but decided that it's not worth.
If anybody wants to use led drl on 07 and 08 models, but don't feel like paying much look up my thread. Some wire and two high value resistors is all you need.
Old 01-03-2019, 04:25 PM
  #153
Received 8,577 Likes on 6,627 Posts
https://acurazine.com/forums/third-g...switch-798978/
https://acurazine.com/forums/third-g...switch-772633/
peter6 (01-03-2019)
Old 01-03-2019, 04:44 PM
  #154
MyGuti's Avatar
Seen these thoiboi, but there isn't a definite answer if anyone got the mod to work on 07-08 years besides the op.....
Old 01-03-2019, 06:17 PM
  #155
So are these fake pics?
Originally Posted by spcslyusarmy
Here is what my 3K HID kit from V-leds looks like, thanks to this DIY for the independent switch!!
Let me know what you think!
Old 01-03-2019, 08:28 PM
  #156
MyGuti's Avatar
Got me there....
​​​​​​but again, all very old posts...
Old 01-04-2019, 02:21 PM
  #157
cblock406's Avatar
I was skeptical when I first saw this thread pop up. They look surprisingly good guys, thanks for being guinea pigs and trying them out!
Old 01-04-2019, 09:21 PM
  #158
jdmvette's Avatar
you order some yet?
Old 01-04-2019, 11:53 PM
  #159
So as an update on my DRL situation, I ordered some resistors and using them, the DRL warning light is now gone, but for some reason the lights still don't turn on. Gonna try and buy some new lights, that's the only point of failure I can think of at this point lol
Old 01-05-2019, 12:07 AM
  #160
MyGuti's Avatar
^^That's interesting. I tried plugging the DRL bulbs in to the stock sockets when I was installing the new headlights and I couldn't get them to work either......
the bulbs look fine, I wonder if I missed something (I did check both sides to ensure polarity wasn't the cause).
even though, I really like the headlight look without the DRLS on. I think it compliments the headlights especially when paired with the NBP.
I would only consider putting LED bulbs in for DRLs in order to match the rest of the headlight.
Quick Reply: New aftermarket headlights? [pics]
