Need DIY on replacing passenger door cable wire inside door.
I took my passenger door panel off and accidentally broke the green plastic after the L shape cable line, so I need to replace the whole cable line but I need to know how to replace it. Does anyone have a DIY for it? http://www.oemacuraparts.com/oem-par.../72131-sep-a01 this is the cable im talking about if you dont know which one im talking about. thanks in advance.
Darn after replacing the cable wire everything works good and when I put everything back together, had to do the window learning and now the lock button works when pressed once sometimes twice, but the unlock doesnt work. I tried searching and I cant find any solution for it, is there a learning process for the lock/unlock button too? everything else works perfect with key fob lock/unlock and driver side lock/unlock works.
cycdaniel
12-17-2019 10:58 AM
tman570
06-11-2019 07:56 AM
