My Review Amsoil MTF vs GM Synchromesh FM
Old 07-24-2010, 10:13 PM
OCD
Roger555's Avatar
When I bought my 06 6spd it had 36K the first thing I did was switch out the oil and transmission fluid. I usually use Amsoil oil so after reading it seemed like the consensus was the Amsoil transmission fluid was similar to the GM stuff so I decided to just go with Amsoil. What a mistake fast forward 6K my 3rd gear is somewhat notchy and shifting in general seems worse actually. Went to the local GM dealer and picked up the GM friction modified stuff last week and swapped out the Amsoil. Initial impression was its different but not the WOW I expected but a few miles later like 50-100 I am amazed at how smooth the car is shifting its unbelievable actually much much better then the Amsoil ever was. SO make the right choice the GM stuff is amazing!
Old 07-24-2010, 10:52 PM
BradE's Avatar
If you really used Amsoil ATF, then you were using it in the wrong application. It's designed for use in automatics, hence the name, ATF - Automatic Transmission Fluid.
Did you use the universal ATF (wrong one) or the manual synchromesh trans fluid (correct one)?
Just so the verbage is clear for those who might be reading this.
Old 07-24-2010, 11:10 PM
OCD
Roger555's Avatar
I never said Amsoil ATF there should be no confusion
Old 07-24-2010, 11:12 PM
craigtl35's Avatar
must be late for you, your title says amsoil atf sir
Old 07-24-2010, 11:16 PM
OCD
Roger555's Avatar
Very true sir I even read over the post before I typed that. Just to be clear this is comparing
To
Old 07-24-2010, 11:20 PM
craigtl35's Avatar
wonderful sir i am sure others will find this helpful i just completed my 3x3 with amsoil atf so this thread caught my attention wish i had a 6mt tho
OCD
Roger555's Avatar
MODS please change the title the ATF to MTF in the title!! Thank you!
Sandals's Avatar
^^^ the titles says Amsoil ATF
EDIT: gotta refresh sooner
Old 07-25-2010, 01:38 AM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
got it fixed! I was going to say ATF + 6spd equals FAIL
Old 07-25-2010, 02:22 AM
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
Good to know so others won't make this mistake. We were just "guessing" which one was better in the other thread.
Old 07-25-2010, 11:19 AM
Wiggy Wiggy Wiggy
powerflow's Avatar
I went from GMSM to Amsoil MTF, no difference to report.
My 3rd gear grind was never that bad though, it was very intermittent.
Old 07-25-2010, 12:17 PM
OCD
Roger555's Avatar
How long ago?? Before I drained the OEM for Amsoil MTF I didn't have much of any notchy 3rd gear symptoms, but they started to develop some time over the 6K I had the Amsoil inside. I'm sure the Amsoil MTF is good fluid but it doesn't feel like it has the same amount of friction modifiers as the GM stuff.
Old 07-25-2010, 07:22 PM
The DVD-A Script Guy
Adobeman's Avatar
Very interesting. I've always been using the GM stuff but read numerous reports of how the Amsoil was supposed to be the exact same thing. Your experience seems to indicate it's not. Anyway, the GM is a few bucks more but I've stuck with it since it's been great. No need to try another brand.
Old 07-25-2010, 07:34 PM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
I may give the stuff a try. Last go around I ended up doing Acura stuff again, supposedly it had been reformatted from the 04 stuff that was in there to begin with. I don't have notchiness to begin with though.
J.
Old 07-25-2010, 08:27 PM
pearlite TL's Avatar
before i even let my car get notchiness..... i have 17000 miles on my car i had it changed to GM at 8000 and been good so far
Old 07-26-2010, 07:38 AM
DMZ
Head a da Family
DMZ's Avatar
I believe the AcDelco MTF Friction Modified is the same as the GM,
Part# 10-4014 88900399
Old 07-26-2010, 07:44 AM
Waltah's Avatar
that is correct.
Old 09-13-2010, 07:32 PM
Gurajit's Avatar
so the third gear notchiness can be fixed with syncromesh then?
Old 09-13-2010, 07:33 PM
That's what everyone has been doing since '04.
Old 09-13-2010, 07:43 PM
LIST/RAMEN/WING MAHSTA 짱
princelybug's Avatar
Originally Posted by Waltah
that is correct.
What's the price difference between the ACDelco and the GM fluid?
Old 09-13-2010, 09:26 PM
Sandals's Avatar
Do they make the GM syncromesh for Automatics?
Old 09-13-2010, 09:27 PM
KoolKatz..
Etohprn247's Avatar
Here we go again.............
Old 09-13-2010, 09:38 PM
You can physically put it in an auto.........
The answer is NO. If you're having troubles with your auto, do a search, there's a ton of info on common auto problems and the fluid and electronics upgrades.
Old 09-13-2010, 09:39 PM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
No. Don't use the GMSM in an AT. A lot of AT folks like Amsoil. Read this thread for more info and how to do a 3 x 3 fluid change:
https://acurazine.com/forums/showthr...=556044&page=3
Old 09-14-2010, 06:12 PM
hondazex's Avatar
part number of gmsm friction modified ??
Old 11-05-2010, 01:08 PM
12377916
Old 05-29-2011, 06:18 PM
con5tant's Avatar
Amsoil MTF safe for our limited slip trannies? On the back of the bottle it says "Not for use in limited slip applications"...altho i ran amsoil MTF in my rsx that had a limited slip with no issues.
Pham Alvan
05-18-2021 06:48 AM
joflewbyu2
08-18-2019 10:38 PM
ITSJESTER
17
12-06-2018 02:29 AM
saturno_v
09-27-2015 08:13 AM
flyromeo3
09-24-2015 11:24 PM
Quick Reply: My Review Amsoil MTF vs GM Synchromesh FM
