On my '04 TL with only 35K miles, should I replace water pump & timing belt?
I have a 2004 Acura TL with only 35,000 miles; should I replace my water pump and timing belt which is recommended at 100,000 miles or 7 years? I'm over twice the time but less than half the miles for that recommendation. The engine runs perfectly with no unusual sounds or performance issues.
Thank you,
Pete
Thank you,
Pete
How likely do you think it would be that the water pump and/or timing belt would fail if I didn't replace it? Very likely, somewhat likely or not very likely?
Thanks again,
Pete
Thanks again,
Pete
rubber deteriorates over time. Plus the timing belt tensioner begins to leak and fail.
15 years is impressive but I would replace it now if i were in your shoes
Why risk it on such a nice car.
Shop the Aisin TKF-004 timing belt kit on the internet, find a local Acura/Honda specialty shop in your area to do the install, save money over what the dealership would charge. Easy Peasy!
Latent car nut
Received 2,005 Likes
Thank you,
Pete
Thank you,
Pete
Acura TL Builder (07-10-2019)
Latent car nut
Lots of good ideas guys, thank you! I forgot to mention that I'm retired now and only drive 300 miles per year. So I might just take my chances and if the worst happens I can always give the car to charity and save myself from having to trade it in when I go new vehicle shopping.
The following 2 users liked this post by Acura TL Builder:
Jackass (07-10-2019),
seinfeld-bassline (08-06-2019)
Thank you,
Pete
Thank you,
Pete
Thank you,
Pete
Thank you,
Pete
I'm and old guy also, but sometimes the logic that I see is somewhat troublesome.
Guess what I'm trying to say is why would one defer the $1000 repair and wait for the belt to go, destroy the valves,
donate the car, then look for something else to buy that is certainly going to cost more than $1000, not to mention the aggravation?
We all know the belt's life will not be infinity, but at what time will it decide to let go, couldn't venture a guess, but our '04 was
changed after 14 years and it looked new, but I say change the belt etc. and be done with it.
Did have a car that had a belt let go after 21 years, but it wasn't a timing belt, just one of four belts at the front of the engine,
but happened to be the one that drove the water pump. Didn't realize that they were on there that long and actually, once
again, the belt looked new, no cracks etc, just split and no damage, just got all four new belts and did an install.
You can take a chance like "The Goose" in the problems & fixes forum, who recently just blew up his engine because his timing belt snapped. See picture in that thread.
https://acurazine.com/forums/3g-tl-p...ptions-980813/
If you live in the snow belt then you should change it. I don't understand the logic either, of not taking care of a car properly then, explode, dump, and spend over 20k again buying another decent one. It obviously costs way more than a timing belt job. It's not so much the belt that goes, it's the hydraulic tensioner that fails over time due to hydraylic fluid leaking out of it, loosening up the belt causing it to jump teeth on the cam gears.
Latent car nut
The Aisin kit is reasonably priced, but it doesn't come with a front main seal as well as cam seals; for that reason alone I'd rather buy the Honda kit.
Latent car nut
Yup, I figured it out a year or so ago; I think buying ala-cart saves a few dollars; I don't remember the price difference being significant.
My TL is pretty low mileage (06, 50k miles) also and I had the timing belt and water pump replaced last year. While the belt itself looked fine the water pump was actually starting to leak very slightly.
There is no such thing as a "Honda kit". Honda kit is what people put together on Ebay. You also don't need the cam seals, they don't hardly ever leak at all. Changing cam seals requires cam gear holding tool and knowledge of dialing in timing while you take the cam gears off. I just did my 3rd timing belt job at 305k miles, they are still not leaking. I did reseal the oil pump because it was leaking BAD. And the crank seal, since the entire oil pump needs to come off to do that job. If anything, the "Honda kit" should consist of oil pump seal, front crank seal, (leave out the 2 cam seals), tensioner pulley, hydraulic tensioner, idler pulley, water pump, timing belt, thermostat, 2 gallons of Honda OEM type-II blue coolant, a tube of Permatex Ultra Grey, 6 Denso Iridium long life or Denso Iridium IK20 power plugs, and a new serpentine belt. That's all the parts I used.
zeta (07-11-2019)
Nope. 60K mile intervals if you drive REGULARLY in those conditions, which rules out any location in North America....
MID indicating a "4" is the only think listed in the SM or OM....No time limit, no mileage limit
horseshoez (07-11-2019)
Latent car nut
Not sure where you're getting your information, but both of my J-Series engines started leaking from the cam seals between 130,000 and 150,000 miles, and based on lots and lots of comments both here and on other Honda/Acura related forums, I am not the only one with leaking cam seals.
And that's not a "Honda Kit", it is a kit by APSG (like everyone else that put it together), stated "Genuine/OEM" fits. Also the OEM Honda crankshaft seal is in the color black, it is not brown or orange. I just put one on and still have the original plastic bag. And that's not the OEM Honda water pump, it is an Aisin water pump. Aisin was the water pump supplier, but the OEM water pump is now made by Yamada Japan. I have pictures of Aisin and OEM water pumps side by side if you need them, I still have both physical pumps in my garage. The OEM water pump still has the highest quality. This kit you listed is under $300 because aftermarket parts are used.
Latent car nut
I'm getting my information from my own engine. I have zero leak around the cam seals. I have 305k miles and 12 years on my AV6 J engine. You need to worry about the rear main seal and the oil pump seal like I said. I worked on this just 2 months ago for 2 weeks, serious oil pump leak, soaking down to the a/c compressor.
Oil pump seal leak, taken 2 months ago. Black all over to the right side of the pump. No drip of oil down from the cam area. Also a picture of OEM crankshaft seal after I inserted it. The OEM crankshaft seal is black in color, not brown or orange as the aftermarket ones. The kit you posted above most likely has aftermarket seals re-sealed into plastic bags with fake Honda stickers. Finally a picture of a real vs. fake Honda thermostat. Real OEM one is on the left, fake one on the right looks way weaker than the OEM one.
Latent car nut
Ha, are you somehow suggesting Amazon is selling counterfeit Honda parts? Geez, for some reason I'm betting you're wrong.
I've gotten fake perfumes and other knockoffs both though amazon directly and 3rd party sellers. Same with ebay, my buddy got fake NGK spark plugs that trashed his civic motor. The print on the NGK was off by a lot. They were listed on amazon and I contacted amazon to remove the listing since they were selling fakes.
You don't have to believe me, if you don't want to. Go and find reviews of Aisin TKH002 on Amazon, there were indeed people that received counterfeit parts, counterfeit Aisin parts. There are many 3rd party vendors on Amazon, that's not of Amazon directly. There are actually parts sold on Amazon, the seller shown as "Honda". I spoke to my local Honda dealer directly, at the counter, there is no such thing as a Honda store on Amazon. Honda sells parts directly online privately dealer by dealer, they source parts from Honda's local warehouses or directly from Marysville, Ohio. You don't know what you are buying until you get a counterfeit part, just like I did. Your "Honda kit" is sold by APSG with mixed parts from Bando, Aisin, and FelPro, that is not Honda. FelPro's cam seals are brown/orange, I know, because I have a set in my garage. Honda OEM cam seals are made by NOK and they are black in color.
Latent car nut
Sorry guys, I strongly suggest counterfeit products will not last very long on Amazon's site; they wouldn't willingly open themselves up to the inevitable law suits.
Latent car nut
All this counterfeit talk now has me thinking if forum member 'losiglow' truly purchased an OEM axle, recently from Amazon, as he believes:
Post #22 on this thread: https://acurazine.com/forums/third-g...enance-980843/
You all have convinced me to get a new timing belt, water pump, tensioners and accessory belt. I've had the coolant and brake fluid replaced on a regular basis so that should be OK. Thanks again for all the thoughtful comments. (Pete)
soghjai
01-14-2019 03:35 PM
desibaba
01-02-2013 05:55 PM
eduardmc
01-19-2010 01:06 AM
Nightpoison
11-08-2007 08:37 AM
