Mobil 1 0W-20 (Advanced Fuel Economy) anybody?
Old 05-04-2008, 09:03 PM
slimboogie's Avatar
Has anybody tried out the new Advanced protection oil from Mobil 1? I've been using the Mobil 5W-20 and I guess this just came out. Supposedly gets better gas mileage. I figured I might as well give it a try. The best part is, I picked up 5 quarts and a Mobil 1 filter for a little over 26 bucks plus tax.
whoops. I meant Advanced Fuel Economy!
Old 05-04-2008, 09:35 PM
KeithL's Avatar
I used to use their 0W20 and loved it, but they don't sell 5qt jugs and at Walmart the 5W20 5qt jug is like $22 vs. $6 a qt for 0W20 when you can find it. SO I am using the 5W20 Mobil 1.
Old 05-04-2008, 09:36 PM
06 WDP / 07 WDP Type-S
Be-in my TL's Avatar
Keith, will sving the 4 dollars make up the difference for the gas milage you would be saving? =P
Maybe it'll save you more gas in 3,000-5,000 miles than 4 dollars, one time fee.
Old 05-04-2008, 09:55 PM
slimboogie's Avatar
Keith,
I picked up the 0W-20 in Augusta, GA. Not sure if they have the same deal going on up in Atlanta. I would have stocked up but the Advance auto parts i went to only had one box of six. I feel you on the 5 qt jug. I was doing the same thing, till I went to visit my folks this past weekend. Tomorrow, I'm going to check Advance Auto here in SC and see if they are doing the same deal.
Old 05-05-2008, 12:26 AM
94 DC4 RS LSV/Turbo
stillhere153's Avatar
JEGS SHIPS FOR FREE...
Old 05-05-2008, 08:34 AM
Tripnbeats's Avatar
i love it!!! the throttle feels more responsive.....the engine feels like it can take a pounding and thats what worries me....uuhhh and economical...no same gas consumption if u ask me. next oil change im gonna do 10w30 to see if the tick goes away.
Old 05-05-2008, 08:46 AM
hates the winter
ChrisQ1980's Avatar
Amsoil 0w30 for me.
Old 05-05-2008, 09:40 AM
[PA] NBP-TL
clavodulce16's Avatar
according to mobil 1 web site i can get about 5 extra mpg per tank! using Mobil 1 0W-20 Advanced Fuel Economy
Old 05-05-2008, 09:45 AM
Tripnbeats's Avatar
thats a crock of shit from mobil... ive been using it for 3 months.....i saw it in fl and thought oh shit i get some extra miles maybe keep the motor running smoother....ummm no same milage and motor shakes for a min til it warms up. it never shook the way it does now
Old 05-05-2008, 10:52 AM
01tl4tl's Avatar
Received 1,137 Likes on 1,067 Posts
you guys crack me up- the first number is the viscosity- flowabilty measured at 32 degrees F, for dead cold starts- that allows instant flow of oil to the important parts
the hot number of 20 or 30 is the actual viscosity at 200 degrees oil temp- normal oil temp when running
the switch from 30 to 20 with the gen3 cars was to fool the CAFE standards, as 20 was determined to be the minimum weight you can run and not destroy the engine parts smashing together at very hi speeds.
It may get .5 mpg better over 30weight, but not the best thing going for many reasons IMO
Do some research before jumping on the oil weight bandwagon
Use a good engine oil cleaner before change and feel better running too
Use engine cleaning in the gas and intake manifold for max increase
Whatever oil you choose may have more cleaners in it- that makes it feel like the engine runs better
That valves clicking on start up may mean they liked the 5 or 10 w over 0
Old 05-05-2008, 11:54 AM
Tripnbeats's Avatar
yes but i get the tick with 5....thats why im going to 10 next time to see if it goes away.....u think ill lose power with 10??
Old 05-05-2008, 02:42 PM
BEAR-AvHistory's Avatar
Received 2,599 Likes on 1,581 Posts
If you are getting at tick on the recommended oil weight you most likely should have the car checked out. Could be a number of different things from needing a valve adjustment to low oil pressure.
Old 05-05-2008, 03:35 PM
KeithL's Avatar
Actually I don't think there is any difference in MPG, I swithced a while back and never saw a differcne, the differcne is the )w vs. 5W and that is all cold starting flow, I like the idea that 0W gets through the engine quicker, but honeslty I have not had a car that long in years to worry about minimal cold starting protection. And actually I should use dino oil since I never have a car long enough for synthetic to matter. I do feel it lubricates better, but that is just me. I was a 3K oil change guy for years even with synthetic, with my TL's I started doing 20-30% on MID now and that is usually 5-6K miles.
Old 05-05-2008, 06:21 PM
hates the winter
ChrisQ1980's Avatar
The gas saving between 5w20, 5w30, 0w20, 0w30 would only show a difference on a dyno. Different drivers, maintence, tires, road conditions, weather, wind, speeds all play a role in gas mileage in REAL TIME conditions.
I like the 0w because it's instant start up protection where most wear occours. I like 30 for operating temps because in the spring/summer here in NY the temps/humidity can be brutal and I'd rather have a lil extra protection over the 20.
In the winter I'd want the thinner 20, so base it off of that. Temp is the key factor in deciding oil. You can't go wrong with either of the above listed oils for the 2nd gen TL assuming you have an engine that is in good condition.
If the engine is making abnormal noises, then take it to a Honda/Acura specialist, or the dealership and find out what is wrong before you go experimenting with different oils.
Old 05-05-2008, 07:21 PM
01tl4tl's Avatar
I can see some logic points in this thread and som e not!
do not use 10w- our engines like 5 or 0 for the far north guys
30 is good for the warm number- I find it funny that some think the engine operating temp drops in winter- should be right in the middle of the guage like always-
Old 05-05-2008, 09:01 PM
flydog's Avatar
If that oil really gets better mileage than regular oil then I will drink a quart.
Old 05-05-2008, 09:39 PM
blueracer17's Avatar
Yeah, but that handling charge will get you every time (used to be about ten bucks)
Old 05-05-2008, 10:34 PM
firstpickrick's Avatar
hahaha i had like 3 set of those deals stocking up
yesSIR-S
05-13-2016 05:42 PM
drone619
01-26-2016 07:09 PM
Mr.Tea
1/2G MDX (2001-2013)
26
10-09-2015 04:27 PM
MyBlackBeauty
Canada
09-14-2015 05:28 PM
Quick Reply: Mobil 1 0W-20 (Advanced Fuel Economy) anybody?
