Notices
Third Generation TL (2004-2008)
Misfire DTC and TSB 03-033 question
Old 09-28-2015, 09:22 AM
Registered Member
thegipper's Avatar
So every few months my check engine light flashes and I get the P0301, P0305 and P0300 codes when I go WOT. The light goes away after a minute and the performance never changes, drives perfectly normal.
I know that there is TSB 03-033 which is a software upgrade to fix this exact problem. Apparently there is some issue with the old software that "incorrectly interprets sensor inputs, causing the codes to set". I'm 99.9999% sure this is my problem, so I just need the TSB done.
I called my local Acura dealership (Acura of Brookfield) and the service guy I talked with was an total idiot.... I asked if he could check my VIN to see if this specific TSB has been performed on my car and he said "there are no recalls on your car right now". I said great, I want to know if this specific TSB has been performed on my car or not, he again said there are no recalls and if I'm having a problem I should schedule an appointment to have the car looked at.
After going back and forth with him and explaining that there is a difference between recalls and a TSB I finally got him to look up my VIN and he said that this specific TSB has NOT been performed on my car. That is all I wanted his dumb a.. to do.
I asked how much it would cost to perform this TSB and he said they would have to diagnoss my car. I explained to him again, I don't want it diagnosed, I want this specific TSB done to my car which it applies too. He then tells me he can't give me a price and someone would have to call me back who knows.
What a moron. Anyways, my question for you guys is what is a fair price to have this updated software flashed? Also, if I don't have it done, is this something that will damage or effect the car? Is it pretty important that I do have it done since every once in awhile when I go WOT it does have the codes come up?
Here is a link to the TSB if you are not familiar with the one I'm talking about. I tried using the link found on Acurazine but when I click on the blue "link" button it brings me to some Estore, not sure if the link is messed up or what is going on. Either way I can't view any of the TSBs following the instructions on the page.
https://drive.google.com/file/d/0B2F...ew?usp=sharing
Thoughts?
thegipper is offline
Old 09-28-2015, 09:55 AM
Registered Bunny
polobunny's Avatar
Received 1,061 Likes on 886 Posts
No, it will not break your car. Essentially it goes into limp mode to protect your car from a possible problem (which is not a problem but a false warning in that case).
As for the price, really depends. I wouldn't expect more than 1 hour of their time for ECP/PCM update + relearn and because it's a dealership I wouldn't expect less than 1 hour either.
polobunny is offline
Old 09-28-2015, 10:29 AM
Registered Member
thegipper's Avatar
Got a call back and they said it would be $75. should I try getting a quote from a Honda dealership or can they not do it?
Old 09-28-2015, 11:01 AM
Registered Member
nfnsquared's Avatar
Received 1,674 Likes on 1,262 Posts
On the one hand, $75 isn't bad at all, but the MIL is happening due to a programming issue caused by Acura, not you. I'd push it up to the district manager and ACS and try to get it done for free.
nfnsquared is offline
Old 09-28-2015, 11:04 AM
Registered Member
thegipper's Avatar
Based on my prior experiences at this dealership, I doubt they will ever do anything for me for free minus a recall.
worth a shot I guess. What about a Honda dealership?
Old 09-28-2015, 01:01 PM
Registered Bunny
polobunny's Avatar
I'd take it for $75. Honda should be able to do it too, they have all that's necessary. They might not want to though, sometimes they're like that.
navtool.com
3G MDX Discussion (2014+)
32
01-20-2016 11:43 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
flybyglass
Fifth Generation TLX (2015+)
09-24-2015 01:12 PM
JOE COOL
2G RDX Problems & Fixes
09-24-2015 07:15 AM
Quick Reply: Misfire DTC and TSB 03-033 question
