Notices
Third Generation TL (2004-2008)
Manual transmissions
Old 02-01-2019, 09:16 AM
Registered Member
Recieved 1 Like on 1 Post
I've got a 04 acura tl speed with the third gear grind. I'm getting ready to put a new clutch and flywheel in it and was going to replace the transmission also. Question I'm asking is, are 04 to 08 manuals all the same, and will a 07 to 08 type s manual transmission work on my car?
any advice on this would be extremely helpfully
Jbtech83 is offline
Old 02-01-2019, 09:22 AM
Registered Member
horseshoez's Avatar
Recieved 813 Likes on 606 Posts
W-A-I-T! Before you do anything else buy three quarts of the following gear lube and put it in your transmission:Notes:
  • Make sure you buy the ACDelco Synchromesh Friction Modified version; they also make a non-FM version which is useless in our transmissions.
  • If you do a search here you will discover roughly 90% of the folks who have complained about 3rd gear grinding and/or pop-out issues have had said issues solved immediately upon replacing the MTF.
  • To answer your question, yes, all of the 3G TL manual transmissions are the same, however, the bellhousings are not.
horseshoez is offline
Old 02-01-2019, 09:24 AM
Registered Member
Recieved 82 Likes on 68 Posts
I believe 07-08 bellhousing is different. First off have you tried switching your transmission fluid to the GM syncromesh fluid? And also why not just rebuild your transmission? A lot of transmission rebuilders can rebuild a manual with ease compared to an auto
90foxnotch is offline
Old 02-01-2019, 09:25 AM
Registered Member
Thumbs up
Beat me to it!
horseshoez (02-01-2019)
Old 02-01-2019, 09:28 AM
Registered Member
I've already done the fluid change right after I bought the car. Hence the reason I'm going to put new transmission in car. Can I use my bellhousing on the newer transmission?
Jbtech83 is offline
Old 02-01-2019, 09:30 AM
Registered Member
Because I can get a used transmission for alot cheaper than rebuilding it and repairing it
Jbtech83 is offline
Old 02-01-2019, 09:43 AM
teh CL's Avatar
Recieved 637 Likes on 469 Posts
Yup, just swap yours over and your good to go.
I'm sure there's cheaper non Type S 6spds available.
teh CL is offline
Old 02-01-2019, 09:48 AM
Registered Member
Cool that's what I needed to know. Thanks and I know there are lol I'm just keeping my options open when looking.
Jbtech83 is offline
princelybug
03-19-2011 09:36 PM
InWI
Second Generation TL (1999-2003)
02-06-2010 11:53 AM
StonedCL
31
08-29-2009 09:58 PM
nokiaman
11-27-2007 04:29 PM
danmcgraw
Second Generation CL Discussion (2000-2003)
30
12-19-2006 09:47 PM
Quick Reply: Manual transmissions
