How to bleed clutch fluid
Old 08-20-2018, 08:07 PM
drsides's Avatar
Looking for suggestions on a one-man way to bleed clutch fluid... I've gotten kind of frustrated with the v
acuum type like this acuum type like this
I'd prefer
positive pressure type (like Motive) positive pressure type (like Motive)
but I don't think there are any that fit our clutch reservoirs. Pls make some suggestions.
thanks.
Old 09-04-2018, 11:12 PM
racerock's Avatar
Just use the classic vacuum tube to a Mason jar two person process.
- but first make sure your bleed port is clear to pass fluid when bleed screw is opened.
- went through an 05 after purchase and there was so much hardened crud, had to remove and disassemble slave cylinder to clean out.
Old 09-05-2018, 04:26 PM
The DVD-A Script Guy
Adobeman's Avatar
Also had bad luck with vacuum type bleeder. You might be able to fabricate a cap for a positive pressure method as it really doesn't need to seal for very high pressure. In the end I just went back to the two person process as racerock suggests.
You may want to limit the slave movement as described in this scan from the SM
dstah
05-13-2012 07:56 AM
Waltah
07-27-2010 02:58 PM
veo
1G TL (1996-1998)
14
04-02-2006 01:05 PM
Quick Reply: How to bleed clutch fluid
