Notices
Third Generation TL (2004-2008)
J35A6 swap
Old 06-12-2019, 12:31 PM
New Member
J35A6 swap
So over the weekend I went from 3rd to 2nd at about 6700 rpms, motor now has a loud tick. Top end. Rather than tearing it down I'm thinking about swapping in a j35a6, i just wanted to know if i can straight drop it in or will i need to modify anything?
Josh Honigford is offline
Old 06-12-2019, 12:35 PM
Received 5,873 Likes on 4,712 Posts
What year car do you have?
thoiboi is offline
Old 06-12-2019, 12:37 PM
teh CL's Avatar
Reuse your engine harness & intake manifold. The A6 doesn't have the IMRC control on the manifold like the TL.
Also, make sure it ONLY comes out of an EX or LX. The EX-L/Touring models have a J35A7 with VCM & you don't want that drama.
teh CL is offline
The following 2 users liked this post by teh CL:
Josh Honigford (06-12-2019), Saving4aTL (06-12-2019)
Old 06-12-2019, 05:37 PM
New Member
An 05 base with nav
Old 06-12-2019, 05:41 PM
New Member
Right on, so pretty much plug n play. My next question would be since the 3.2 is a high compression engine and the 3.5 isn't that not gonna throw the ecu for a loop will it? I dont really think it'll matter but I just wanna be sure before I do this. I'll drive it till it goes completely just wanna get everything straight before that time comes.
Old 06-12-2019, 07:31 PM
Registered Member
horseshoez's Avatar
I thought the J35A6 from the 2005 Honda Pilot was also a direct fit. Yes, no?
horseshoez is offline
Old 06-12-2019, 07:59 PM
Registered Member
truonghthe's Avatar
Nice to see that you still retain the knowledge of J series after having fun with CTS-V tho.
truonghthe is offline
Old 06-12-2019, 08:35 PM
teh CL's Avatar
Never looked into the Pilot motor but it should be an identical swap.
You'll have no issues at all with the stock TL ECU. I've had an A6 in my 05' 6spd TL for almost 2 years issue free.
teh CL is offline
wallawalla
06-10-2019 06:35 AM
Trinidad Valladolid
06-09-2019 04:57 PM
Layton1
Acura ZDX Discussion
06-07-2019 05:55 PM
cp328
05-27-2019 06:34 PM
MrVtech
Second Generation RL (2005-2012)
05-22-2019 12:06 PM
Quick Reply: J35A6 swap
