It's official. '06 AT TL has no top speed governor.
I finally got to do it after my first attempt that got interrrupted by a highway patrol. I had nearly 20 miles of straight downhill freeway in front of me with nearly no traffic. Tires were at 40psi and Z-rated so I went for it. Didn't take that long to peg the speedo since this was a pretty good grade. I hit just a hair north of 160mph with it still barely climbing and backed out of it. Previous best on flat land was ~152mph. This is indicated and I'm sure the speedo is off by a few mph at that speed, especailly with my .10" smaller diameter tires. Regardless of actual speed, the computer saw over 160 and didn't cut power.
Undying Dreams (04-10-2014)
Originally Posted by fant0m_TL
lol.... brush up with the highway patrol, eh? howd that work out? you get a ticket?
Originally Posted by stillhere153
dude you need a vid or I wont bite, TLFourPlay maxed his TL-S at 150, and which is it rev limiter or governer I am still wanting to know
Originally Posted by I hate cars
Regardless, why would my auto TL let me go 160+ and the TL-S is governed.
I think the governor may in the form of a RPM limiter. Since the TL maxes out it's RPM's most of the time to get up that high, it might be just hitting the RPM limiter.
Originally Posted by mishar
Probably 06 TL Auto doesn’t need limiter because it can’t go faster than 156 mph on a levelled road. On the other hand 07 TL-S 6MT can and they introduced limiter. Most German cars are electronically limited at 156 mph or 250 km/h.
Originally Posted by Timmahh
Ehh...
Your mother chiming in here..
Please tell me why and when we ever need to go above 100mph.
Sincerely,
California Highway Patrol
Sincerely,
it's me, Alan Rickman.
Most of my street racing friends grew up to be highway patrol.
I know some CHP officers and a member of my family does.. stuff..
.:KCCO:.
bad thing is, you "put" more miles on the car then you actually do AND your speed goes "up" cause of the smaller diameter. at speeds that high, it is a noticeable difference.
Originally Posted by ayethetiense
the computer never saw over 160, only your needle did. the same thing happened to my last car, larger rims but way thinner tires, so it was smalelr overall.
AZ Community Team
Received 7,770 Likes
TLFourplay's top speed runs hit the Redline (rev limited) at ~152 in 5th gear. He hit ~152 in 6th gear with plenty of room before the redline.
I Hate Cars: What gear and what RPM when you had ~160 indicated?
AZ Community Team
Originally Posted by Bearcat94
Not so sure about that.
Originally Posted by TLFourplay
Exactly. Basically at 150mph in 5th gear I am running about 250rpm's less than redline, and at 150mph in 6th gear I am running about 5200 rpm's. If drag wasnt an issue the car could do 198 before being "redlined" in 6th gear. I dont really know why the hell an auto TL would not be limited and a Type-S would. If that is in fact the case than maybe its because a stock TL-S has the power to do those speeds and a stock auto 3.2 TL wouldnt realistically have that much oomph to surpass 150 on its own. who knows though. All I know is I proved that the 07 TL-S 6spd DEFINITELY has a fuel cut off at 150mph. And that was when my needle hit 150, I have never been over 150 with my stock 17's or my RJ 19's.
Originally Posted by 3rdGenHybrid
im not sayin that your wrong or anything.....but i had my TL and TL-S both up to 155 on flat land....no hills....the TL is an 05 AT....and the TL-S is a 6spd....the only thing with the auto is the longer gears....but still the 6spd hit 155 alot faster than it did in the 5at....(derrrr bigger motor...shorter gears)
oh it definately does have a govenor....i agree on that....next time i get up around that speed...ill have a buddy snap the pic....at 150+mph i dont wanna whip out the camera and start clicking photos..hahaha
Yes... It's called the wind.
Be kind to us truckers !
Dude I can't wait till someone cracks the ecu... acutally let me take that back cuz then tlfourplay will do 198mph
See I hate dumb crap like this. Gets me all fired up inside. Some "person" was arguing with me a while back that TL's are drag limited and dont have governers and when I posted my top speed vids SHOWING the car dipping down each time I hit the governor and also pulling very hard to 150 he didnt have anything to say. Either prove it or stop talking about something you dont know about. The TL has a governor. PLEASE prove me wrong and take a vid of doing over 150mph. How the hell would every TL be magically drag limited to 150mph....
IF I ever do it again, maybe I'll take a picture but not likely. This was the 15 outside of Vegas and I really don't feel like going to jail or killing myself or someone else. I've already proved it to myself. You can believe me and try and figure out why my car is not limited and yours might be or you can not believe me and feel secure thinking yours has a limiter.
One point to bring up is I've been 152 on flat ground before. The speed would hover around 150, drop a few mph, back up to 150, and finally topped at 152. At those kinds of speeds all it takes is the smallest undetectable incline or gust of wind to drop you a few mph and make it seem like you've hit a limiter.
bro...your going off the fact that your car did 160 on a downgrade....i could drop your car off a cliff and make it do 200.....the car will cut fuel or spark(which ever one honda uses..) before 160....but since gravity is pulling your car down hill...and u have all that momentum pushing up behind you....with a big enough downgrade....you could probably hit 180....we're talking flat land...
It's not true. If you're governor limited at a certain speed, the ECU still won't let you go past that limit even if you go downhill. Unless you're on a very very steep downhill.
I've touched many cars speed limiters (mainly rentals) while going downhill and I can tell you that when the ECU cuts the fuel delivery, you're slowing down. No question about it.
I don't have pics or video to prove it, so if you don't believe me, it's your call. I once took my car to more than 155 mph (indicated) and I didn't feel any governor limiter kicking in either. My car is 05 with 6MT.
i agree....on flat land...if your car cuts off fuel/spark...your car will slow down...but this guy is talkin about downgrade...
if the car does cut fuel...and your doing 155 on a downgrade and lets say you put it in neutral, 3500lbs is pushing you down that hill....even with resistance...momentum will still "push" you....so now your "free wheeling" at 155mph....and gaining more momentum...so cuttin fuel wont do anything....go try it....you'll go faster on a downgrade then you could possible go on flat land....
Actually...not all cars cut fuel delivery...especially turbo cars....the last thing you want is to lean out a turbocharged motor....
But i can tell you hondas has some lazy limiters. The 2nd gens are supposed to be limited to 149 and i was clocked at 157 by radar (friend who is a cop)and my limiter never kicked in while others have had it kick in at the correct speed
I've been on hills with twice the incline of the one in question and the car wouldn't coast past 90mph.
When I let off the gas STILL ON THE INCLINE, the car lost speed very quickly.
How can you possibly think an automobile will coast at 150+mph on a 6% grade? Maybe I could've hit the revlimiter in 5th gear at 200mph going by your logic.
I did this on an incline because the TL does not have enough power on flat land to push it to 160. My whole point was to prove that my car does not have a limiter at 150 which I did.
94 DC4 RS LSV/Turbo
Ok this one time I coasted down an incline at 40 I was doing 10 over... lmfao
Dude we are like that guy in the bible see to believe lol
Tlfourplay showed me that rev limiter is at 150 so honestly without proof who knows
Well, since I've been 160, I would say it's not limited to 150...
In closing all I have to say is that 07 TL-S is speed limited to 150mph. Also car and driver has always posted that the TL is limited to 152mph.
Regardless of rims I have on, going uphill or downhill with or against the wind my gauge has NEVER went beyond 150mph.
You are so wrong in this... the drag of the wind is SO high that you will INSTANTLY start to slow down if you do not have the engine keeping you at that speed... no incline is enough to overcome this drag, even going down a mountain...
94 DC4 RS LSV/Turbo
Man I don't even think this is worth discussing... I mean TLFOURPLAY maxed it out and his is worked... I mean the guy put all the mods available into the 07... so no words to that
