Interior color code
Old 09-20-2011, 10:13 AM
scarylarry1's Avatar
Interior color code
guys,
i've looked, but i haven't seen a clear explanation (at least to me) i have a dgp 2004 tl with the light brown, cream interior.
the door tag says type-c. i've seen it called a bunch of different things, camel, parchment, light cream, etc. which one is correct?
thanks,
larry
Old 09-20-2011, 11:21 AM
Q('.')=O
imj0257's Avatar
camel is what acura calls it
Old 09-20-2011, 11:22 AM
Received 16,266 Likes on 11,974 Posts
caramel is what i call it.
Old 09-20-2011, 11:28 AM
thanks!
Old 09-20-2011, 11:29 AM
3G TL/2G MDX Owner
TLtrigirl's Avatar
tan-ish...most likely "camel." parchment is more of a cream/off-white color (its the lightest of all the interiors, i believe). they also have taupe, but i think that's a newer flavor for later models which is in between the parchment and camel.
Old 09-20-2011, 03:24 PM
Turbonut's Avatar
Check the door pillar on the diver's side about 3" above the tire information.
A Graphite Black
B Moon Lake Gray
C Light Tan
D Light Cream Ivory
NBP-UA6 (09-20-2011)
Old 12-11-2014, 10:37 PM
Chad05TL's Avatar
My door says Type C, and I always buy *YR240L* (LIGHT CREAM IVORY) and it always matches.
The weird thing is, I know they make a lighter color of tan and they make a darker color. The lighter color I am thinking of is an off white. The darker color is a Camel color which I see on the 04's a lot.. But nothing on the parts pictures says Camel.
And even more particular, when I logged onto owners.acura.com like 3 or 4 years ago, it said my color was "parchment".. but today when I log on, it says nothing about color..
All i know is I order *YR240L* (LIGHT CREAM IVORY) and it matches pretty close or exact.
(I had my seat out because I was swapping the OPDS with an 07/08 OPDS. And I swapped a few small sub-harnesses that are contained within the seat only and are removable. I am doing this to get rid of my airbag light after the new cluster I installed. ( I bought a rough 07 seat from LKQ locally in dallas for $119.. and took out the opds and the sub-harness.(which might be able to be purchased from acura.. So, that made the swap more convenient and pretty cheap.) Actually, the seats are plug and play with my 05, but the new seat I got kinda smelled.. So I had to swap components and I spliced in the seat sensors since they are glued to the foam. I will make a post about it later.
Old 12-12-2014, 04:13 AM
Turbonut's Avatar
[QUOTE=Chad05TL;15266733]My door says Type C, and I always buy *YR240L* (LIGHT CREAM IVORY) and it always matches.
You are correct.
Didn’t remember posting this, but the following posted 3 years ago is incorrect. The letter designation is a suffix to the part number but has no reference to the interior code.
A Graphite Black
B Moon Lake Gray
C Light Tan
D Light Cream Ivory
Part numbers for the various colors:
Graphite Black NH167L
Moon Lake Gray NH528L
Light Tan YR167L
Light Cream Ivory YR240L
snorf
11-04-2019 06:44 AM
handsom-hustla
11-13-2015 05:04 PM
PortlandRL
09-14-2015 12:01 PM
siularbar
1/2G MDX (2001-2013)
09-11-2015 10:40 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: Interior color code
