Notices
Third Generation TL (2004-2008)
Injector R&R
Old 01-31-2019, 10:56 AM
New Member
Recieved 0 Likes on 0 Posts
Injector R&R
Are there any gaskets I will be replacing as I get down to the injectors? Before I start pulling her top off and leaving myself walking to the parts store for gaskets I'm not sure are there or not?
William Morrison is offline
Old 01-31-2019, 11:45 AM
Registered Member
peter6's Avatar
Recieved 79 Likes on 72 Posts
You will need to pull the intake off, so all the gaskets that are involved in that might need to be replaced.
That is gasket under that upper plate and under the intake manifold:
(this picture came from 07-08 service manual)
Additionally injectors have rubber o-rings on them, but new ones should come with new o-rings.
Injector base stays on the car, and you shouldn't need to remove throttle body, so those gaskets don't need to be replaced.
peter6 is offline
jevans06
02-26-2014 04:36 PM
step_sticky
07-23-2012 11:51 PM
Sly Raskal
Second Generation CL Discussion (2000-2003)
06-18-2006 12:54 AM
803Twon302
05-11-2005 08:32 PM
show-n-go
First Generation CL Discussion (1997-1999)
04-03-2002 09:16 PM
Quick Reply: Injector R&R
