I'm pushing my luck on getting an oil change. Opinions?
My MIL says I'm overdue on getting my oil change and I am now 360km over (226 miles).
I got my last oil change done in August of 2013.
The color is a dark brown and still very liquid and fluid.
The smell is slightly off - similar to when the car starts and there is that nauxious gas smell in the garage of gas-fumes or exhaust-like fumes. So I guess the oil is old but I don't think it is completely used up.
The level is on the lower 1/3 of the cross-hatched pattern at the bottom of the dip stick, so its still within level, but it is rather low.
The temperature outside on average these days is a bout -15C or 5F.
My scheduled appointment on January 6th. Today is December 30th.
I think I am good until this date. What are your opinions? Am I good, should I get an oil change pronto? Should I at least top off with some oil and get it completely redone on Jan 6th?
The following 4 users liked this post by GRAF-FITI:
designer (12-30-2013)
Jk.
The following 3 users liked this post by ggesq:
You'll be fine. I have gone 500 over but always use synthetic so I wasn't too concerned. Just don't redline the motor if you're using a conventional oil.
You're fine. And you can't tell anything by the color, don't let that worry you. And if it's in the cross-hatch area, it's not low...
The following 2 users liked this post by nfnsquared:
Acura_Dude (12-31-2013),
designer (12-31-2013)
Your fine. I'm sure we all went over 200 miles at one point. Or just me being lazy this past month haha. I'm over 200 miles for sure. Doing mine tomorrow
My first ricer
I don't know what oil you're running so I can't say, but on an old Chevy I had, the owner's manual said to change the oil within 500 miles after the change oil light came on. My TL says I have 0 miles range left when I have 3 gallons of gas still, there's a reason they call them idiot lights, you'd have to ignore it way too long for it to be an issue. If you have synthetic oil and a good filter I wouldn't sweat a few extra thousand miles.
it's a car-drive it
when we went on our first cross country roadtrip-had the oil/filter changed before the trip. By the time we arrived home it show almost 2,000 miles past due. Fast forward 6+ years and 150K miles-still running excellent.
You know when your oil starts to get low on the dipstick it is ok to add to fill it up, in fact that is advisable. It won't do a lot of damage if you don't but it is always better to have an engine with the correct amount of oil in the pan. Otherwise...no worries.
Received 6,470 Likes
Yep, you'll be fine. Just don't take any cross-country trips.
I wouldn't worry about a few hundred miles over the MID even on dino but I wouldn't make a habit out of it.
My friend had a Mustang that went through so much oil, a quart every couple weeks, it went over 80,000 miles without an actual oil change. Even a quart of oil over the normal interval is good, bringing more additives and raising the TBN and lowering the TAN.
rockyboy
12-06-2022 02:29 PM
mugen_kid
11-13-2015 10:38 PM
CheeseyPoofs McNut
10-11-2015 11:25 AM
