How often do you change your oil?
Old 12-24-2012, 08:54 PM
  #81
I hate cars's Avatar
Received 1,811 Likes on 1,282 Posts
Originally Posted by TLtrigirl
^^it's been done by the old timers that have moved on. check the 3G garage for those threads. IIRC the "road rage" journals might have that info.
Yes it has, over and over and over and over and over again and the same questions still pop up.
MID is nothing more than an algorithm with total engine revolutions, average trip length, and ambient conditions being the largest contributors.
Mine will say to change it at 3,000 miles if I only drive it the 2 miles to work and back because it never has a chance to get fully warm and burn off the condensation and acids. I've had it take me out to 10,000 miles when I was commuting 210 miles a day. There is no "sensor" in the oil pan to monitor oil condition. I usually set 5k as the upper limit and change sooner if the MID says so.
I've done the calculations, they're on this board, the difference in total engine revolutions between city and freeway driving. The engine will be turning less total revolutions in 10,000 miles of freeway use lugging around in top gear than it will in 3,000 miles going from 0-50mph over and over again in city driving. Engine revolutions are a far more accurate indicator of use. It takes into account idle time, high rpms, lugging around in top gear, etc, than mileage does.
After a point it no longer matters how long the oil itself can go, the contaminate load is what matters. Short trips in the winter will introduce many more contaminates than long trips in the summer and even if the oil has a lot more life left in it, you still have to dump the crap out that accumulates.
Most decent oils are capable of 10,000 miles under the right conditions.
I run a 50-50 mix of Redline 5w-30 and Redline 5w-40 in my TL. It comes out to a 12.85 cSt at 100c which just barely misses the 30wt category but it has a 4.2 HTHS which is incredibly high and will practically stop wear from occurring. It still has great cold flow. This car has had a 30wt in it almost since the beginning when it was brand new. It's had a 0w-20 when I was doing a 1 mile drive to work in 17F weather. The rest of the time it's had either a straight 30wt or a 5w-30. Now I'm experimenting with the 50-50 mix of the 30 and 40wt for fun. It's never been so quiet before, even at 113,000 miles. Still though, I'll probably do a valve adjustment since I'm off for the next couple weeks.
So, MID has no sensor, it does not know what's in it.
The MID can vary drastically depending on driving conditions, 3k-10k from my own personal experience.
Most oils will go 10,000 miles before the additive pack is depleated or it's sheared or thickens from oxidation but you still have the contaminate load that needs to be dumped.
The 20wt is driven by government fuel economy standards (CAFE). Look at the UK site for Acura recommended oil viscosities and you'll see that they recommend everything from a 0w-20 to a 10w-40 in the 2013 TL 3.7L. In the 2006 Honda Legend, Shell shows 0w-30 as the recommended oil. You'll find just about anything acceptable into the 10w-40 range for these cars in other parts of the world where the government is not mandating a 20wt. American OCIs are generally shorter as well because there's no safety cushion, if the oil sheers any thinner, excessive wear occurs. This is why I have absolutely no problem running a mix of 30 and 40wts since it falls right into the average viscosity recommendation.
TLtrigirl (12-25-2012)
Old 12-24-2012, 10:12 PM
  #82
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
Originally Posted by I hate cars
.... Look at the UK site for Acura recommended oil viscosities....
Interesting, since AFAIK Acura doesn't sell a single model in the UK or anywhere in Europe for that matter. Got a link?
Old 12-24-2012, 10:59 PM
  #83
It's very hard, follow closely, this one is not in the manual. Look up "Honda" on any given UK site. Next, find the corresponding car/engine. I'll give you a clue since google may be of no help here leaving you at a dead end. Look up "Honda Legend" for beginners. You might be able to figure out the rest.
Old 12-24-2012, 11:35 PM
  #84
nfnsquared's Avatar
Ahhh, you meant:
UK oil vendor recommendations, not Acura's recommendations. Got it. Glad we got that cleared up for everyone.
Old 12-25-2012, 12:30 AM
  #85
Ahhh, you meant:
Google must've failed you. Keep searching. I've got a family to get back to while you're "educating" yourself.
Old 12-25-2012, 12:37 AM
  #86
nfnsquared's Avatar
^^^In less time than it took you to type that you could have just posted the link... that is, if you had one...
But as I've already said, your statement refers to UK oil vendor recommendations, not Acura recommendations. If that's not the case, feel free to clarify it for us.
Old 12-28-2012, 04:44 PM
  #87
Ctla4ig's Avatar
I have a headache from all this information
Old 12-28-2012, 04:52 PM
  #88
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
^^^ just do it every 5K miles if you use synthetic and 3K miles if you conventional
Old 12-28-2012, 05:53 PM
  #89
RaviNJCLs's Avatar
5W20 when the MID tells you too. Its not that hard. I use Mobil 1. And I'll get about 7-8k miles per change.
TLtrigirl (12-28-2012)
Old 12-28-2012, 05:56 PM
  #90
swoosh's Avatar
^^^ 7-8K changes depending on amount of highway/city miles....so i just stick to 5K miles LOL
Old 12-28-2012, 08:37 PM
  #91
RaviNJCLs's Avatar
Yep.
I do mostly highway. But follow the MID.
Old 12-28-2012, 08:52 PM
  #92
flappy paddles
Otacon's Avatar
Justin,
Last warning....I'm saying this in public so there's no question about this.
Lay off of TerpNation. The next name calling escapade-you get a vacation.
Last warning.
This is easily the most care bear fucking forum I've ever been on.
Old 12-28-2012, 09:01 PM
  #93
swoosh's Avatar
its been 2 months since that post dude...let it be
RaviNJCLs (12-29-2012)
Old 12-29-2012, 10:03 AM
  #94
RaviNJCLs's Avatar
He held in his feelings for that long.
Old 12-29-2012, 06:19 PM
  #95
Series Motor's
TrustinHFDJ's Avatar
Well it depends are you using syn or fully syn... next comes the weight of the oil, and lastly the outside temp, all of these factors play on how fast you need to change oil. I rarely use the oil life, which the car indicates, but in my car it is doing 642 mi per 10%. By calm I mean that I do not maintain fast accelerations, I enjoy driving really fast, I'm too kind to my first gear. I use Acura Syn Blend because I get it for almost nothing; OCI 5.5k
5-6k is the best in my opinion for the Type S, base I would push to 6 minimum.
Old 12-29-2012, 06:21 PM
  #96
winning_blue's Avatar
every 4k or so
Old 12-29-2012, 07:10 PM
  #97
tihomirbg's Avatar
Twice a year. I try to do it before it gets really cold- October or November- and then March or April for the summer. What i do though- i use 5w20 during the winter and 5w30 during summer time. I also put in only 4.5 qrts and never more. The level always goes a little over maximum though which i guess is ok.
TrustinHFDJ (01-05-2013)
Old 01-05-2013, 09:14 PM
  #98
Series Motor's
Really? strange, mine is barely above with 5 full qts.
Old 01-06-2013, 12:57 PM
  #99
#GOBULLS
RyanCHICL's Avatar
I don't drive very far for work and school, so I do a yearly OCI every July. The MID is usually around 30-40% when I change it.
Old 01-06-2013, 07:29 PM
  #100
makk's Avatar
5/20 synthetic since second oil change in 04. Switching to 0w/30 next change. Valve train is immaculate and runs like day it left the showroom.
Old 01-09-2013, 08:47 AM
  #101
Desert Life Sucks!!
sauceja's Avatar
I change mine when mid says 20%. Mobil 1 synthetic 5w20 with genuine honda filters.
I drive hard...
Old 01-09-2013, 09:02 AM
  #102
sleeper22's Avatar
I change mine at approximately 5000 miles and use a Kendall blend a local Tire Shop stocks. Oil change cost me around $20 and my oil always looks clean. I drive 60-70% highway and I am very easy on my car. Very rare for me to get in the upper RPM's so I'm comfy changing at 5000 miles.
Old 01-09-2013, 09:56 PM
  #103
LaCostaRacer's Avatar
^ really- your oil is 'clean' after 5000 miles? There's no dark brown color at all? The only thing I have drained that was 'clean' is our Pilot's rear differential.
I just checked my Honda Pilot's oil that has just 300 miles since its Mobile1 change and the oil is a darker shade of yellow/brown than the light gold Mobile 1 is normally. The oil is not black, but it is certainly not clean compared to new.
I usually change the Pilot every 6k miles (no MID) and the oil will be dark. Even dark, the oil has still a lot of life in it. The darkness in the oil is not the only indicator of oil life but it adds comfort.
My TL is changed by MID interval which is usually around 6500 miles @ 10% MID life and it's often dark.
Old 01-09-2013, 10:23 PM
  #104
I would be nervous about an oil that stays clean for the whole oil change interval. I would be investigating the detergent level.
Old 01-09-2013, 10:36 PM
  #105
swoosh's Avatar
yes, my oil is clean as well...it has no bolts and screws in it when I change it
Old 01-10-2013, 05:43 AM
  #106
RaviNJCLs's Avatar
Mine is a nice dark brown color. Same as every other car I have had.
Old 01-10-2013, 05:46 AM
  #107
sleeper22's Avatar
I'm not saying its as clear as when it was changed IHC but its not real dirty or black. It's not fully synthetic but a blend. Don't fully synthetics get darker much quicker? The Mobil 1 in my Triumph Speed Triple and all the other bikes do get dark rather quickly even though there is plenty of life left. Bikes rev much higher and stay in the upper RPM ranges usually more than cars and especially my car.
Old 01-10-2013, 05:47 AM
  #108
sleeper22's Avatar
WOW space age protection. Cool let us know where you get this invisible oil lol?
Old 01-10-2013, 10:32 AM
  #109
BANNED
SharksBreath's Avatar
Received 2,885 Likes on 1,784 Posts
wat.
Old 01-10-2013, 11:10 PM
  #110
'04 TL w/ Navi
drumz0rz's Avatar
I usually ride the MID down as close to "Service Due Now" as possible, a few times pushing into the "Service Past Due". I use full synth, and honestly I've never been too worried about it. The engine runs like the day it rolled off the showroom floor despite years of mashing the pedal to the floor.
I once had a mechanic at one of those quick lube shops (I was in a rush) tell me some BS about how I shouldn't trust the MID and should follow his stupid 3,000mi sticker instead. The MID said I had 30% left on that oil when it was changed. I trust the MID...
Old 01-11-2013, 05:47 AM
  #111
sleeper22's Avatar
Most quick lubes are trained to take every dollar they can.
Old 01-11-2013, 06:43 AM
  #112
jdm_94-07TypeS's Avatar
MID in 15% so time to get some new oil!!
Old 01-11-2013, 08:48 AM
  #113
ff4930's Avatar
My MID has been stuck at 70% for months now. I've had the car for about 9 months. Is this normal?
Old 01-11-2013, 10:50 AM
  #114
3G TL/2G MDX Owner
TLtrigirl's Avatar
^^do you drive the car?
Old 01-11-2013, 11:04 AM
  #115
Undying Dreams's Avatar
Received 3,824 Likes on 2,847 Posts
I'm at 10%
Old 01-11-2013, 01:45 PM
  #116
It has to be seriously overfilled for foaming. Like 4-5 quarts overfilled. Same with weeping. Think about every time you hit a large bump or take a hard corner, the oil goes all over the place. I'm not sure how well baffled the oil pan is but you get a huge margin of error. The rear main would be the first seal to suffer if its from being too full. Basically don't sweat getting the level just perfect.
Old 01-12-2013, 03:00 AM
  #117
anx1300c's Avatar
Every March with Redline and an RP filter. Usually 8-9k, but I've already done ~10k since last March. Maybe I'll do it a little early this year.
Old 01-13-2013, 03:25 PM
  #118
BuLtL00's Avatar
I also have the same question.I have an RL but pretty sure is the same.Here is some info.
Changed oil 04/2012 at 84,3xx,MID reset to 100%
Current mileage is 85,9xx,MID is 80%
Acura dealer sticker on windshield says back on 10/12 at 15%
According to sticker i am overdue,according to MID 65% away
What should i do,does oil go bad over time even if you dont drive the car much.Thanks
Old 01-13-2013, 03:39 PM
  #119
makk's Avatar
Ignore the sticker, you can easily go till April. Oil does go bad once open but years not months.
Old 01-13-2013, 03:43 PM
  #120
It's safe to follow the MID or one year, whichever comes first. When you don't drive the car much you have to deal with a higher level of fuel dilution, water, acids, etc. The oil doesn't go bad but the total base number (TBN) goes down to where it can no longer protect from the acids.
I wouldn't pay any attention to a dealer sticker basing your oil change on time unless you've been over a year. Oil itself doesn't go bad, if you just dumped it in your engine and never started it, it would last indefinitely. But driving it introduces the contaminates I talked about and all of the bad things associated with it, that's why one year is the limit even if you've only driven 500 miles.
The following 2 users liked this post by I hate cars:
BuLtL00 (01-13-2013), TLtrigirl (01-13-2013)
Quick Reply: How often do you change your oil?
