How many gallons needed for a coolant flush?
Old 11-10-2018, 07:56 PM
VictorTL's Avatar
My coolant looks a bit of cloudy blue . I want to do a full flush. How many gallons do I need?
VictorTL is offline
Old 11-10-2018, 08:20 PM
theCoffeeFiend's Avatar
Recently did mine a few months ago. 2 gallons of coolant shall do. I would recommend getting Honda coolant, just for peace of mind. Doesn't cost that much more.
theCoffeeFiend is offline
Old 11-11-2018, 10:58 AM
nick04tl's Avatar
I use Honda coolant as well. You need 2 gallons and will have some left over.
nick04tl is offline
Old 11-11-2018, 06:29 PM
VictorTL's Avatar
Thank! Warm up the car until the thermostat open and remove the drain plug under the radiator and behind the engine block. Correct?
VictorTL is offline
Old 11-12-2018, 11:00 AM
VictorTL's Avatar
You think it is a good time to replace the thermostat as well. The car had 90,000 miles
VictorTL is offline
Old 11-12-2018, 08:19 PM
Pair of TLs's Avatar
Thermostat
Absolutely.
Pair of TLs is offline
Old 11-12-2018, 09:05 PM
GhostTL09's Avatar
I would
GhostTL09 is offline
Old 11-13-2018, 08:03 PM
VictorTL's Avatar
Ok thank
VictorTL is offline
Old 11-13-2018, 08:10 PM
WDPanda's Avatar
wait what? No dont do that unless you want to burn yourself. Cold car, drain from rad and remove thermostat some more fluid will come out. You have the optional (harder) drain plug on the engine block as well. Change thermo while youre at it. 2 gallons. Use a coolant funnel or you'll wish you did.
WDPanda is offline
Old 11-14-2018, 12:30 PM
Received 8,568 Likes on 6,621 Posts
a quick search of this site would have found the results you were looking for, no need to open a new thread for simple questions like these:
https://www.google.com/search?q=site...hrome&ie=UTF-8
thoiboi is offline
01RedCLS
08-11-2012 12:56 PM
rybin87
10-29-2010 10:16 AM
bluesman78
05-15-2006 09:56 PM
Stew97CL3.0
02-06-2006 09:43 PM
Quick Reply: How many gallons needed for a coolant flush?
