Notices
Third Generation TL (2004-2008)
How many catalytic converters does a TL have?
Old 11-28-2014, 11:31 AM
Registered Member
i have a 08 types and my cats went out ...was wondering how many does it have and ...can i run some cats of a 05 tl?...
72types is offline
Old 11-28-2014, 11:49 AM
Received 13,979 Likes on 10,384 Posts
two primary and 1 secondary.
so 3 all together.
the third one underneath the car doesnt have a sensor and will not throw a code if removed.
justnspace is offline
Slot Machine Lubricator
1black_seven's Avatar
You have 3.
2 on the block, 1 on the J pipe.
The Type-S has different cats than the base model. Lower cell count I believe.
1black_seven is offline
Old 11-28-2014, 01:43 PM
Get Out Of The Left Lane!
NBP04TL4ME's Avatar
Agreed with 1black_seven as I don't believe they are x-compatible.
NBP04TL4ME is offline
Old 11-28-2014, 02:19 PM
runnin a little boost
Hi speed's Avatar
The 05 cats will fit the type-s, you will lose a few HP due to the 05 cats being more restrictive. Cats are expensive so make sure they are really bad before replacing them. The 3rd cat is under the car and most likely not damaged, so you may only need the two primary cats attached to the engine. The rear cat is hard to get to and might be worth having a shop do for you.
Hi speed is offline
Old 11-28-2014, 03:06 PM
Registered Bunny
polobunny's Avatar
Received 1,061 Likes on 886 Posts
Seconded. Make sure your cats are really clogged and the cause of your issues unless you like throwing money around, in which case I can send you my bank account information.
polobunny is offline
Old 11-28-2014, 09:26 PM
Registered Member
pohljm's Avatar
doubtful the cats went bad, certainly not all three. what makes you think they are bad? they should be under warranty for quite a long time as well as an emissions component.
pohljm is offline
Old 11-29-2014, 11:20 AM
Registered Member
lol...im goin to my buddys shop and ok tht makes sense..and yea i have this guy selling all 3 cats and the o2 sensors 250 is tat a good price?
well both my front and rear o2 sensors are bad and i think thts wat caused the cats to go bad...i could be wrong but idk
72types is offline
Old 11-29-2014, 02:13 PM
Administrator
Regional Coordinator
(Mid-West)
Steven Bell's Avatar
Received 6,149 Likes on 5,054 Posts
Punctuation is your friend....
Steven Bell is offline
rockstar143 (12-05-2014)
Old 11-29-2014, 08:07 PM
Registered Member
pohljm's Avatar
Yep your wrong, O2 sensors dont cause cats to go bad
pohljm is offline
Old 11-29-2014, 08:40 PM
David_Dude
Acura_Dude's Avatar
But bad O2s can cause your mpg to go down big time.
Acura_Dude is offline
Old 12-03-2014, 09:00 AM
Make it so
DuoDSG's Avatar
Thumbs up
If you look up the January 2008 Service Bulletin, there is an article there about the three catalytic converters, the codes that each will give you if there's an error, and a nice diagram of where they actually are in the car:
http://www.tegger.com/hondafaq/p0420/B080100.pdf
(Look on page 3)
As per the article (for anyone that doesn't want to click on the link):
Acuraís compact V6 engine uses three catalytic converters:
ē The front warm up three way catalytic converter (WU-TWC) thatís bolted to the front cylinder head
ē The rear WU-TWC thatís bolted to the rear cylinder head
ē The under-floor TWC thatís downstream and mounted to exhaust pipe A
Both of the WU-TWCs are monitored and can set DTCs. Each bank has a specific DTC: P0420 for bank 1 and P0430 for bank 2. The under-floor TWC isnít monitored and wonít set any DTCs.
A word of advice for the OP:
Replacing a cat is expensive. It's more common that the O2 sensor associated with that cat is bad, and it is cheaper to replace. You need to diagnose it correctly so you don't end up replacing a part you don't need only to find that you actually should have replaced the other part.
DuoDSG is offline
Old 12-04-2014, 01:59 AM
paperboy42190's Avatar
Received 1,149 Likes on 838 Posts
too many
paperboy42190 is offline
Old 12-05-2014, 01:47 PM
Platinum Sponsor
ExcelerateRep's Avatar
As Hi Speed said, the cats will physically fit, but the non Type-S cats will be more restricting. We sell our XLR8 High Flow Cat for $299 that will provide you with better performance
XLR8 High Flow Cat - Excelerate Performance - Japanese and European Performance Specialists!!
__________________
Connecticut's Finest and Master Distributor For:
Stoptech | TEIN | Ktuner | XLR8 | ISC | Kraftwerks
ExcelerateRep is offline
Old 12-05-2014, 01:58 PM
rockstar143's Avatar
Received 14,801 Likes on 11,020 Posts
Upstream 02 is an AF ratio sensor, and not just a dirty sniffer like the lower 2.
I doubt the cats are bad, although high flow ones are a good option.
rockstar143 is offline
Old 05-08-2019, 06:04 PM
New Member
Catalytic converter problem
I have a 2002 Acura TL I have allot of heat coming from the car. Which indicates my converter/converter's are stopped up. Which one is most likely to be stopped up
Acman44 is offline
Old 05-09-2019, 06:09 AM
If I had to guess rear but only using logic and path of least resistance since it's the shortest distance out the back.
Acman44 (05-10-2019)
Old 05-09-2019, 04:05 PM
Received 5,846 Likes on 4,687 Posts
Get an infrared thermometer and go under the car. Point the thermometer to the cats and you'll see very quickly which one is clogged.
thoiboi is offline
Old 05-10-2019, 10:57 AM
New Member
Now I'm being told a 02 sensor might be bad.
Acman44 is offline
02-20-2017 09:14 AM
hpfiend
Second Generation RL (2005-2012)
09-27-2015 06:59 AM
Dman00tl
2G TL Photograph Gallery
09-25-2015 10:34 AM
Rcelestino93
09-23-2015 10:01 PM
jpm3071
NY/NJ
09-07-2015 08:25 AM
Quick Reply: How many catalytic converters does a TL have?
