Notices
Third Generation TL (2004-2008)
How hard is it to put j37 into 3rd gen '07 TL type S
Old 05-11-2017, 11:41 AM
New Member
Liked 0 Times in 0 Posts
My engine has close to 200 k miles and the head has been tapped... Just looking to replace the engine but just wanted to know how hard would it be to put a j37 instead of the j35 it comes with?
Rafael Silva is offline
Old 05-11-2017, 11:46 AM
Liked 13,899 Times in 10,328 Posts
ecu, tranny, wiring.. and that's just the beginning!
fix the heads and be done with it
justnspace is online now
Old 05-11-2017, 11:51 AM
New Member
is that something that could be done at a shop or should I take it to dealership
Old 05-11-2017, 12:00 PM
anything can be done at a shop....
anything can be done at a dealership...just depends on how much you want to pay...
a mechanic will take off the heads.. and inspect the heads and valves. then either replace the valves or machine the head...then put it right back on
Old 05-11-2017, 12:04 PM
New Member
Thanks man I really appreciate it
Old 01-28-2019, 02:39 AM
Registered Member
Liked 7 Times in 7 Posts
Direct bolt on. Depending if which j37 you use, different things need to be done.
Gumby309 is offline
Old 01-28-2019, 06:13 AM
WTF?
Midnight Mystery's Avatar
Liked 249 Times in 223 Posts
Are you auto or 6 speed currently?
Midnight Mystery is offline
Old 01-28-2019, 09:34 AM
Registered Member
horseshoez's Avatar
Liked 812 Times in 605 Posts
Have the head with a tapped spark plug hole replace and call it done. For these engines, 200,000 miles is pretty young (assuming the engine has been well maintained.
horseshoez is offline
Old 01-28-2019, 09:53 AM
Registered Member
truonghthe's Avatar
Liked 989 Times in 850 Posts
the 3.7 is a direct bolt on? wow may be I should swap my motor with the NSX its a direct bolt on.
truonghthe is online now
Old 01-28-2019, 09:45 PM
Registered Member
My car is a 6speed tl type s. And yes the j37 bolts right up to an auto and manual 07 acura tl type s. Im currently using a j37a1 short block from 07-09 mdx. 2010 mdx j37a1 alil different but still bolts on to our trannys. My j37a1 from 07-09 mdx had bad headgasket. Warped heads so we ending up using the original j35a8 type s head on the j37a1 short block.
Gumby309 is offline
The following users liked this post: Gumby309
teh CL (01-30-2019)
Old 01-29-2019, 12:36 PM
Registered Member
you would know if its bolts on if you actually attempted it. Just like any other long block replacement. Keep original harness and transfer over mounting brackets and accessories. Pretty straight forward swap for 07-09 j371a1
Gumby309 is offline
Old 01-29-2019, 02:59 PM
WTF?
Didn't even realize this was an old thread.
DC2Teg97
02-28-2014 11:43 AM
rets
01-01-2013 09:50 PM
truonghthe
29
08-02-2012 08:06 PM
datmrman
254
10-04-2006 12:16 AM
TheAcAvenger
Racing & Competition
09-17-2006 01:48 PM
Quick Reply: How hard is it to put j37 into 3rd gen '07 TL type S
