Hood Supports
#41
@OsK: I just want to know if you're sure that the Strongarm 4160 will fit an 08 TL-S. When I check via Amazon, it is telling me that those struts will not fit the 08 TL-S. I am all for getting the better product, but I just want to verify that the 4160's will fit. Thanks.
#44
I replaced the TL's ones today damn, pulled the driver side one off and the hood dropped! (luckly was to the side and was able to catch it). Put on Strong Arm 6351 (got them from Amazon.ca for canadian folks for 50 bucks and some change minus a gift card I had for Amazon).
The one strong arm is able to keep the hood up no problem, with 2 it feels like my hood is going to pop off
Another plus one for Strong Arm hood lift supports. Took less than 3 minutes to do both sides.
The following 2 users liked this post by mau108:
ggesq (03-17-2015),
guitarplayer16 (03-14-2015)
#45
4160 or 6351 should fit fine.
#47
I always wanted StrongArm ones but when I looked on Amazon.com, it was quite expensive.
So then I was about to process my order with rockauto until I read your post.
Checked out Amazon.ca, and they had the strongarms.
No dealing with currency conversion, it had free shipping, and shipping took 2 days (I placed order on March 15).
Just installed them and couldn't be happier, thanks to your post.
Rockauto comes to $41 USD, convert that to CAD is $52.43.
Amazon.ca came to $53.94.
#48
Thanks for sharing.
#50
Are there any differences between SG326009 & SG365001? I keep finding that one is for the 04/05 and the other is for 07/08?
Rock auto only has the 04/05 ones left in stock (SG326009).
I just wanted to make sure since i have an 07, even tho I believe both should fit based on the comments above. Please confirm - Thanks
#51
#54
My hood lifts are faulty for awhile. Have to hold up the hood with piece of wood when working few times fell on my head. This winter noticed the hood near the lifts doesn't shut properly. Think it's the hood strut lifts on the passengers side, making the hood warped not flush when closed.
Only about 15 inches of the hood is not flush with the passenger fender exactly above the hood lifts.
Does anyone believe a faulty hood strut lift can warp the hood lifting it when closed? Thought at first ice bent the hood or warped the metal at the fender and hood seams, in the winter.
Now i think it has to do with the lifts making one corner not shutting properly bulging up slightly. Almost can stick my fingers in between the hood and fender at the passengers side of the hood.
Anyone agree?
Or could it be a hinge problem?
Either way i need new strut lifts buying them see if it corrects the body of the hood shutting flush with the fender.
Anyone agree?
#55
I just replaced mine today on my '08 TL Type S with the parts I bought from RockAuto,com at <$15 a piece. Fits perfectly, part number SG365001 for both the left and the right. You can can spin the bottom around.
Use a piece of wood to prop the hood up while changing it but I find that it it's quicker to replace if you "loosen" the clips first.
#56
gee, should I change them myself or go ahead and have my dealer take care of them for the small fee of $206.
#57
i did this last winter. very easy. i did this swap in the dark by myself and very little ambient lighting. definitely would recommend saving yourself the $ and doing it yourself.
i have almost 0 mechanical experience. i have only changed bulbs and fuses on my car.
used this https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
watched this
watched this
#59
and just to be clear, I was being sarcastic, there is no way I would need them to do something like that for me.
#62
Monroe 901709 works on 2004-2005
AMS Automotive 6351 works on 2004-2008
Sachs sg326009 works on 2004-2005
Sachs sg365001 works on 2006-2008
2005 - https://www.rockauto.com/?carcode=1430829&parttype=1404
2006 - https://www.rockauto.com/en/catalog/...t+support,1404
So, one out of four (AMS) has the same part number for 2004-2005 and 2006-2008. Fwiw, I recently bought the Monroes for about $12.50/ea - the installation was easy and they work great.
#64
I just installed these on an '04 TL, $14.20 shipped!!. Very stiff, work great. Can't give any long term reports though, only been on a week:
Qty(2) Hood Lift Supports Struts Shocks Springs Fit 2004-2008 Acura TL 6351 | eBay
#66
08 TL type-S
Thank you Brothers!
Sachs Stabilus hood lifts $16.00 each, 2x $16.00 around $40.00 with shipping from Car Parts Discount Inc. Simi Valley , CA. Fit fine , like OEM. No more sticks and tearing my hood lining up.
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
ExcelerateRep
10-14-2015 08:20 AM
