Higher Mileage Crew, let's talk BUSHINGS!
Fearless DIY Guy
So, she's getting up there for sure, and there's no doubt the compliance bushings are once again gone. While I will be replacing them in short order, aside from the compliance bushings, are there any others you'd recommend replacing?
I'm in the exact same boat, man.
I'm planning to order all 3 bushings (#9, #10, #11) as I'll be taking out the lower control arm myself and getting a shop to press the bushings out for me.
Heeltoe has aftermarket bushings, but they're really expensive.
http://www.heeltoeauto.com/fastline-...x-tl-tl-s.html
Being an Acha Bacha in
I always wondered if this is what leads to the deterioration in overall comfort and ride quality and characteristics of older cars. When new the car was nice and sturdy feeling and tight. Over the years even with proper routine maintainance of suspension components it's not like new.
Maybe someone can chime in.
There's a lot of bushings in the rear. There's a lot more arms, but I haven't seen those go out yet, they seem to be a lot more durable or they undergo less stress.
For the front, besides the lower control arm there aren't many other bushings. There's the front sway bar bushing but no one wants to change that one at home lol
There are other rubber pieces like motor mounts that wear out, and couple ball joints
The following 2 users liked this post by paperboy42190:
cokorote (04-29-2014),
JuicyLarry (07-01-2014)
Haha, I had my sway bar bushings changed out when the transmission was being worked on (nothing wrong with them though). They only charged me for the parts ($6 each I think). The engine mount was also bad and was replaced. I was at 122k miles.
you cant expect one set of bushings to fix a "poor" ride quality on a high mileage vehicle. take my 92 Civic for example. 221k miles on it and the bushings were worn slap out. i replaced every single suspension bushing on it and it made all the difference. HardRace made the kit for the civic along with other companies like Skunk2 were i got front upper and rear lower control arms.
it doesnt matter if the bushings aren't torn or damaged, per sae. They all wear out and allow the pin to sag allowing more movement/travel.
I dont believe i could bare to have a full metal spherical bushings. But i wouldnt mind hearing more reviews than what is on their page.
This is a great thread. I would like to know all the bushings in the car that could be changed and could restore like new ride quality and feel.
For example in colder climates I feel the car is tighter and stiffer and nice compared to when weather is warmer outside. Then I feel the ride is more floaty and loose. I am going to go out on a limb and say this is due to compliance of the rubber bushings due to temperature change which makes
logical sense.
I really think its the subframe bushings that need to be changed to restore the ride I'm talking about it.
logical sense.
Moved to the LOU
I ordered and have received the three front bushings as well as rear bushings. I'm also replacing my rear trailing and control arms with ingalls. My car feels sloppy even with new coilovers... Its got to bebtje bushings. I hope. Car has 125k on it.
Just buy complete replacement front LCA's... they're $60-70/shipped ea. Where as if you buy the bushings, they're ~$60/shipped. Then you have to take the time and or pay labor to have them pressed out and new one back in...
I just had this done on my '06 TSX
Bought new LCA's off of Rock Auto .com
I am about to replace all of my bushings as well and was going to use the 07-08 Compliance Bushings on my 04-06. I have heard the 07-08 are softer but are they less prone to cracking is that why Acura made them softer?
Is this a good idea or should I just use the 04-06? I will be putting in type S shocks at the same time too.
TLX-S
logical sense.
logical sense.
My compliance bushings have the slight crack that's considered "normal" for them and have been that way for the past 2 years with no change, no issues with ride in city and highway driving. My '04 TL currently has 97600 miles.
Great thread. I know this is about bushing but I changed the raxle and new shock and that make all the difference on ride quality on TL. It was like brand new car and "nice and sturdy feeling or tight". But I'm going to change the LCA bushing to the aftermarket one when the oem get cracked badly.
Fearless DIY Guy
All said and told, it looks like we're at $450 for parts alone if we go HAM on the issue.
As of this point in time, here's where I'm thinking the culprits lie, and I'm contemplating whether or not I bite the bullet and do it. Let's assume (a) The tires are in good shape, (b) alignment is in spec, (c) wheels are not out-of-round, and (d) suspension is in good, working order
I could completely be talking out of my ass, but this is a thread for generating ideas, so let's keep it constructive
SUSPECTED ROOT CAUSES
1.) Fatigued / oxidized rubber bushings (all)
2.) Fatigue of mechanical fasteners (mild elongation)
3.) Disposition of nut / bolt head from original fastened position
4.) Improper torque value on fasntener
ORDER of OPERATIONS
CONTROL ARM BUSHINGS
1.) Compliance Bushing (51394-SEP-A01) - $28
2.) Front Arm Lower Bushing (51393-SEP-A01) - $22
3.) Shock Absorber Bushing (51810-SDA-A01) - $16
SECONDARY ITEMS
4.) Front Stabilizer Link (51320-SDA-A05 / 51321-SDA-A05) - $16
5.) Upper Arm Assembly w/ Knuckle (51450-SEP-A02 / 51460-SEP-A02) - $55
6.) FSB Bushings (51306-SEP-A01) - $3
7.) Front Ball Joint, Lower (51220-SDA-A0) - $64
I think I'm going to shop around and see what labor would run on all of this...I just don't have the time to do it myself, but I think this should solve the problem?
Fearless DIY Guy
Moved to the LOU
ORDER of OPERATIONS
ORDER of OPERATIONS
6spd FTW
I would suggest adding new sway bar end links too. I was going to do the compliance bushings on my car before I sold it and noticed the end links were rather rusty. Fully expected to have to ruin one or more pieces of the hardware in the process.
Moved to the LOU
Here is what I have so far.
51394-SEP-A01 - BUSH ASSY., FR. COMPLIANCE - $27.71 - x2
51393-SEP-A01 - BUSH, FR. ARM (LOWER) - $21.87 - x2
0181-S84-A00 - BOLT, TRAILING ARM (12X68) - $1.70 - x4
90215-SB0-003 - NUT, SELF-LOCK (12MM) (SATO RASHI) - $0.84 - x2
90119-SEP-A00 - BOLT, FLANGE (14X100) - $4.11 - x2
90124-SEP-A01 - WASHER, PLAIN (14MM) - $1.91 - x8
90122-SEP-A00 - NUT, FLANGE (14MM) - $1.33 - x2
90123-SEP-A01 - WASHER, PLAIN (12MM) - $0.64 - x4
90181-S84-A00 - BOLT (12X68) - $1.70 - x4
90215-SB0-003 - NUT (12MM) - $0.84 - x2
90119-SEP-A00 - BOLT, FLG (14X) - $4.11 - x2
90122-SEP-A00 - NUT, FLANGE - $1.33 - x2
I have an additional list of parts I decided to order today. Will post that tomorrow. Left the list in my car.
Mr. Detail
Replaced worn LCA bushings with Moog and upgraded to the solid TL Type S front anti-roll bar. Front end feels noticeably tighter. Was a little jittery on on off ramp near me, now it tracks straight through it. FWIW, I had a little over 150k miles on my car and front struts were replaced about 30k miles ago.
Fearless DIY Guy
ORDER of OPERATIONS, UPDATED..APPROX. +$600
SECONDARY ITEMS
8.) Outer Tie Rod (53540-SEP-A02) - $40
9.) Inner Tie Rod (53010-DSA-A01) - $51
10.) Gearbox Mounting Bushing (53685-SEP-A01) - $6 x 2
SECONDARY ITEMS
SECONDARY ITEMS
SECONDARY ITEMS
My labor for just swapping my LCA's, endlinks, and (1) ball joint was $125... @ $55/hr
AcuraPartsforless.com
SECONDARY ITEMS
SECONDARY ITEMS
Current mileage is 123k. Over a span of 3 year or 20k miles I changed the following:
1. Both Lower Control Arms
2. Inner and Outter Tie Rods
3. Steering Rack
4. All 3 Engine Mounts
5. Sway Bar Endlinks
6. Sway Bar Bushings.
7. Replaced to TYPE S Suspension Top Hats and Bushings for Suspension
8 Replaced both Upper Control Arms
9. All 3 Transmission Mounts
All of this was done at Acura with OEM parts in order to fix the loose feeling which it really never did. It felt like it did for a day or two but then it was evident it didn't (placebo effect). Then when my transmission took a dump and they replaced it, I felt almost instantly my car gained 30% of its stiffness back. The only thing they changed at this time was the transmission and nothing else.
The only theory I could come with is that they dropped the subframe and when they mounted it back up all the bolts were re-torqued and tightened and hence eliminating the flex in the body and holding all the other parts listed above in place as well. However fast forward 7 months later and its now starting to feel loose again. This is why I think the issue is surrounding the subframe rather than all these other components.
The entire engine is mounted and sits on the subframe. If the subframe bushings have more play in it, this could cause the body to flex more during driving as the weight of the engine is not be supported firmly and cause body roll and sway. Keep in mind the engine mounts would be normal and good. I could be totally wrong but this but this is my theory.
