Notices
Third Generation TL (2004-2008)
HID/LED Daytime running lights
Old 06-28-2013, 02:08 PM
Registered Member
i saw an 07/08 TL on the road the other day facing me, didn't realize it at first but there was a subtle mod that i realized later was HID or LED daytime running lights. they look pretty cool and much whiter.
i don't know if it actually has a practical function, but what kind of mod is this, is the entire headlight assembly changed. anyone have any examples. is it HID or LED? i did a quick search and sound 'halo lights' but read some pretty bad reviews about its compatibility
any thoughts?
anagramjones is offline
Old 06-28-2013, 02:36 PM
BANNED
Received 2,877 Likes on 1,781 Posts
nobody knows what you're talking about.
are you referring to DRL's? Halo/Angel Eyes? HID lights?
SharksBreath is offline
Old 06-28-2013, 02:39 PM
Deezy
whoismiked's Avatar
whoismiked is offline
Old 06-28-2013, 04:46 PM
Registered Member
vietxquangstah's Avatar
Like this?
vietxquangstah is offline
Old 06-28-2013, 07:03 PM
Registered Member
yeah something like that. the ones i saw were hollow circles, looked like a BMW. are they LED? seems like it makes sense, cause an HID (if it's HID) would be solid, not hollow, like vietxquangstah's photos.
they were white/bluish like your pic, not yellowish like the stock...halogen?
maybe something like this...it's jdm?
http://www.uniquestyleracing.com/2020actljdmc.html
Old 06-28-2013, 11:02 PM
Registered Member
This is probably what you saw than.
http://www.uniquestyleracing.com/20actlremouh.html
Halos / angel eyes
Mine are LED Daytime Running Light bulbs.
Old 06-28-2013, 11:47 PM
JJH
Registered Member
JJH's Avatar
Any notable differences between the USR kit and the iJDMToy kit?
JJH is offline
Old 06-29-2013, 06:23 PM
Registered Member
Ijdmtoy sells the harness separately if you want to use your own LED bulbs. I use ijdmtoy harness with the 10XB 825 lumen LED bulbs from VLEDs.
Old 06-29-2013, 06:26 PM
JJH
Registered Member
JJH's Avatar
^ The kit I bought from iJDM came with everything including the bulb(s).
JJH is offline
Old 06-29-2013, 10:31 PM
Registered Member
What I meant to say was that iJDMtoy also offers their DRL harness separately if you wanted to buy other better LED bulbs to use.
If you want everything all at once they also do offer the DRL harness + 68 smd LED bulbs..
I myself chose to use the ijdmtoy harness by itself (I also had a 15% off discount code at the time) and bought super bright 5k white 9005 DRL bulbs from vleds (had 35% discount code for that)
I paid less than $60 and got some damn bright good looking LED DRLs now. I've seen a 68smd LED DRL bulb in a 2G TSX and I don't like how you can clearly see each small individual LED in the reflector. It looks very weird and not uniform. Multiple bright dots scattered.
Old 07-01-2013, 10:06 PM
JJH
Registered Member
JJH's Avatar
^ There are three levels of pricing for the 9005 bulbs. Did you get the most costly of the three? I decided to get the iJDM harness and get the vLed bulb as you suggested above. I dig bright white DRLs.
JJH is offline
Old 07-02-2013, 09:16 PM
Registered Member
Sorry for the late reply but I noticed in the other VLEDs sale thread you said you already made a purchase.
I bought the 10XB 850 lumen LED ones.. They are $59.99. I had a 35% off coupon when I bought them earlier this year. Check out this thread
https://acurazine.com/forums/third-generation-tl-2004-2008-93/vleds-6-led-725-lumen-drl-9005-bulb-884617/
Those are the 6XB 725 lumen ones. I exchanged those after trying them out for a week to get the 10XB 850 Lumen versions.
Old 07-02-2013, 09:26 PM
JJH
Registered Member
JJH's Avatar
JJH is offline
Old 07-06-2013, 11:03 AM
Registered Member
does this mean the LED becomes your high beams too? what do you do about high beam? are LED as good as halogen as high beams?
Old 07-06-2013, 11:07 AM
The Boss
Nick216's Avatar
our low beams and high beams come from one bulb. drls have nothing to do with high beams. and halogen are shit.
Nick216 is offline
anagramjones (07-06-2013)
Old 07-06-2013, 06:14 PM
Registered Member
actually this looks pretty cool, and simple. vleds are out of stock though... and i'm in canada
Old 07-06-2013, 07:46 PM
paperboy42190's Avatar
Received 1,149 Likes on 838 Posts
i got mine from JLC
paperboy42190 is offline
Old 07-06-2013, 09:15 PM
Registered Member
Originally Posted by paperboy42190 View Post
i got mine from JLC
doesn't look like they have vleds
Old 07-21-2013, 11:12 PM
Registered Member
Can u just change the bulb or have buy a conversion kit or something to look like hid
xkobe0821x is offline
Old 06-11-2019, 07:19 PM
New Member
In reguards to HID daytime running lights
So i attempted to install HIDs for my 07 Acura TL 9005 8000k bulbs. While doing so the instrument panel DRL went on and the HID lights didn't? This kit has a ballest that comes with it. Is their something i missed doing While installing them? Or possibly the wrong kit? Or do i need restricters to go with this as well? Any input,ideas, or comments will help. Thanks
Adrian cruz is offline
Old 06-12-2019, 10:16 PM
Registered Member
peter6's Avatar
I explained it in my thread about installing LED DRL's on my TL. If you simply plugged in ballasts into the existing DRL bulbs sockets, same stuff applies. Otherwise skip the rest of this post.
https://acurazine.com/forums/third-g...nstall-960677/
In summary, in stock setup, DRLs are run in series to cut voltage in half, thus cutting power, so bulbs are dimmer than normal.
So now ballasts (or LED bulbs) are also run in series, which is not good for them (let's assume they get 6V each, while designed to work at 12V). So they might work intermittent, barely lit up, or most likely don't work at all.
Now I would discourage you from running HIDs as DRLs. Why? Too bright - they will blind all oncoming traffic. Also HIDs will be much hotter than stock bulb at half power - they might melt the headlight as headlight was not designed for bulb with that much power in this location.
I'm running LED bulbs, that provide about same amount of light as stock bulbs, but they are white - not yellow - if that's what you are looking for.
So now how to fix your problem? Either do it my way (make modifications to your wiring) (cheap but harder to reverse to stock) or buy one of LED wiring harnesses with resistors and relay. If you go my way with HID keep in mind that DRL harness was not designed to run two 35W ballasts. Stuff might fail.
peter6 is offline
mada51589
05-10-2019 02:17 PM
spidermankb
03-05-2019 11:34 AM
space_boy
Acura ILX Discussion
51
08-15-2017 12:06 PM
PortlandRL
09-14-2015 12:01 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
Quick Reply: HID/LED Daytime running lights
