Help with Side markers LED Change.
Sup guys,
I have a few qestions. I have notice that some TL drivers have replaced there side markers to being 2 colours. It will stay white while normal driving and when you signal right the white colour changes to amber flashing . Anyone tell me where I can get these and what they are called? Do you have to change the hole marker or is it just the bulbs that you change after removing the marker lens? I have also noticed people doing it with the light in the headlight signal . Anyone have any links to pass threads about this I could not find any.
Hoping to gey JnC to do my headlight mod as well!
Please any help would be great
Nighthawk type S
Nighthawk type S
For cleared headlights (what JnC does), we are using the switchback LED bulb in the turn signals. There are 2 types: Type 1 shines white and flashes amber-white-amber. Type 2 shines white and flashes amber-off-amber. The bulbs are a direct fit, but you need to install resistors to prevent "hyperflashing". Here is a pic of the Type 1 bulbs I am using. Note that I took a Sharpie to the bulb to make it blacker:
The sidemarkers are custom made using a Type 2 switchback. The marker needs to be removed and cut open. As mentioned, gerzand here on AZ does this work for a fee. Contact him directly for pricing info.
Here are my switchback DEPO sidemarkers:
Hi guys
thanks for the info so far, Can those led lights that are going in the headlight be installed with out having to remove the bumper ? Or they can only be installed when the headlight mod is being performed?
So gerzand is the guy to talk to about the side markers. I will have to try and contact him but I still cant pm anyone yet.
Your light look sweet man cant wait to have it done on mine.
Nighthawk type S
Nighthawk type S
acura, acurazine, cahnge, change, changing, headlight, led, marker, markers, remove, side, sidemarker, sidemarkers, switchback, tl
